Running newer kernels on Tegra 30
I see Linux for Tegra Cardhu uses the 3.1.10 kernel. Is it possible to run a newer kernel (up to 3.16) on Tegra 30?
Thanks in advance
I think it depends on which hardware has this. There are chips surrounding the actual tegra3, some of which might use nVidia firmware or custom features. I have some development going on for a Toradex variant of Tegra 30, but have not tried a new kernel. Even L4T would require modification to run on this. Well, the short answer is that likely another kernel will work, but require adjustments.
