Running NVIDIA GLM-5.2-NVFP4 on 8xB200 GPUs with vllm
Hello everyone,
I recently tested nvidia/GLM-5.2-NVFP4 on an 8× NVIDIA Blackwell B200 system using the latest version of vllm. Below are the launch commands along with benchmark results for three different workloads: prompt-heavy, decode-heavy, and balanced
Serving the Model
vllm serve nvidia/GLM-5.2-NVFP4 \
    --tensor-parallel-size 8 \
    --enable-expert-parallel \
    --trust-remote-code \
    --reasoning-parser glm45 \
    --tool-call-parser glm47 \
    --enable-auto-tool-choice \
    --kv-cache-dtype fp8_e4m3 \
    --host 0.0.0.0 --port 8000
Prompt-heavy
vllm bench serve \
  --model nvidia/GLM-5.2-NVFP4 \
  --dataset-name random \
  --random-input-len 8000 \
  --random-output-len 1000 \
  --request-rate 10000 \
  --num-prompts 16 \
  --ignore-eos
Output:
============ Serving Benchmark Result ============
Successful requests:                     16
Failed requests:                         0
Request rate configured (RPS):           10000.00
Benchmark duration (s):                  20.24
Total input tokens:                      128000
Total generated tokens:                  16000
Request throughput (req/s):              0.79
Output token throughput (tok/s):         790.40
Peak output token throughput (tok/s):    1216.00
Peak concurrent requests:                16.00
Total token throughput (tok/s):          7113.59
---------------Time to First Token----------------
Mean TTFT (ms):                          3577.88
Median TTFT (ms):                        3538.65
P99 TTFT (ms):                           6658.12
-----Time per Output Token (excl. 1st token)------
Mean TPOT (ms):                          16.58
Median TPOT (ms):                        16.63
P99 TPOT (ms):                           19.48
---------------Inter-token Latency----------------
Mean ITL (ms):                           16.58
Median ITL (ms):                         13.50
P99 ITL (ms):                            23.35
Decode-heavy
vllm bench serve \
  --random-input-len 1000 \
  --random-output-len 8000 \
  --num-prompts 16 \
  --ignore-eos
Output:
Failed requests:                         0
Benchmark duration (s):                  108.88
Total input tokens:                      16000
Total generated tokens:                  128000
Request throughput (req/s):              0.15
Output token throughput (tok/s):         1175.58
Peak output token throughput (tok/s):    1248.00
Total token throughput (tok/s):          1322.52
Mean TTFT (ms):                          510.68
Median TTFT (ms):                        534.91
P99 TTFT (ms):                           536.94
Mean TPOT (ms):                          13.55
Median TPOT (ms):                        13.54
P99 TPOT (ms):                           13.58
Mean ITL (ms):                           13.55
Median ITL (ms):                         13.58
P99 ITL (ms):                            14.35
3. Balanced
vllm bench serve \
  --num-prompts 16 \
  --ignore-eos
Output:
Failed requests:                         0
Benchmark duration (s):                  13.79
Request throughput (req/s):              1.16
Output token throughput (tok/s):         1160.19
Total token throughput (tok/s):          2320.38
Mean TTFT (ms):                          582.37
Median TTFT (ms):                        610.28
P99 TTFT (ms):                           612.51
Mean TPOT (ms):                          13.21
Median TPOT (ms):                        13.19
P99 TPOT (ms):                           13.54
Mean ITL (ms):                           13.21
Median ITL (ms):                         13.23
P99 ITL (ms):                            13.89
Testing dSpark Speculative Decoding
    --spec-model RedHatAI/GLM-5.2-speculator.dspark \
    --spec-method dspark \
    --spec-tokens 7 \
At the moment, I have not yet managed to get the dSpark speculator working successfully. I’m continuing to investigate whether this is related to model compatibility, the current vllm implementation, or another configuration issue.
We tried with SGLang and got slightly higher throughput.
On balanced
The serving command was:
vllm serve GLM-5.2-NVFP4
–served-model-name glm-5.2-nvfp4
–tensor-parallel-size 8
–enable-expert-parallel
–reasoning-parser glm45
–tool-call-parser glm47
–enable-auto-tool-choice
–kv-cache-dtype fp8_e4m3
–max-model-len 131072
–max-num-seqs 256
–max-num-batched-tokens 16384
–gpu-memory-utilization 0.90
