Following the instructions at https://github.com/NVIDIA/nvidia-docker/wiki/NVIDIA-Container-Runtime-on-Jetson i am doing some tests for running GUI apps in a docker container in a jetson nano, i’m using the following code to do the tests:
docker run --runtime nvidia --network host -it -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-base:r32.4.3
apt-get update && apt-get install -y mesa-utils
export DISPLAY=:0.0 && glxgears
everything works well, in this example i run the container in host mode (–network host) but i have an application where i want to run the container isolated from the host, after i remove --network host
and run the container, doing the same steps i got the following error:
root@056440576e00:/# glxgears
the strace log:
socket(AF_UNIX, SOCK_DGRAM, 0) = 7
connect(7, {sa_family=AF_UNIX, sun_path=@"nvidia20ac498a\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"}, 66) = -1 ECONNREFUSED (Connection refused)
close(7) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x28c48} ---
+++ killed by SIGSEGV (core dumped) +++
Segmentation fault
gdb log:
(gdb) r
Starting program: /usr/bin/glxgears
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x0000007fb78736a4 in ?? () from /usr/lib/aarch64-linux-gnu/libGLX_nvidia.so.0
(gdb)
why i’m getting the segmentation fault only running in the isolated mode. Maybe i have to mount other things besides /tmp/.X11-unix/:/tmp/.X11-unix
the host is running yocto using the dunfell-l4t-r32.4.3 branch from meta-tegra
