I asked the possibility of using Omniverse on a rendering farm, they answered to me:
This would work best on a virtual workstation machine …as this being a super fast real time render it doesn’t make sense to support it on the farm.
If you are interested we could create a workstation in the cloud for you. We can add up to 8 GPUs on it…equivalent to 8x RTX3080. We can do with 1, 2, 4 or 8 gpus on one machine.
You can use it like your normal machine …connect to it via RDP and use it in c4d, max unreal…etc.
Is this possible? If I take this deal and connect to it via RDP, what should I take care when starting to install Omniverse and Machinima?
Hi!
I logged in to my renderfarm.ro hosted virtual workstation machine.
I managed to install everything: drive, cache, nucleus, create & machinima.
But when I started to use Machinima, my viewport was totally empty.
The workstation was using this GPU: https://www.touchpoint.com.au/shop/nvidia-tesla-t4-gpu/
It should be RTX card, I assume?
There were also 2 error messages. In Machinima:
In Create:
Please help?
Thanks for stopping by with your question, I’ll pass this onto the devs and get an answer for you. Thanks for your patience.
I really need a solution fast.
I am working with Machinima projects now and I need raw rendering power.
The renderfarm that I write above, just told me they cannot get it to work, viewport is always empty:
We’re tracking this issue internally now, but unfortunately it’s not looking like we have a quick fix for what’s causing this problem with the viewport without investigating further. There shouldn’t be any issue running Machinima on a VM. Will update you here with any progress that we make on this.
