Running LDC example from modulus sym in Jupyter notebook
I’m trying to reproduce the LDC example from Modulus sym step by step on a jupyter notebook.
I attempted the following in order to load the config into my Jupyter notebook:
import omegaconf
cfg = omegaconf.OmegaConf.load("conf/config.yaml”)
This works for some attributes such as cfg.batch_size, but throws an error when I try to use it here:
flow_net = instantiate_arch(
       input_keys=[Key("x"), Key("y")],
       output_keys=[Key("u"), Key("v"), Key("p")],
       cfg=cfg.arch.fully_connected,
In particular it says:
ConfigAttributeError: Missing key arch
   full_key: arch
   object_type=dict
What’s the correct way to load the cfg into a Jupyter notebook? (i.e. is there a way around using the python decorator that’s used in the scripts?)
although I haven’t tried it myself in a Jupyter notebook, you could try to use the FullyConnectedArch class directly instead of using the hydra instantiate_arch method like:
from modulus.sym.models.fully_connected import FullyConnectedArch
input_keys = [Key("x"), Key("y")]
output_keys = [Key("u"), Key("v"), Key("p")],
flow_net = FullyConnectedArch(input_keys=input_keys, output_keys=output_keys)
This is also described here: FPGA Heat Sink with Laminar Flow - NVIDIA Docs
Thanks for the suggestion, I found the following alternative which worked for me in the notebook:
from modulus.sym.hydra.utils import compose
cfg = compose(config_path="conf", config_name="config")
It’s described here: Jupyter Notebook workflow - NVIDIA docs
