Running Issac Sim 2023 using GeForce RTX 4070 Laptop GPU
I’m trying to run Issac 23’ on a 4070 laptop GPU, and have been successfully running Issac 22’ without issue using the 535.113.01 Linux driver. However, Issac 23’ seems unwilling to launch on 535.113.01 and throws the following error:
X Error of failed request:  GLXBadFBConfig
  Major opcode of failed request:  148 (GLX)
  Minor opcode of failed request:  0 ()
  Serial number of failed request:  219
  Current serial number in output stream:  219
I have checked the FAQ and tried to uninstall OpenGL etc to no avail.
I am unable to install 525.85.05 due to an unsupported device (525 only supports 30 series Laptop GPUs)
Any help would be appreciated.
SOLUTION:
export MESA_GL_VERSION_OVERRIDE=4.6
then run the following from your home directory
./.local/share/ov/pkg/isaac_sim-2023.1.1/isaac-sim.sh --allow-root
In my instance reenabling my integrated graphics and appending
amd_iommu=off
to GRUB_CMDLINE_LINUX in
/etc/default/grub
and running
sudo update-grub
fixed an unrelated IOMMU warning
