Note: I am running everything I mentioned below in Linux 18.4 Host machine.
I am running into below error every once in a while running the IMUPlugin for custom IMU sensor.
./sample_imu_logger --driver=imu.custom --params=decoder-path=.../sample_build/src/sensors/plugins/OpenIMU300/libopenimu_plugin.so,can-proto=can.socket,device=slcan0,packetRate=1
[15-06-2020 15:11:13] Platform: Detected Generic x86 Platform
[15-06-2020 15:11:13] TimeSource: monotonic epoch time offset is 1592253860887882
[15-06-2020 15:11:14] Driveworks exception thrown: Platform: cannot acquire CUDA context, error cudaErrorMemoryAllocation: out of memory
[15-06-2020 15:11:14] Driveworks exception thrown: DW_INVALID_HANDLE: Cannot cast to C handle, given instance is a nullptr, type=P15dwContextObject
[15-06-2020 15:11:14] Driveworks exception thrown: DW_INVALID_HANDLE: Cannot cast to C handle, given instance is a nullptr, type=P11dwSALObject
Cannot create sensor imu.custom with decoder-path=.../sample_build/src/sensors/plugins/OpenIMU300/libopenimu_plugin.so,can-proto=can.socket,device=slcan0,packetRate=1
Am I doing something wrong memory allocation wise? I am not using dynamic memory allocation in my plugin anywhere. This problem goes away when I restart the computer. It comes back once a day after running the plugin to test my changes many times.
Dear @rborad,
Which GPU you have? Could you share CUDA sample deviceQuery output log.
Could you check nvidia-smi in a loop to know GPU memory utilization to see if the GPU memory usage is increasing in each run?
Thanks for the reply Siva. I have Quadro T1000 Graphics.
Tue Jun 16 11:15:36 2020
| NVIDIA-SMI 440.59 Driver Version: 440.59 CUDA Version: 10.2 |
| 0 Quadro T1000 Off | 00000000:01:00.0 Off | N/A |
| N/A 53C P3 13W / N/A | 2137MiB / 3914MiB | 2% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2232 G /usr/lib/xorg/Xorg 126MiB |
| 0 3012 G /usr/bin/gnome-shell 92MiB |
| 0 4759 C ./sample_imu_logger 119MiB |
| 0 4798 C ./sample_imu_logger 119MiB |
| 0 4831 C ./sample_imu_logger 119MiB |
| 0 4865 C ./sample_imu_logger 119MiB |
| 0 4897 C ./sample_imu_logger 119MiB |
| 0 4935 C ./sample_imu_logger 119MiB |
| 0 4967 C ./sample_imu_logger 119MiB |
| 0 4999 C ./sample_imu_logger 119MiB |
| 0 5031 C ./sample_imu_logger 119MiB |
| 0 5063 C ./sample_imu_logger 119MiB |
| 0 5095 C ./sample_imu_logger 119MiB |
| 0 5127 C ./sample_imu_logger 119MiB |
| 0 5159 C ./sample_imu_logger 119MiB |
| 0 5191 C ./sample_imu_logger 119MiB |
| 0 5223 C ./sample_imu_logger 119MiB |
| 0 5255 C ./sample_imu_logger 119MiB |
Looks like each time I run the sample it runs always without terminating. How do I terminate them automatically? Is this happening because something I am doing with my custom plugin?
Dear @rborad,
It is clear from nvidia-smi that the memory allocations from each process are not cleared. How are you killing/stopping the process? Do you see the same when running sample in multiple launches without your custom plugin?
This is happening because I am terminating the plugin using Ctrl+z in command line. Plugin doesn’t close properly. Sample plugins close the plugin instance properly because it exits properly once all the input data is processed (it uses a finite logger file to read data). In my case, I am using real hardware to read data. HW sends data continuously and plugin parses that infinite data continuously until you force it to break. In this case plugin doesn’t close properly because it never gets to the point where SAL calls _dwSensorPlugin_stop(). I see the same problem when I use the sample plugin with real hardware (sample_CAN_logger using [can.socket, param=device=slcan0]).
Ctrl-Z just stops the process in the background. You can still see it with “jobs” command and foreground it with “fg” command. That’s why it still occupies the GPU memory. Please try to kill it with “kill” command.
