Running more than 2 USB camera on Jetson NX with DeepStream5.0 | Error: Failed to allocate required memory
Hi I am trying to below simple deepstream5.0 cammand to run usbcam.
2 camera run fine.
More than 2 camera, it throws error.
I reference:
Running multiple USB cam on nano | Error: Failed to allocate required memory
DeepStream4 Jetson nano multiple webcams issue
connected more than two usb cameras problem on deepstream-app (Jetson Nano Dev Kit)
My configure file below:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=1
camera-width=320
camera-height=240
camera-fps-n=60
camera-fps-d=1
camera-v4l2-dev-node=0
[source1]
enable=1
type=1
camera-width=320
camera-height=240
camera-fps-n=60
camera-fps-d=1
camera-v4l2-dev-node=1
[source2]
enable=1
type=1
camera-width=320
camera-height=240
camera-fps-n=60
camera-fps-d=1
camera-v4l2-dev-node=2
[source3]
enable=1
type=1
camera-width=320
camera-height=240
camera-fps-n=60
camera-fps-d=1
camera-v4l2-dev-node=3
[source4]
enable=0
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=5
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-csi-sensor-id=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
overlay-id=1
[osd]
enable=0
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=model_b4_gpu0_fp32.engine
labelfile-path=labels.txt
batch-size=4
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3_tiny.txt
[tracker]
enable=1
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gpu-id=0
display-tracking-id=1
enable-past-frame=0
[tests]
file-loop=0
Command:
$ deepstream-app -c deepstream_app_config_yoloV3_tiny_camera.txt
output error:
Unknown or legacy key specified 'is-classifier' for group [property]
Warn: 'threshold' parameter has been deprecated. Use 'pre-cluster-threshold' instead.
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
Deserialize yoloLayerV3 plugin: yolo_17
Deserialize yoloLayerV3 plugin: yolo_24
0:00:04.714632390 27856     0x33e0ba00 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/model_b4_gpu0_fp32.engine
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT data            3x416x416
1   OUTPUT kFLOAT yolo_17         255x13x13
2   OUTPUT kFLOAT yolo_24         255x26x26
0:00:04.714953258 27856     0x33e0ba00 INFO                 nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/model_b4_gpu0_fp32.engine
0:00:04.875912495 27856     0x33e0ba00 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo/config_infer_primary_yoloV3_tiny.txt sucessfully
Runtime commands:
        h: Print this help
        q: Quit
        p: Pause
        r: Resume
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
KLT Tracker Init
ERROR from src_elem: Failed to allocate required memory.
Debug info: gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstV4l2Src:src_elem:
Buffer pool activation failed
** INFO: <bus_callback:151>: usb bandwidth might be saturated
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
** INFO: <bus_callback:147>: incorrect camera parameters provided, please provide supported resolution and frame rate
Debug info: gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstV4l2Src:src_elem:
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstV4l2Src:src_elem:
Quitting
KLT Tracker Init
App run failed
We have explained the bandwidth limitation in the links. Would suggest use USB3 cameras.
I think my camera is USB3.0 port
lsusb -t
output:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|__ Port 3: Dev 2, If 0, Class=Hub, Driver=hub/4p, 10000M
|__ Port 1: Dev 4, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 63, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 4: Dev 78, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 4: Dev 78, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 79, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 79, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 4: Dev 50, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 50, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 80, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 2: Dev 80, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 81, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 81, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 49, If 0, Class=Wireless, Driver=rtk_btusb, 12M
|__ Port 3: Dev 49, If 1, Class=Wireless, Driver=rtk_btusb, 12M
You have a USB3 root HUB, and USB3 HUBs on that (the lines ending with 10000M and 5000M). However, your cameras are operating at USB2 speeds (the 480M at end of the line). If your cameras are capable of USB3, but other issues get in the way, then they will in fact back off to USB2 speeds. More likely the cameras (the uvcvideo devices), then either the cameras are on a non-USB3 HUB, or signal quality has degraded. My bet is that your cameras are not connected to the USB3 root HUB.
FYI, if you run just plain “lsusb”, then you will get an ID for each device. If you identify a camera, then you can tell lsusb to provide the details of just that one device. I’ll pretend (for the purpose of illustration) that your camera has ID “0955:7e19” (which is really a Jetson NX). Then you could get a verbose listing for that device via:
sudo lsusb -d 0955:7e19 -vvv
You could log the result:
sudo lsusb -d 0955:7e19 -vvv | tee log_usb.txt
Towards the end of the listing a USB3 device will have some information identifying the USB3 capabilities. This might be cut short on a USB2 HUB not capable of USB3, but most of the time the spec will be listed even if the device is not currently operating at the faster spec. An example would be this verbose lsusb for a USB3 device capable of gen. 1 (5000Mb/s):
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
Thank you very much!
$ lsusb -d 0edc:2076 -vvv
output:
    Bus 001 Device 090: ID 0edc:2076
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2 ?
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x0edc
  idProduct          0x2076
  bcdDevice           10.6b
  iManufacturer           3
  iProduct                1
  iSerial                 2
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength          466
    bNumInterfaces          2
    bConfigurationValue     1
    iConfiguration          4
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass         14 Video
      bFunctionSubClass       3 Video Interface Collection
      bFunctionProtocol       0
      iFunction               5
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass        14 Video
      bInterfaceSubClass      1 Video Control
      bInterfaceProtocol      0
      iInterface              5
      VideoControl Interface Descriptor:
        bLength                13
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdUVC               1.00
        wTotalLength           78
        dwClockFrequency       15.000000MHz
        bInCollection           1
        baInterfaceNr( 0)       1
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0201 Camera Sensor
        bAssocTerminal          0
        iTerminal               0
        wObjectiveFocalLengthMin      0
        wObjectiveFocalLengthMax      0
        wOcularFocalLength            0
        bControlSize                  3
        bmControls           0x00022204
          Auto-Exposure Priority
          Zoom (Absolute)
          Roll (Absolute)
          Focus, Auto
        bLength                11
        bDescriptorType        36
        bDescriptorSubtype      5 (PROCESSING_UNIT)
      Warning: Descriptor too short
        bUnitID                 2
        bSourceID               1
        wMaxMultiplier          0
        bControlSize            2
        bmControls     0x0000157f
          Brightness
          Contrast
          Hue
          Saturation
          Sharpness
          Gamma
          White Balance Temperature
          Backlight Compensation
          Power Line Frequency
          White Balance Temperature, Auto
        iProcessing             0
        bmVideoStandards     0x 9
          None
          SECAM - 625/50
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             3
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               4
        iTerminal               0
        bLength                27
        bDescriptorType        36
        bDescriptorSubtype      6 (EXTENSION_UNIT)
        bUnitID                 4
        guidExtensionCode         {8ca72912-b447-9440-b0ce-db07386fb938}
        bNumControl             2
        bNrPins                 1
        baSourceID( 0)          2
        bControlSize            2
        bmControls( 0)       0x00
        bmControls( 1)       0x06
        iExtension              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               6
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Video Streaming
      iInterface              0
      VideoStreaming Interface Descriptor:
        bLength                            15
        bDescriptorType                    36
        bDescriptorSubtype                  1 (INPUT_HEADER)
        bNumFormats                         2
        wTotalLength                      229
        bEndPointAddress                  129
        bmInfo                              0
        bTerminalLink                       3
        bStillCaptureMethod                 2
        bTriggerSupport                     1
        bTriggerUsage                       0
        bControlSize                        1
        bmaControls( 0)                    27
        bmaControls( 1)                    27
        bLength                            27
        bDescriptorType                    36
        bDescriptorSubtype                  4 (FORMAT_UNCOMPRESSED)
        bFormatIndex                        1
        bNumFrameDescriptors                2
        guidFormat                            {59555932-0000-1000-8000-00aa00389b71}
        bBitsPerPixel                      16
        bDefaultFrameIndex                  1
        bAspectRatioX                       0
        bAspectRatioY                       0
        bmInterlaceFlags                 0x00
          Interlaced stream or variable: No
          Fields per frame: 2 fields
          Field 1 first: No
          Field pattern: Field 1 only
          bCopyProtect                      0
        bLength                            30
        bDescriptorType                    36
        bDescriptorSubtype                  5 (FRAME_UNCOMPRESSED)
        bFrameIndex                         1
        bmCapabilities                   0x00
          Still image unsupported
        wWidth                            640
        wHeight                           480
        dwMinBitRate                147456000
        dwMaxBitRate                147456000
        dwMaxVideoFrameBufferSize      614400
        dwDefaultFrameInterval         333333
        bFrameIntervalType                  1
        dwFrameInterval( 0)            333333
        bLength                            30
        bDescriptorType                    36
        bFrameIndex                         2
        bmCapabilities                   0x00
        wWidth                            320
        wHeight                           240
        dwMinBitRate                 73728000
        dwMaxBitRate                 73728000
        dwMaxVideoFrameBufferSize      153600
        dwDefaultFrameInterval         166666
        dwFrameInterval( 0)            166666
        bLength                            14
        bDescriptorType                    36
        bDescriptorSubtype                  3 (STILL_IMAGE_FRAME)
        bEndpointAddress                    0
        bNumImageSizePatterns               2
        wWidth( 0)                        640
        wHeight( 0)                       480
        wWidth( 1)                        320
        wHeight( 1)                       240
        bNumCompressionPatterns             2
        bLength                             6
        bDescriptorType                    36
        bDescriptorSubtype                 13 (COLORFORMAT)
        bColorPrimaries                     1 (BT.709,sRGB)
        bTransferCharacteristics            1 (BT.709)
        bMatrixCoefficients                 4 (SMPTE 170M (BT.601))
        bLength                            27
        bDescriptorType                    36
        bFormatIndex                        2
        bBitsPerPixel                      16
        bAspectRatioX                       0
        bAspectRatioY                       0
          Field 1 first: No
          bCopyProtect                      0
        bLength                            30
        bDescriptorType                    36
        bFrameIndex                         1
        bmCapabilities                   0x00
        wWidth                            640
        wHeight                           480
        bLength                            30
        bDescriptorType                    36
        bFrameIndex                         2
        bmCapabilities                   0x00
        wWidth                            320
        wHeight                           240
        bLength                            14
        bDescriptorType                    36
        bEndpointAddress                    0
        wWidth( 0)                        640
        wHeight( 0)                       480
        wWidth( 1)                        320
        wHeight( 1)                       240
        bLength                             6
        bDescriptorType                    36
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x0080  1x 128 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0400  1x 1024 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0b00  2x 768 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0c00  2x 1024 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       6
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1380  3x 896 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       7
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1400  3x 1024 bytes
        bInterval               1
Yea, I think my camera is USB2.0 !
Yes, on USB3 there is a fairly obvious section at the end of the listing like this:
SuperSpeed USB Device Capability:
…so this is indeed a USB2 camera.
