Following this post I used the following items, in order to try odmfuse:
secureboot_R32.4.3_aarch64.tbz2
- the patched version of
tegraparser_v2
provided in the linked post
But the script failed with an error.
$ sudo ./odmfuse.sh -c NS -i 0x18 jetson-tx2-4GB
./tegraflash.py --chip 0x18 --applet "/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0027 ] Generating RCM messages
[ 0.0036 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0045 ] RCM 0 is saved as rcm_0.rcm
[ 0.0050 ] RCM 1 is saved as rcm_1.rcm
[ 0.0050 ] List of rcm files are saved in rcm_list.xml
[ 0.0050 ]
[ 0.0050 ] Signing RCM messages
[ 0.0058 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0065 ] Assuming zero filled SBK key
[ 0.0093 ]
[ 0.0093 ] Copying signature to RCM mesages
[ 0.0101 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0112 ]
[ 0.0112 ] Boot Rom communication
[ 0.0119 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0127 ] RCM version 0X180001
[ 0.0139 ] Boot Rom communication completed
[ 1.0211 ]
[ 2.0254 ] tegrarcm_v2 --isapplet
[ 2.0280 ] Applet version 01.00.0000
[ 2.0471 ]
[ 2.0500 ] Retrieving EEPROM data
[ 2.0502 ] tegrarcm_v2 --oem platformdetails eeprom cvm /media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0526 ] Applet version 01.00.0000
[ 2.0877 ] Saved platform info in /media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1616 ]
Board ID(3489) version(300) sku(0888) revision(H.0)
copying sdram_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/P3489_Sku888_4GB_Hynix_4GB_lpddr4_204Mhz_P138_A02_l4t.cfg)... done.
copying misc_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg)... done.
copying scr_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying pmc_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3489-1000-a00.cfg)... done.
copying pmic_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-lightning-p3489-1000-a00.cfg)... done.
copying br_cmd_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3489-1000-a00.cfg)... done.
copying prod_config(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-storm-p3489-1000-a00.cfg)... done.
copying dev_params(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing mb2_bootloader(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mts_preboot(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts_bootpack(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
copying bootloader_dtb(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3489-0888-a00-00-base.dtb)... done.
Existing bpmp_fw(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpmp_fw_dtb(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-lightning-p3489-a00-00-te770m.dtb)... done.
Existing tlk(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eks(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/eks.img) reused.
Existing mb1file(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing spefile(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/spe.bin) reused.
copying tegraboot(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing tbcfile(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/cboot.bin) reused.
Existing scefile(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
copying wb0boot(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
done.
Existing cfg(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/flash.xml) reused.
Existing bl(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing applet(/media/ofirm/Ofir_1TB10/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2_4GB/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
*** Generating fuse configuration ... done.
*** Start fusing ...
./tegraflash.py --sdram_config P3489_Sku888_4GB_Hynix_4GB_lpddr4_204Mhz_P138_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3489-1000-a00.cfg --pmic_config tegra186-mb1-bct-pmic-lightning-p3489-1000-a00.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3489-1000-a00.cfg --prod_config tegra186-mb1-bct-prod-storm-p3489-1000-a00.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bootloader_dtb tegra186-quill-p3489-0888-a00-00-base.dtb; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-lightning-p3489-a00-00-te770m.dtb; tlk tos-trusty.img; eks eks.img" --cfg flash.xml --bl nvtboot_recovery_cpu.bin --odmdata 0x1090000 --chip 0x18 --applet mb1_recovery_prod.bin --cmd "burnfuses odmfuse_pkc.xml" --skipuid
version 1.0.0
[ 0.0374 ] Burning fuses
[ 0.0375 ] Generating RCM messages
[ 0.0396 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0414 ] RCM 0 is saved as rcm_0.rcm
[ 0.0422 ] RCM 1 is saved as rcm_1.rcm
[ 0.0422 ] List of rcm files are saved in rcm_list.xml
[ 0.0422 ]
[ 0.0422 ] Signing RCM messages
[ 0.0442 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0461 ] Assuming zero filled SBK key
[ 0.0533 ]
[ 0.0534 ] Copying signature to RCM mesages
[ 0.0554 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0586 ]
[ 0.0586 ] Boot Rom communication
[ 0.0607 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0629 ] Boot Rom communication failed
[ 5.3142 ]
[ 5.3143 ] Send tboot failed. Bootrom is likely not running, try to detect whether mb1/mb2/cpubl is running.
[ 6.3182 ] tegrarcm_v2 --isapplet
[ 6.3204 ] Applet version 01.00.0000
[ 6.3362 ]
[ 6.3411 ] Parsing fuse info as per xml file
[ 6.3437 ] tegraparser_v2 --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
[ 6.3460 ] MagicId=0x45535546 version=0x1
[ 6.3464 ] node: name=JtagDisable size=4
[ 6.3464 ] value=0x1
[ 6.3464 ] Not a valid Fuse entry : PkcDisable
[ 6.3464 ] Failed to generate fuse info, ErrNum=4
[ 6.3464 ]
Error: Return value 4
Command tegraparser_v2 --fuse_info odmfuse_pkc.xml blow_fuse_data.bin
failed.
Is it a bug/config issue? what am I missing?
