/home/casperl/.nvidia-omniverse/logs/Kit/Create/2021.1/kit_20210721_151801.log:
2021-07-21 13:18:01 [0ms] [Info] [carb] Registered plugin: carb.profiler-cpu.plugin (interfaces: [carb::profiler::IProfileMonitor v0.3],[carb::profiler::IProfiler v1.1],[carb::tasking::IFiberEvents v0.1]) (impl: carb.profiler-cpu.plugin)
2021-07-21 13:18:01 [3ms] [Info] [carb] Initializing plugin: carb.profiler-cpu.plugin (interfaces: [carb::profiler::IProfileMonitor v0.3],[carb::profiler::IProfiler v1.1],[carb::tasking::IFiberEvents v0.1]) (impl: carb.profiler-cpu.plugin)
2021-07-21 13:18:01 [3ms] [Info] [omni.kit.app.plugin] Loaded profiler: "carb.profiler-cpu.plugin". From: "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/libcarb.profiler-cpu.plugin.so"
2021-07-21 13:18:01 [3ms] [Info] [omni.kit.app.plugin] App Name: 'Create', App Version: '2021.1.1-rc.1+2021.1..1062.c3c75ff4.gitlab', Kit Version: '100.3.528-c8003e0d-release'
2021-07-21 13:18:01 [3ms] [Info] [omni.kit.app.plugin] Tokens:
"app_documents": "/home/casperl/Documents/Kit/apps/Create",
"documents": "/home/casperl/Documents/Kit/apps/Create",
"cache": "/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release",
"shared_documents": "/home/casperl/Documents/Kit/shared",
"logs": "/home/casperl/.nvidia-omniverse/logs/Kit/Create/2021.1",
"omni_cache": "/home/casperl/.cache/ov",
"omni_logs": "/home/casperl/.nvidia-omniverse/logs",
"omni_data": "/home/casperl/.local/share/ov/data",
"start_timestamp": "20210721_151801",
"rtx_path": "plugins/rtx",
"shell_ext": ".sh",
"xrresources": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/xrresources",
"lib_ext": ".so",
"resources": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/resources",
"drive": "/",
"local-config-path": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release",
"bindings_ext": ".so",
"appcache": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/cache/Kit/100.3/528-c8003e0d-release",
"materials": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/resources/materials",
"exe-path": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release",
"exe-filename": "kit",
"omni_documents": "/home/casperl/Documents",
"custom-config-path": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release",
"data": "/home/casperl/.local/share/ov/data/Kit/Create/2021.1",
"platform": "linux-x86_64",
"app": "./apps/../apps",
"lib_prefix": "lib",
"gfx_path": "plugins/carb_gfx",
"cli-config-path": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release",
"exe_ext": "",
"glyphs": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/resources/glyphs",
"xrcontrollers": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/xrresources/models/controllers",
"temp": "/tmp/carb.4WRWVU",
"fonts": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/resources/fonts",
"icons": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/resources/icons",
"sounds": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/resources/sounds",
"kit": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release",
"models": "/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/resources/models",
"config": "release"
2021-07-21 13:18:01 [3ms] [Info] [omni.kit.app.plugin] Applied configs: [/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/config/kit-core.json, ./apps/../apps/omni.create.next.kit, /home/casperl/.nvidia-omniverse/config/privacy.toml, ]
2021-07-21 13:18:01 [3ms] [Info] [omni.kit.app.plugin] Async hydra rendering disabled due to Vulkan enabled
2021-07-21 13:18:01 [3ms] [Info] [omni.kit.app.plugin] [0.030s] Loading user config located at: '/home/casperl/.local/share/ov/data/Kit/Create/2021.1/user.config.json'
2021-07-21 13:18:01 [3ms] [Info] [carb] file '/home/casperl/.local/share/ov/data/Kit/Create/2021.1/user.config.json' does not exist
2021-07-21 13:18:01 [3ms] [Info] [carb] Initializing plugin: carb.scripting-python.plugin (interfaces: [carb::scripting::IScripting v1.0]) (impl: carb.scripting-python.plugin)
2021-07-21 13:18:01 [3ms] [Info] [carb.scripting-python.plugin] Attempting to initialize Python interpreter. Failure of doing it will lead to the termination of the application.
2021-07-21 13:18:01 [16ms] [Info] [carb.scripting-python.plugin] Python interpreter was successfully initialized.
2021-07-21 13:18:01 [97ms] [Info] [carb] Initializing plugin: omni.ext.plugin (interfaces: [omni::ext::IExtensions v1.0]) (impl: omni.ext.plugin)
2021-07-21 13:18:01 [98ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [104ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [104ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [105ms] [Info] [omni.ext.plugin] [ext: omni.create.next-2021.1.0] registered
2021-07-21 13:18:01 [105ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [105ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [105ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [105ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/extsPhysics' (path type: 0)
2021-07-21 13:18:01 [106ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [106ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/extsPhysics' (path type: 0)
2021-07-21 13:18:01 [106ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts' (path type: 0)
2021-07-21 13:18:01 [106ms] [Info] [omni.ext.plugin] [ext: carb.audio-0.1.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.ansel-0.0.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.appwindow-0.1.0-rc1] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.assets-0.0.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.audioplayer-0.2.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.audiorecorder-0.1.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.client-0.1.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.convexdecomposition-1.1.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.debugdraw-0.0.0] registered
2021-07-21 13:18:01 [107ms] [Info] [omni.ext.plugin] [ext: omni.example.dependent_ext-0.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.greet-0.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.hello-0.2.2] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.menu_hook-0.1.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.multi_app_window-0.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.native_ext-0.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.splash-1.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.standalone-0.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.streamclient-mini-0.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.ui-1.0.0] registered
2021-07-21 13:18:01 [108ms] [Info] [omni.ext.plugin] [ext: omni.example.workspace-1.0.0] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.flowusd-0.1.0] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.geometry-1.1.0-5.1] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.graph.core-0.0.0] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.graph.examples.cpp-0.0.0] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.graph.examples.python-0.0.0] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.graph.tools-0.0.0] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.graph.ui-0.0.0] registered
2021-07-21 13:18:01 [109ms] [Info] [omni.ext.plugin] [ext: omni.hydra.iray-0.1.0] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.hydra.pxr-1.0.0] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.hydra.rtx-0.1.0] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.iray.render_settings-0.1.0] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.iray.settings.core-0.6.2] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.kit.agent-0.1.0] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.kit.agent.watcher-0.1.0] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.kit.asset_converter-1.0.1] registered
2021-07-21 13:18:01 [110ms] [Info] [omni.ext.plugin] [ext: omni.kit.async_engine-0.0.0] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.capture-0.3.2] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.commands-0.0.0] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.console-0.0.0] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.context_menu-1.0.5] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.controlport-1.0.0] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.debug.utils-0.1.0] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.default-0.0.0] registered
2021-07-21 13:18:01 [111ms] [Info] [omni.ext.plugin] [ext: omni.kit.editor-full-0.0.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.editor-mini-0.0.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.example.toolbar_button-0.1.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.filebrowser_column.acl-1.0.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.filebrowser_column.tags-1.0.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.livestream.core-0.0.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.livestream.native-0.0.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.loop-default-0.1.0] registered
2021-07-21 13:18:01 [112ms] [Info] [omni.ext.plugin] [ext: omni.kit.mainwindow-0.0.0] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.material.library-1.0.3] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.menu.file-1.0.1] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.menu.utils-1.0.1] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.pip_archive-0.0.0] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.pipapi-0.0.0] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.primRandomColor-0.0.0] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.primitive.mesh-1.0.0] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.procedural.mesh-0.0.0] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.profile_python-0.0.0] registered
2021-07-21 13:18:01 [113ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.audio-1.0.3] registered
2021-07-21 13:18:01 [114ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.bundle-1.2.2] registered
2021-07-21 13:18:01 [114ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.camera-1.0.2] registered
2021-07-21 13:18:01 [114ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.geometry-1.0.6] registered
2021-07-21 13:18:01 [114ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.layer-1.0.1] registered
2021-07-21 13:18:01 [114ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.light-1.0.2] registered
2021-07-21 13:18:01 [114ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.material-1.4.1] registered
2021-07-21 13:18:01 [114ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.physx-0.1.0] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.tagging-1.0.1] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.transform-1.0.2] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.property.usd-3.4.2] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.quicklayout-1.0.0] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.registry.nucleus-0.0.0] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.capture-0.0.0] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] registered
2021-07-21 13:18:01 [115ms] [Info] [omni.ext.plugin] [ext: omni.kit.rpc-0.1.0] registered
2021-07-21 13:18:01 [116ms] [Info] [omni.ext.plugin] [ext: omni.kit.search.service-0.1.0] registered
2021-07-21 13:18:01 [116ms] [Info] [omni.ext.plugin] [ext: omni.kit.search_core-1.0.0] registered
2021-07-21 13:18:01 [116ms] [Info] [omni.ext.plugin] [ext: omni.kit.search_example-1.0.0] registered
2021-07-21 13:18:01 [116ms] [Info] [omni.ext.plugin] [ext: omni.kit.selection-0.0.0] registered
2021-07-21 13:18:01 [116ms] [Info] [omni.ext.plugin] [ext: omni.kit.skelvis-1.0.0] registered
2021-07-21 13:18:01 [116ms] [Info] [omni.ext.plugin] [ext: omni.kit.splash-0.1.0] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.stage_templates-1.0.3] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.tagging-0.1.0] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.test-0.0.0] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.images-0.1.0] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.usd-0.3.0] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.tool.asset_importer-2.0.0] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.tool.collect-2.0.0] registered
2021-07-21 13:18:01 [117ms] [Info] [omni.ext.plugin] [ext: omni.kit.uiapp-0.0.0] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.usd_undo-0.0.0] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.usda_edit-1.1.7] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.welcome-1.0.0] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.browser_bar-2.0.0] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.fast_search-0.2.0] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.filebrowser-2.0.4] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.graph-1.0.2] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.imageview-1.0.0] registered
2021-07-21 13:18:01 [118ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.layers-0.3.1] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.live-0.0.0] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.path_field-2.0.0] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.stage-2.3.3] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.stage_icons-1.0.0] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.about-0.2.1] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.audioplayer-1.0.1] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.audiorecorder-1.0.1] registered
2021-07-21 13:18:01 [119ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.commands-0.1.0] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.console-0.0.0] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.content_browser-2.0.3] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.copy_service-1.0.1] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.cursor-1.0.0] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.details-1.0.0] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.extensions-1.0.2] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.file-1.0.1] registered
2021-07-21 13:18:01 [120ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.filepicker-2.0.3] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.hydra_viewport-0.0.0] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.images-0.0.0] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.imageviewer-1.0.3] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.material_graph-1.0.2] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.material_swap-1.0.1] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.movie_maker-0.3.1] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.popup_dialog-1.0.0] registered
2021-07-21 13:18:01 [121ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.preferences-1.0.1] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.profiler-1.0.0] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.property-0.0.0] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.provide_feedback-0.1.0] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.render_farm-0.2.0] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.script_editor-1.5.0] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.splash-0.0.0] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.splash_close_example-0.0.0] registered
2021-07-21 13:18:01 [122ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stage-2.3.2] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stageviewer-1.0.1] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stats-0.0.0] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.status_bar-0.0.0] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.stream_viewport-0.0.0] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.tests-0.1.0] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.title-1.0.0] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.toolbar-0.0.0] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.transform-0.0.0] registered
2021-07-21 13:18:01 [123ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.usd_paths-1.0.3] registered
2021-07-21 13:18:01 [124ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] registered
2021-07-21 13:18:01 [124ms] [Info] [omni.ext.plugin] [ext: omni.kit.xr-1.0.0] registered
2021-07-21 13:18:01 [124ms] [Info] [omni.ext.plugin] [ext: omni.kit.xr.profile.tabletar-1.0.0] registered
2021-07-21 13:18:01 [124ms] [Info] [omni.ext.plugin] [ext: omni.kvdb-0.0.0] registered
2021-07-21 13:18:01 [124ms] [Info] [omni.ext.plugin] [ext: omni.localcache-0.0.0] registered
2021-07-21 13:18:01 [124ms] [Info] [omni.ext.plugin] [ext: omni.physx-1.1.0-5.1] registered
2021-07-21 13:18:01 [124ms] [Info] [omni.ext.plugin] [ext: omni.physx.bundle-1.1.0-5.1] registered
2021-07-21 13:18:01 [125ms] [Info] [omni.ext.plugin] [ext: omni.physx.cct-1.1.0-5.1] registered
2021-07-21 13:18:01 [125ms] [Info] [omni.ext.plugin] [ext: omni.physx.computegraph-1.1.0-5.1] registered
2021-07-21 13:18:01 [125ms] [Info] [omni.ext.plugin] [ext: omni.physx.internal-1.1.0-5.1] registered
2021-07-21 13:18:01 [125ms] [Info] [omni.ext.plugin] [ext: omni.physx.tests-1.0.0] registered
2021-07-21 13:18:01 [125ms] [Info] [omni.ext.plugin] [ext: omni.physx.ui-1.1.0-5.1] registered
2021-07-21 13:18:01 [125ms] [Info] [omni.ext.plugin] [ext: omni.physx.vehicle-1.1.0-5.1] registered
2021-07-21 13:18:01 [125ms] [Info] [omni.ext.plugin] [ext: omni.physx.vehicle.tests-0.1.0] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.physx.zerogravity-1.1.0-5.1] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.renderer-rtx-0.0.0] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.renderer-ui-0.0.0] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.rtx.settings.core-0.5.4] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.rtx.window.settings-0.6.0] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.services.appwindow-0.1.0] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.services.client-0.2.0] registered
2021-07-21 13:18:01 [126ms] [Info] [omni.ext.plugin] [ext: omni.services.core-1.1.0] registered
2021-07-21 13:18:01 [127ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.base-1.0.0] registered
2021-07-21 13:18:01 [127ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.config-1.0.0] registered
2021-07-21 13:18:01 [127ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.log-1.0.0] registered
2021-07-21 13:18:01 [127ms] [Info] [omni.ext.plugin] [ext: omni.services.facilities.workqueue-1.0.0] registered
2021-07-21 13:18:01 [127ms] [Info] [omni.ext.plugin] [ext: omni.services.instances-0.1.0] registered
2021-07-21 13:18:01 [127ms] [Info] [omni.ext.plugin] [ext: omni.services.mdl_preview-0.1.1] registered
2021-07-21 13:18:01 [127ms] [Info] [omni.ext.plugin] [ext: omni.services.registry-1.0.0] registered
2021-07-21 13:18:01 [128ms] [Info] [omni.ext.plugin] [ext: omni.services.thumbnails.images-1.1.0] registered
2021-07-21 13:18:01 [128ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.base-1.0.0] registered
2021-07-21 13:18:01 [128ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.http_async-1.0.0] registered
2021-07-21 13:18:01 [128ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.https_async-1.0.0] registered
2021-07-21 13:18:01 [128ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.client.idl_http_async-0.1.0] registered
2021-07-21 13:18:01 [128ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.base-1.0.0] registered
2021-07-21 13:18:01 [129ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.http-1.0.0] registered
2021-07-21 13:18:01 [129ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.https-1.0.0] registered
2021-07-21 13:18:01 [129ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.tcp_socket-1.0.0] registered
2021-07-21 13:18:01 [129ms] [Info] [omni.ext.plugin] [ext: omni.services.usd-1.0.0] registered
2021-07-21 13:18:01 [130ms] [Info] [omni.ext.plugin] [ext: omni.stats-0.0.0] registered
2021-07-21 13:18:01 [130ms] [Info] [omni.ext.plugin] [ext: omni.syntheticdata-0.0.0] registered
2021-07-21 13:18:01 [130ms] [Info] [omni.ext.plugin] [ext: omni.timeline-0.0.0] registered
2021-07-21 13:18:01 [130ms] [Info] [omni.ext.plugin] [ext: omni.ui-2.1.2] registered
2021-07-21 13:18:01 [130ms] [Info] [omni.ext.plugin] [ext: omni.usd-0.1.8] registered
2021-07-21 13:18:01 [130ms] [Info] [omni.ext.plugin] [ext: omni.usdphysics-1.1.0] registered
2021-07-21 13:18:01 [130ms] [Info] [omni.ext.plugin] [ext: omni.usdphysics.tests-1.1.0] registered
2021-07-21 13:18:01 [131ms] [Info] [omni.ext.plugin] [ext: omni.videoencoding-0.0.0] registered
2021-07-21 13:18:01 [131ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [131ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [131ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [131ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/extsPhysics' (path type: 0)
2021-07-21 13:18:01 [131ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts' (path type: 0)
2021-07-21 13:18:01 [132ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [132ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/apps/Create/exts' (path type: 0)
2021-07-21 13:18:01 [132ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [132ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [132ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/extsPhysics' (path type: 0)
2021-07-21 13:18:01 [132ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts' (path type: 0)
2021-07-21 13:18:01 [133ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [133ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/apps/Create/exts' (path type: 0)
2021-07-21 13:18:01 [133ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/shared/exts' (path type: 0)
2021-07-21 13:18:01 [133ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [133ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/experiences/kit' (path type: 0)
2021-07-21 13:18:01 [133ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [134ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/extsPhysics' (path type: 0)
2021-07-21 13:18:01 [134ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts' (path type: 0)
2021-07-21 13:18:01 [134ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [134ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/apps/Create/exts' (path type: 0)
2021-07-21 13:18:01 [134ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/shared/exts' (path type: 0)
2021-07-21 13:18:01 [135ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [135ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/experiences/kit' (path type: 0)
2021-07-21 13:18:01 [135ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [135ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/extsPhysics' (path type: 0)
2021-07-21 13:18:01 [135ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts' (path type: 0)
2021-07-21 13:18:01 [136ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [136ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [136ms] [Info] [omni.ext.plugin] [ext: omni.blast-0.7.2-kit_100.3] registered
2021-07-21 13:18:01 [136ms] [Info] [omni.ext.plugin] [ext: omni.create.app.launcher-1.0.0] registered
2021-07-21 13:18:01 [136ms] [Info] [omni.ext.plugin] [ext: omni.create.app.setup-0.0.0] registered
2021-07-21 13:18:01 [136ms] [Info] [omni.ext.plugin] [ext: omni.create.splash-1.0.0] registered
2021-07-21 13:18:01 [136ms] [Info] [omni.ext.plugin] [ext: omni.kit.tool.asset_exporter-1.0.2] registered
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] [ext: omni.kit.tools.mergemesh-0.1.3] registered
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] [ext: omni.kit.tools.surface_instancer-0.1.12] registered
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/apps/Create/exts' (path type: 0)
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/shared/exts' (path type: 0)
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.cache/ov/Kit/100.3/528-c8003e0d-release/exts' (path type: 1)
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/experiences/kit' (path type: 0)
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [137ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/extsPhysics' (path type: 0)
2021-07-21 13:18:01 [138ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts' (path type: 0)
2021-07-21 13:18:01 [138ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps' (path type: 0)
2021-07-21 13:18:01 [138ms] [Info] [omni.ext.plugin] [ext: omni.app.uidoc-2021.1.0] registered
2021-07-21 13:18:01 [139ms] [Info] [omni.ext.plugin] [ext: omni.create.app.splash-2021.1.0] registered
2021-07-21 13:18:01 [139ms] [Info] [omni.ext.plugin] [ext: omni.create.ar-2021.1.0] registered
2021-07-21 13:18:01 [139ms] [Info] [omni.ext.plugin] [ext: omni.create.hdstorm-2021.1.0] registered
2021-07-21 13:18:01 [139ms] [Info] [omni.ext.plugin] [ext: omni.create.iray-2021.1.0] registered
2021-07-21 13:18:01 [140ms] [Info] [omni.ext.plugin] [ext: omni.create-2021.1.0] registered
2021-07-21 13:18:01 [140ms] [Info] [omni.ext.plugin] [ext: omni.create.launcher-2021.1.0] registered
2021-07-21 13:18:01 [140ms] [Info] [omni.ext.plugin] [ext: omni.create.next.headless-2021.1.0] registered
2021-07-21 13:18:01 [140ms] [Info] [omni.ext.plugin] [ext: omni.create.testing-2021.1.0] registered
2021-07-21 13:18:01 [140ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/apps/omni.create.next.kit' (path type: 2)
2021-07-21 13:18:01 [140ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/linux-x86_64/release/exts' (path type: 0)
2021-07-21 13:18:01 [141ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/apps/Create/exts' (path type: 0)
2021-07-21 13:18:01 [141ms] [Info] [omni.ext.plugin] Searching for extensions in: '/home/casperl/Documents/Kit/shared/exts' (path type: 0)
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.create.next-2021.1.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.usd-0.3.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.tool.asset_importer-2.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.tool.collect-2.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.layers-0.3.1] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.console-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.videoencoding-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.script_editor-1.5.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.extensions-1.0.2] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.content_browser-2.0.3] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.property-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.file-1.0.1] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.thumbnails.images-0.1.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.widget.stage-2.3.3] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.filepicker-2.0.3] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.mainwindow-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.appwindow-0.1.0-rc1] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.services.transport.server.http-1.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.services.registry-1.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.client-0.1.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.usd-0.1.8] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.pipapi-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.test-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.loop-default-0.1.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.splash-0.1.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.async_engine-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.splash-0.0.0] applying settings
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.assets-0.0.0] (order: 0) Triggered by: omni.client-0.1.0, omni.kit.renderer.core-0.0.0, omni.kit.window.splash-0.0.0, omni.renderer-rtx-0.0.0, omni.usd-0.1.8
2021-07-21 13:18:01 [143ms] [Info] [omni.kit.app.plugin] [0.170s] [ext: omni.assets-0.0.0] startup
2021-07-21 13:18:01 [143ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.assets/bin' Filename: '*.plugin'
2021-07-21 13:18:01 [144ms] [Info] [carb] Registered plugin: carb.tasking.plugin (interfaces: [carb::tasking::ITasking v1.1],[carb::tasking::IThreadPool v0.1]) (impl: carb.tasking.plugin)
2021-07-21 13:18:01 [145ms] [Info] [carb] Registered plugin: carb.imaging.plugin (interfaces: [carb::imaging::IImaging v0.4]) (impl: carb.imaging.plugin)
2021-07-21 13:18:01 [145ms] [Info] [carb] Registered plugin: carb.datasource-file.plugin (interfaces: [carb::datasource::IDataSource v0.3]) (impl: carb.datasource-file.plugin)
2021-07-21 13:18:01 [146ms] [Info] [carb] Registered plugin: carb.assets.plugin (interfaces: [carb::assets::IAssets v0.1],[carb::assets::IAssetsBlob v0.1]) (impl: carb.assets.plugin)
2021-07-21 13:18:01 [146ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.window.splash-0.0.0] (order: -5000) Triggered by: omni.kit.splash-0.1.0
2021-07-21 13:18:01 [146ms] [Info] [omni.kit.app.plugin] [0.172s] [ext: omni.kit.window.splash-0.0.0] startup
2021-07-21 13:18:01 [146ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.kit.window.splash/bin' Filename: '*.plugin'
2021-07-21 13:18:01 [146ms] [Info] [carb] Registered plugin: omni.splash.plugin (interfaces: [omni::splash::ISplashScreen v0.1]) (impl: omni.splash.plugin)
2021-07-21 13:18:01 [146ms] [Info] [carb] Registered plugin: omni.kit.window.splash.ext.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.window.splash.ext.plugin)
2021-07-21 13:18:01 [146ms] [Info] [carb] Initializing plugin: omni.kit.window.splash.ext.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.window.splash.ext.plugin)
2021-07-21 13:18:01 [146ms] [Info] [omni.ext.plugin] [ext: omni.kit.window.splash-0.0.0] Starting ext::IExt in '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.kit.window.splash/bin/libomni.kit.window.splash.ext.plugin.so'
2021-07-21 13:18:01 [146ms] [Info] [carb] Initializing plugin: omni.splash.plugin (interfaces: [omni::splash::ISplashScreen v0.1]) (impl: omni.splash.plugin)
2021-07-21 13:18:01 [146ms] [Info] [carb] Initializing plugin: carb.imaging.plugin (interfaces: [carb::imaging::IImaging v0.4]) (impl: carb.imaging.plugin)
2021-07-21 13:18:01 [146ms] [Info] [carb] Initializing plugin: carb.assets.plugin (interfaces: [carb::assets::IAssets v0.1],[carb::assets::IAssetsBlob v0.1]) (impl: carb.assets.plugin)
2021-07-21 13:18:01 [146ms] [Info] [carb] Initializing plugin: carb.tasking.plugin (interfaces: [carb::tasking::ITasking v1.1],[carb::tasking::IThreadPool v0.1]) (impl: carb.tasking.plugin)
2021-07-21 13:18:01 [149ms] [Info] [carb] Initializing plugin: carb.datasource-file.plugin (interfaces: [carb::datasource::IDataSource v0.3]) (impl: carb.datasource-file.plugin)
2021-07-21 13:18:01 [162ms] [Info] [omni.splash.plugin] Converting splash image data format into eBGRA8_UNORM;
2021-07-21 13:18:01 [180ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.async_engine-0.0.0] (order: 0) Triggered by: omni.client-0.1.0, omni.kit.splash-0.1.0, omni.kit.test-0.0.0, omni.kit.window.extensions-1.0.2
2021-07-21 13:18:01 [180ms] [Info] [omni.kit.app.plugin] [0.207s] [ext: omni.kit.async_engine-0.0.0] startup
2021-07-21 13:18:01 [215ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.agent-0.1.0] (order: 0) Triggered by: omni.kit.splash-0.1.0, omni.kit.thumbnails.images-0.1.0
2021-07-21 13:18:01 [215ms] [Info] [omni.kit.app.plugin] [0.241s] [ext: omni.kit.agent-0.1.0] startup
2021-07-21 13:18:01 [221ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.splash-0.1.0] (order: -4000) Triggered by: omni.create.next-2021.1.0
2021-07-21 13:18:01 [221ms] [Info] [omni.kit.app.plugin] [0.248s] [ext: omni.kit.splash-0.1.0] startup
2021-07-21 13:18:01 [245ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.loop-default-0.1.0] (order: 0) Triggered by: omni.appwindow-0.1.0-rc1, omni.kit.test-0.0.0, omni.services.core-1.1.0
2021-07-21 13:18:01 [246ms] [Info] [omni.kit.app.plugin] [0.272s] [ext: omni.kit.loop-default-0.1.0] startup
2021-07-21 13:18:01 [246ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.kit.loop-default/bin' Filename: '*.plugin'
2021-07-21 13:18:01 [246ms] [Info] [carb] Registered plugin: omni.kit.loop-default.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.loop-default.plugin)
2021-07-21 13:18:01 [247ms] [Info] [carb] Initializing plugin: omni.kit.loop-default.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.loop-default.plugin)
2021-07-21 13:18:01 [247ms] [Info] [omni.ext.plugin] [ext: omni.kit.loop-default-0.1.0] Starting ext::IExt in '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.kit.loop-default/bin/libomni.kit.loop-default.plugin.so'
2021-07-21 13:18:01 [247ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.test-0.0.0] (order: 0) Triggered by: omni.client-0.1.0, omni.kit.commands-0.0.0, omni.kit.mainwindow-0.0.0, omni.kit.pipapi-0.0.0, omni.kit.selection-0.0.0, omni.kit.stage_templates-1.0.3, omni.kit.thumbnails.images-0.1.0, omni.kit.thumbnails.usd-0.3.0, omni.kit.usd_undo-0.0.0, omni.kit.widget.graph-1.0.2, omni.kit.widget.imageview-1.0.0, omni.kit.widget.stage-2.3.3, omni.kit.window.imageviewer-1.0.3, omni.services.client-0.2.0, omni.services.core-1.1.0, omni.services.facilities.base-1.0.0, omni.services.transport.client.base-1.0.0, omni.services.transport.client.http_async-1.0.0, omni.services.transport.server.base-1.0.0, omni.services.transport.server.http-1.0.0, omni.ui-2.1.2, omni.usd-0.1.8
2021-07-21 13:18:01 [247ms] [Info] [omni.kit.app.plugin] [0.273s] [ext: omni.kit.test-0.0.0] startup
2021-07-21 13:18:02 [270ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.pipapi-0.0.0] (order: -1000) Triggered by: omni.kit.pip_archive-0.0.0, omni.services.client-0.2.0, omni.ui-2.1.2
2021-07-21 13:18:02 [270ms] [Info] [omni.kit.app.plugin] [0.297s] [ext: omni.kit.pipapi-0.0.0] startup
2021-07-21 13:18:02 [279ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.pip_archive-0.0.0] (order: -1000) Triggered by: omni.kit.context_menu-1.0.5, omni.kit.search.service-0.1.0, omni.kit.tagging-0.1.0, omni.kit.window.file-1.0.1, omni.kit.window.filepicker-2.0.3, omni.services.client-0.2.0, omni.services.core-1.1.0, omni.services.registry-1.0.0, omni.services.transport.client.http_async-1.0.0
2021-07-21 13:18:02 [279ms] [Info] [omni.kit.app.plugin] [0.305s] [ext: omni.kit.pip_archive-0.0.0] startup
2021-07-21 13:18:02 [279ms] [Info] [carb.python] [omni.kit.pipapi] Add archive dir: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.kit.pip_archive/pip_archive'
2021-07-21 13:18:02 [287ms] [Info] [omni.ext.plugin] About to startup: [ext: carb.audio-0.1.0] (order: 0) Triggered by: omni.usd-0.1.8
2021-07-21 13:18:02 [287ms] [Info] [omni.kit.app.plugin] [0.314s] [ext: carb.audio-0.1.0] startup
2021-07-21 13:18:02 [287ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins' Filename: 'carb.audio-forge.plugin'
2021-07-21 13:18:02 [310ms] [Info] [carb] Registered plugin: carb.audio-forge.plugin (interfaces: [carb::audio::IAudioCapture v0.3],[carb::audio::IAudioData v0.6],[carb::audio::IAudioDevice v0.1],[carb::audio::IAudioGroup v0.1],[carb::audio::IAudioPlayback v0.5],[carb::audio::IAudioUtils v0.3]) (impl: carb.audio-forge.plugin)
2021-07-21 13:18:02 [310ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.commands-0.0.0] (order: 0) Triggered by: omni.convexdecomposition-1.1.0, omni.kit.material.library-1.0.3, omni.kit.property.layer-1.0.1, omni.kit.property.transform-1.0.2, omni.kit.property.usd-3.4.2, omni.kit.selection-0.0.0, omni.kit.stage_templates-1.0.3, omni.kit.window.extensions-1.0.2, omni.kit.window.toolbar-0.0.0, omni.kit.window.viewport-0.0.0, omni.rtx.settings.core-0.5.4, omni.rtx.window.settings-0.6.0, omni.usd-0.1.8
2021-07-21 13:18:02 [310ms] [Info] [omni.kit.app.plugin] [0.337s] [ext: omni.kit.commands-0.0.0] startup
2021-07-21 13:18:02 [325ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.timeline-0.0.0] (order: 0) Triggered by: omni.kit.capture-0.3.2, omni.kit.property.usd-3.4.2, omni.kit.window.movie_maker-0.3.1, omni.kit.window.toolbar-0.0.0, omni.kit.window.viewport-0.0.0, omni.physx.ui-1.1.0-5.1, omni.usd-0.1.8
2021-07-21 13:18:02 [325ms] [Info] [omni.kit.app.plugin] [0.352s] [ext: omni.timeline-0.0.0] startup
2021-07-21 13:18:02 [325ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.timeline/bin' Filename: '*.plugin'
2021-07-21 13:18:02 [325ms] [Info] [carb] Registered plugin: omni.timeline.plugin (interfaces: [omni::ext::IExt v0.1],[omni::timeline::ITimeline v0.1]) (impl: omni.timeline.plugin)
2021-07-21 13:18:02 [325ms] [Info] [carb] Initializing plugin: omni.timeline.plugin (interfaces: [omni::ext::IExt v0.1],[omni::timeline::ITimeline v0.1]) (impl: omni.timeline.plugin)
2021-07-21 13:18:02 [326ms] [Info] [omni.ext.plugin] [ext: omni.timeline-0.0.0] Starting ext::IExt in '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.timeline/bin/libomni.timeline.plugin.so'
2021-07-21 13:18:02 [330ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.services.facilities.base-1.0.0] (order: 0) Triggered by: omni.services.core-1.1.0, omni.services.registry-1.0.0
2021-07-21 13:18:02 [330ms] [Info] [omni.kit.app.plugin] [0.357s] [ext: omni.services.facilities.base-1.0.0] startup
2021-07-21 13:18:02 [336ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.usd-0.1.8] (order: 0) Triggered by: omni.client-0.1.0, omni.create.app.setup-0.0.0, omni.debugdraw-0.0.0, omni.kit.asset_converter-1.0.1, omni.kit.capture-0.3.2, omni.kit.context_menu-1.0.5, omni.kit.material.library-1.0.3, omni.kit.menu.file-1.0.1, omni.kit.primitive.mesh-1.0.0, omni.kit.property.audio-1.0.3, omni.kit.property.bundle-1.2.2, omni.kit.property.camera-1.0.2, omni.kit.property.geometry-1.0.6, omni.kit.property.layer-1.0.1, omni.kit.property.light-1.0.2, omni.kit.property.material-1.4.1, omni.kit.property.physx-0.1.0, omni.kit.property.tagging-1.0.1, omni.kit.property.transform-1.0.2, omni.kit.property.usd-3.4.2, omni.kit.stage_templates-1.0.3, omni.kit.thumbnails.usd-0.3.0, omni.kit.tool.asset_exporter-1.0.2, omni.kit.tool.asset_importer-2.0.0, omni.kit.tool.collect-2.0.0, omni.kit.widget.graph-1.0.2, omni.kit.widget.layers-0.3.1, omni.kit.widget.live-0.0.0, omni.kit.widget.stage-2.3.3, omni.kit.window.file-1.0.1, omni.kit.window.movie_maker-0.3.1, omni.kit.window.preferences-1.0.1, omni.kit.window.property-0.0.0, omni.kit.window.stage-2.3.2, omni.kit.window.status_bar-0.0.0, omni.kit.window.title-1.0.0, omni.kit.window.usd_paths-1.0.3, omni.kit.window.viewport-0.0.0
2021-07-21 13:18:02 [336ms] [Info] [omni.kit.app.plugin] [0.362s] [ext: omni.usd-0.1.8] startup
2021-07-21 13:18:02 [389ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.usd/bin' Filename: '*.plugin'
2021-07-21 13:18:02 [389ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins' Filename: 'omni.audiodeviceenum.plugin'
2021-07-21 13:18:02 [392ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.fastcache.plugin'
2021-07-21 13:18:02 [395ms] [Info] [carb] Registered plugin: omni.stageupdate.plugin (interfaces: [omni::kit::IStageUpdate v1.0]) (impl: omni.stageupdate.plugin)
2021-07-21 13:18:02 [395ms] [Info] [carb] Registered plugin: omni.audiodeviceenum.plugin (interfaces: [omni::audio::IAudioDeviceEnum v0.1]) (impl: omni.audiodeviceenum.plugin)
2021-07-21 13:18:02 [396ms] [Info] [carb] Registered plugin: carb.fastcache.plugin (interfaces: [carb::fastcache::FastCache v0.4],[carb::fastcache::FastCacheHydra v0.2]) (impl: carb.fastcache.plugin)
2021-07-21 13:18:02 [606ms] [Info] [carb] Initializing plugin: omni.stageupdate.plugin (interfaces: [omni::kit::IStageUpdate v1.0]) (impl: omni.stageupdate.plugin)
2021-07-21 13:18:02 [606ms] [Info] [carb] Initializing plugin: carb.fastcache.plugin (interfaces: [carb::fastcache::FastCache v0.4],[carb::fastcache::FastCacheHydra v0.2]) (impl: carb.fastcache.plugin)
2021-07-21 13:18:02 [607ms] [Info] [carb] Initializing plugin: carb.audio-forge.plugin (interfaces: [carb::audio::IAudioCapture v0.3],[carb::audio::IAudioData v0.6],[carb::audio::IAudioDevice v0.1],[carb::audio::IAudioGroup v0.1],[carb::audio::IAudioPlayback v0.5],[carb::audio::IAudioUtils v0.3]) (impl: carb.audio-forge.plugin)
2021-07-21 13:18:02 [617ms] [Info] [carb.audio.audio] Forge audio backend = 'ALSA'
2021-07-21 13:18:02 [621ms] [Info] [carb.audio.output] failed to retrieve the device details {hr = 0x88960004, deviceIndex = 0}
2021-07-21 13:18:02 [621ms] [Warning] [carb.audio.output] failed to retrieve the capabilities for device 0 {result = eInvalidParameter (8)}
2021-07-21 13:18:02 [621ms] [Warning] [carb.audio.context] failed to set the requested output during context creation. Using a null streamer instead {result = eInvalidParameter (8)}
2021-07-21 13:18:02 [621ms] [Info] [carb.audio.output] setting a null output at 0Hz with the speaker mode Default (0x00000000)
2021-07-21 13:18:02 [621ms] [Info] [carb.audio.output] requested a streamer-only output with a zero frame rate. Defaulting to 48000Hz.
2021-07-21 13:18:02 [621ms] [Info] [carb.audio.output] requested a streamer-only output without an empty speaker mode mask. Defaulting to Stereo (0x00000003).
2021-07-21 13:18:02 [621ms] [Info] [carb.audio.output] {speakers = 0x00000003, map = 0x7ffd473b2940}
2021-07-21 13:18:02 [621ms] [Info] [omni.usd] initial audio volumes: (1.00, 1.00, 1.00)
2021-07-21 13:18:02 [624ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.services.core-1.1.0] (order: 0) Triggered by: omni.kit.thumbnails.images-0.1.0, omni.services.registry-1.0.0, omni.services.transport.server.base-1.0.0, omni.services.transport.server.http-1.0.0
2021-07-21 13:18:02 [624ms] [Info] [omni.kit.app.plugin] [0.650s] [ext: omni.services.core-1.1.0] startup
2021-07-21 13:18:02 [819ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.client-0.1.0] (order: 0) Triggered by: omni.kit.asset_converter-1.0.1, omni.kit.property.material-1.4.1, omni.kit.property.usd-3.4.2, omni.kit.renderer.core-0.0.0, omni.kit.search.service-0.1.0, omni.kit.tagging-0.1.0, omni.kit.thumbnails.images-0.1.0, omni.kit.thumbnails.usd-0.3.0, omni.kit.tool.asset_exporter-1.0.2, omni.kit.tool.asset_importer-2.0.0, omni.kit.tool.collect-2.0.0, omni.kit.widget.filebrowser-2.0.4, omni.kit.widget.layers-0.3.1, omni.kit.widget.live-0.0.0, omni.kit.window.about-0.2.1, omni.kit.window.content_browser-2.0.3, omni.kit.window.extensions-1.0.2, omni.kit.window.filepicker-2.0.3, omni.kit.window.preferences-1.0.1, omni.kit.window.property-0.0.0, omni.renderer-rtx-0.0.0, omni.services.registry-1.0.0
2021-07-21 13:18:02 [819ms] [Info] [omni.kit.app.plugin] [0.845s] [ext: omni.client-0.1.0] startup
2021-07-21 13:18:02 [819ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.client/bin' Filename: '*.plugin'
2021-07-21 13:18:02 [819ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.datasource-omniclient.plugin'
2021-07-21 13:18:02 [825ms] [Info] [carb] Registered plugin: carb.messaging-omniclient.plugin (interfaces: [carb::messaging::IMessaging v0.3]) (impl: carb.messaging-omniclient.plugin)
2021-07-21 13:18:02 [826ms] [Info] [carb] Registered plugin: omni.client.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.client.plugin)
2021-07-21 13:18:02 [828ms] [Info] [carb] Registered plugin: carb.datasource-omniclient.plugin (interfaces: [carb::datasource::IDataSource v0.3],[carb::omniclient::IOmniClient v0.18]) (impl: carb.datasource-omniclient.plugin)
2021-07-21 13:18:02 [828ms] [Info] [carb] Initializing plugin: omni.client.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.client.plugin)
2021-07-21 13:18:02 [828ms] [Info] [omni.ext.plugin] [ext: omni.client-0.1.0] Starting ext::IExt in '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.client/bin/libomni.ext-client.plugin.so'
2021-07-21 13:18:02 [828ms] [Info] [omni.client.plugin] Main: omniclient: Initializing Version 0.18.0-5a97ef3d-release
2021-07-21 13:18:02 [829ms] [Info] [carb] Initializing plugin: carb.datasource-omniclient.plugin (interfaces: [carb::datasource::IDataSource v0.3],[carb::omniclient::IOmniClient v0.18]) (impl: carb.datasource-omniclient.plugin)
2021-07-21 13:18:02 [839ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.services.registry-1.0.0] (order: -1500) Triggered by: omni.create.next-2021.1.0
2021-07-21 13:18:02 [839ms] [Info] [omni.kit.app.plugin] [0.865s] [ext: omni.services.registry-1.0.0] startup
2021-07-21 13:18:02 [1,123ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.services.transport.server.base-1.0.0] (order: 0) Triggered by: omni.services.transport.server.http-1.0.0
2021-07-21 13:18:02 [1,123ms] [Info] [omni.kit.app.plugin] [1.149s] [ext: omni.services.transport.server.base-1.0.0] startup
2021-07-21 13:18:02 [1,130ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.services.transport.server.http-1.0.0] (order: -1500) Triggered by: omni.kit.thumbnails.images-0.1.0
2021-07-21 13:18:02 [1,130ms] [Info] [omni.kit.app.plugin] [1.157s] [ext: omni.services.transport.server.http-1.0.0] startup
2021-07-21 13:18:02 [1,131ms] [Info] [carb.python] [omni.kit.pipapi] Python UserEnvPath: /home/casperl/.local/share/ov/data/Kit/Create/2021.1/pip3-envs/default
2021-07-21 13:18:03 [1,302ms] [Info] [carb.python] Server will attempt to start on http://0.0.0.0:8011
2021-07-21 13:18:03 [1,306ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.stats-0.0.0] (order: 0) Triggered by: omni.appwindow-0.1.0-rc1, omni.create.next-2021.1.0, omni.renderer-rtx-0.0.0
2021-07-21 13:18:03 [1,306ms] [Info] [omni.kit.app.plugin] [1.332s] [ext: omni.stats-0.0.0] startup
2021-07-21 13:18:03 [1,306ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.stats.plugin'
2021-07-21 13:18:03 [1,307ms] [Info] [carb] Registered plugin: carb.stats.plugin (interfaces: [carb::stats::IStats v0.2]) (impl: carb.stats.plugin)
2021-07-21 13:18:03 [1,311ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.appwindow-0.1.0-rc1] (order: 0) Triggered by: omni.kit.renderer.core-0.0.0, omni.kit.window.title-1.0.0, omni.physx-1.1.0-5.1, omni.physx.cct-1.1.0-5.1, omni.ui-2.1.2
2021-07-21 13:18:03 [1,311ms] [Info] [omni.kit.app.plugin] [1.338s] [ext: omni.appwindow-0.1.0-rc1] startup
2021-07-21 13:18:03 [1,311ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.appwindow/bin' Filename: '*.plugin'
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Registered plugin: carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v0.1],[carb::windowing::IWindowing v1.1]) (impl: carb.windowing-glfw.plugin)
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Registered plugin: carb.input.plugin (interfaces: [carb::input::IInput v1.0]) (impl: carb.input.plugin)
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Registered plugin: omni.appwindow.plugin (interfaces: [omni::ext::IExt v0.1],[omni::kit::IAppWindowFactory v1.0]) (impl: omni.appwindow.plugin)
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Initializing plugin: omni.appwindow.plugin (interfaces: [omni::ext::IExt v0.1],[omni::kit::IAppWindowFactory v1.0]) (impl: omni.appwindow.plugin)
2021-07-21 13:18:03 [1,312ms] [Info] [omni.ext.plugin] [ext: omni.appwindow-0.1.0-rc1] Starting ext::IExt in '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.appwindow/bin/libomni.appwindow.plugin.so'
2021-07-21 13:18:03 [1,312ms] [Info] [omni.appwindow.plugin] [Graphics API] Vulkan
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Initializing plugin: carb.graphics-vulkan.plugin (interfaces: [carb::graphics::Graphics v1.16],[carb::ngx::Ngx v0.2]) (impl: carb.graphics-vulkan.plugin)
2021-07-21 13:18:03 [1,312ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VK_SDK_PATH =
2021-07-21 13:18:03 [1,312ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VULKAN_SDK =
2021-07-21 13:18:03 [1,312ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VK_LAYER_PATH =
2021-07-21 13:18:03 [1,312ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VK_INSTANCE_LAYERS =
2021-07-21 13:18:03 [1,312ms] [Info] [carb.graphics-vulkan.plugin] Environment variable overridden: VULKAN_HEADERS_INSTALL_DIR =
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Initializing plugin: carb.profiler.gpu.plugin (interfaces: [carb::profiler::IGpuProfiler v0.2]) (impl: carb.profiler.gpu.plugin)
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Initializing plugin: carb.input.plugin (interfaces: [carb::input::IInput v1.0]) (impl: carb.input.plugin)
2021-07-21 13:18:03 [1,312ms] [Info] [carb] Initializing plugin: carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v0.1],[carb::windowing::IWindowing v1.1]) (impl: carb.windowing-glfw.plugin)
2021-07-21 13:18:03 [1,331ms] [Info] [omni.appwindow.plugin] Created window: width=1593,height=843.
2021-07-21 13:18:03 [1,340ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.kit.renderer.core-0.0.0] (order: 0) Triggered by: omni.create.next-2021.1.0, omni.kit.renderer.capture-0.0.0, omni.kit.uiapp-0.0.0,
2021-07-21 13:18:03 [1,340ms] [Info] [omni.kit.app.plugin] [1.367s] [ext: omni.kit.renderer.core-0.0.0] startup
2021-07-21 13:18:03 [1,340ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.kit.renderer.core/bin' Filename: '*.plugin'
2021-07-21 13:18:03 [1,341ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.graphicsmux.plugin'
2021-07-21 13:18:03 [1,343ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx' Filename: 'rtx.resourcemanager.plugin'
2021-07-21 13:18:03 [1,344ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.blockcompression.plugin'
2021-07-21 13:18:03 [1,346ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx' Filename: 'rtx.rendergraph.plugin'
2021-07-21 13:18:03 [1,348ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.cudainterop.plugin'
2021-07-21 13:18:03 [1,350ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.glinterop.plugin'
2021-07-21 13:18:03 [1,351ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.imgui.plugin'
2021-07-21 13:18:03 [1,352ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.imguizmo.plugin'
2021-07-21 13:18:03 [1,353ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins' Filename: 'omni.ui.windowmanager.plugin'
2021-07-21 13:18:03 [1,355ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins' Filename: 'omni.ui.glyphmanager.plugin'
2021-07-21 13:18:03 [1,358ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.svg-nanosvg.plugin'
2021-07-21 13:18:03 [1,359ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/carb_gfx' Filename: 'carb.xr.plugin'
2021-07-21 13:18:03 [1,360ms] [Info] [omni.ext.plugin] Attempting to load plugins. Folder: '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx' Filename: 'rtx.xrtools.plugin'
2021-07-21 13:18:03 [1,362ms] [Info] [carb] Registered plugin: omni.kit.imgui_renderer.plugin (interfaces: [omni::kit::renderer::IImGuiRenderer v1.0]) (impl: omni.kit.imgui_renderer.plugin)
2021-07-21 13:18:03 [1,362ms] [Info] [carb] Registered plugin: omni.kit.renderer.ext.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.renderer.ext.plugin)
2021-07-21 13:18:03 [1,362ms] [Info] [carb] Registered plugin: omni.kit.renderer.plugin (interfaces: [omni::kit::renderer::IGpuFoundation v0.2],[omni::kit::renderer::IRenderer v1.0]) (impl: omni.kit.renderer.plugin)
2021-07-21 13:18:03 [1,363ms] [Info] [carb] Registered plugin: carb.graphicsmux.plugin (interfaces: [carb::graphicsmux::GraphicsMux v0.9]) (impl: carb.graphicsmux.plugin)
2021-07-21 13:18:03 [1,363ms] [Info] [carb] Registered plugin: rtx.resourcemanager.plugin (interfaces: [rtx::resourcemanager::ResourceManager v0.11]) (impl: rtx.resourcemanager.plugin)
2021-07-21 13:18:03 [1,364ms] [Info] [carb] Registered plugin: carb.blockcompression.plugin (interfaces: [carb::blockcompression::BlockCompression v0.1]) (impl: carb.blockcompression.plugin)
2021-07-21 13:18:03 [1,364ms] [Info] [carb] Registered plugin: rtx.rendergraph.plugin (interfaces: [rtx::rendergraph::RenderGraphBuilder v0.6]) (impl: rtx.rendergraph.plugin)
2021-07-21 13:18:03 [1,364ms] [Info] [carb] Registered plugin: carb.cudainterop.plugin (interfaces: [carb::cudainterop::CudaInterop v0.3]) (impl: carb.cudainterop.plugin)
2021-07-21 13:18:03 [1,364ms] [Info] [carb] Registered plugin: carb.glinterop.plugin (interfaces: [carb::glinterop::GLInterop v0.1]) (impl: carb.glinterop.plugin)
2021-07-21 13:18:03 [1,364ms] [Info] [carb] Registered plugin: carb.imgui.plugin (interfaces: [carb::imgui::ImGui v0.14]) (impl: carb.imgui.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Registered plugin: carb.imguizmo.plugin (interfaces: [carb::imguizmo::ImGuizmo v0.1]) (impl: carb.imguizmo.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Registered plugin: omni.ui.windowmanager.plugin (interfaces: [omni::ui::windowmanager::IWindowCallbackManager v0.3]) (impl: omni.ui.windowmanager.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Registered plugin: omni.ui.glyphmanager.plugin (interfaces: [omni::ui::IGlyphManager v1.0]) (impl: omni.ui.glyphmanager.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Registered plugin: carb.svg.plugin (interfaces: [carb::svg::Svg v0.1]) (impl: carb.svg.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Registered plugin: carb.xr.plugin (interfaces: [carb::xr::XRContext v0.5]) (impl: carb.xr.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Registered plugin: rtx.xrtools.plugin (interfaces: [rtx::xrtools::XRTools v0.1]) (impl: rtx.xrtools.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Initializing plugin: omni.kit.renderer.ext.plugin (interfaces: [omni::ext::IExt v0.1]) (impl: omni.kit.renderer.ext.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] Starting ext::IExt in '/home/casperl/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_exts/omni.kit.renderer.core/bin/libomni.kit.renderer.ext.plugin.so'
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Initializing plugin: omni.kit.renderer.plugin (interfaces: [omni::kit::renderer::IGpuFoundation v0.2],[omni::kit::renderer::IRenderer v1.0]) (impl: omni.kit.renderer.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Initializing plugin: omni.kit.imgui_renderer.plugin (interfaces: [omni::kit::renderer::IImGuiRenderer v1.0]) (impl: omni.kit.imgui_renderer.plugin)
2021-07-21 13:18:03 [1,365ms] [Info] [omni.kit.renderer.plugin] Added dataSource connection for prefix '/'
2021-07-21 13:18:03 [1,365ms] [Info] [carb] Initializing plugin: carb.graphicsmux.plugin (interfaces: [carb::graphicsmux::GraphicsMux v0.9]) (impl: carb.graphicsmux.plugin)
2021-07-21 13:18:03 [1,366ms] [Info] [gpu.foundation] X server vendor: The X.Org Foundation
2021-07-21 13:18:03 [1,366ms] [Warning] [gpu.foundation] Vulkan multi-GPU enumeration not supported on X server 1.19.6.0! Minimum required X server version is 1.20.7.0.
2021-07-21 13:18:03 [1,386ms] [Warning] [carb.audio.context] 1 contexts were leaked
Currently I am clueless on what it could be, so thanks in advance for giving my directions on where to look!
Casper
