When I run jtop, I noticed that the NVJPG=716.8Mhz. However, my other 3 Xaviers says NVJPG=Off. I uploaded snapshot of my screen.
My question is, how do I get my NVJPG=OFF? Is there a command that I can run?
It shows off when not used, and a frequency when used.
So if you want to get it off, don’t use any command or application that uses NVJPG.
You can find which process uses it with lsof
(may be installed with apt):
lsof | grep nvhost-nvjpg
thank you for the tip
