Running Inference on AGX GPU
Hi, I am currently benchmarking inference on both the Jetson AGX Orin and the Jetson Orin Nano using TensorRT.
A UNet model that I am benchmarking achieved a throughput of 58.3 FPS on the AGX Orin, and 131.5 FPS on the Orin Nano. I am trying to understand why inference on the AGX is so much slower than on the Nano.
One thing I wanted to look into is running inference on the AGX using only the GPU. I have not been able to find anything online detailing how this would be achieved using TensorRT.
Any help detailing how to benchmark only on the GPU, or around the benchmarking results I am seeing would be much appreciated, thanks.
Your result doesn’t match our expectations.
Would you mind sharing how the benchmark is conducted?
Below is our benchmark for UNET-sgmentation:
Jetson Orin Nano 8GB: 148
Jetson AGX Orin 32GB: 387
You can find our benchmark tutorial in the below GitHub:
I have two scripts, one for converting the model to trt format:
#!/bin/bash
MODEL_PATH=$1
OUTPUT_PATH=$2
trtexec --onnx=$MODEL_PATH --saveEngine=$OUTPUT_PATH --skipInference
I add additional arguments (–fp16, --int8, etc.) manually depending on the precision that I am benchmarking.
I then run inference using the following python script:
import tensorrt as trt
import numpy as np
import argparse
import os
import time
from onnx_helper import ONNXClassifierWrapper
PRECISION = np.float32
parser = argparse.ArgumentParser()
parser.add_argument('-m', '--engine_model', help='Path to compiled TesnsorRT model.')
parser.add_argument('-i', '--input_path', help='Path to data for inference to be run on.')
parser.add_argument('-is', '--input_shape', help='Expected shape of input data. Expected in the format [b,c,h,w]')
parser.add_argument('-os', '--output_shape', help='Expected shape of output data. Expected in the format [b,c,h,w]')
parser.add_argument('-o', '--output_path', help='Path to save model outputs to.')
parser.add_argument('-v', '--verbose', help='Display inference metrics for every inference.', action='store_true')
args = parser.parse_args()
output_shape = np.array(args.output_shape.strip('[]').split(',')).astype(int)
trt_model = ONNXClassifierWrapper(args.engine_model, output_shape, target_dtype = PRECISION)
input_shape = np.array(args.input_shape.strip('[]').split(',')).astype(int)
totalTime = 0
numfiles = 0
for filename in os.listdir(args.input_path):
    if filename.endswith(".bin"):
        with open(os.path.join(args.input_path, filename), 'rb') as input_file:
            image = np.fromfile(input_file, dtype=PRECISION).reshape(input_shape)
            start_time = time.time()
            output = trt_model.predict(image)
            end_time = time.time()
            inference_time_ms = (end_time-start_time)*1000
            totalTime += inference_time_ms
            numfiles += 1
            if args.verbose:
                print(f'Inference time: {inference_time_ms:.2f} ms')
                fps = 1000/inference_time_ms
                print(f"Throughput: {fps:.2f} FPS")
            with open(args.output_path + '/' + filename, "wb") as output_file:
                output_file.write(output)
avg_inference_time = totalTime/numfiles
print(f'Average inference time: {avg_inference_time:.2f} ms')
print(f'Average throughput: {1000/avg_inference_time:.1f} FPS')
I should also specify that I have benchmarked nine different DNN architectures on the AGX Orin and the Orin Nano, and the Nano has only outperformed the AGX when running the UNet model.
Thanks again for your help.
Could you share the UNet model so we can give it a check?
I have uploaded the model in onnx format to this github repository:
https://github.com/MariaB2000/UNet_model
We will give it a try and then update more info with you.
We tried to test your model with trtexec and met the below error.
[07/04/2024-00:12:45] [E] Uncaught exception detected: ONNX graph has duplicate tensor name:
&&&& FAILED TensorRT.trtexec [TensorRT v8602] # /usr/src/tensorrt/bin/trtexec --onnx=model_new.onnx
It looks like the model has some definition issue on the tensor name, could you help fix it?
This might cause some issues when TensorRT optimizes the layers.
