Running PeopleNet on x86 with Jetson Inference Container
Hey, I have a project where I want to run Automatic labeling of people on images. I Have it running on my Jetson device. I am using the pre trained PeopleNet. Now I want to also have it running on my normal linux PC with a 1080ti. I did build the docker container but it can not load PeopleNet.
jetson.inference – detectNet loading build-in network ‘peoplenet’
jetson.inference – detectNet invalid built-in network was requested (‘peoplenet’)
File “Automatic_Labeling.py”, line 85, in
results = detect_people_in_image(image)
File “Automatic_Labeling.py”, line 50, in detect_people_in_image
net = detectNet(“peoplenet”, threshold=0.01)
Exception: jetson.inference – detectNet invalid built-in network was requested
I also tried to load PeopleNet (deployable_quantized_onnx_v2.6.2) myself and then transform it with trtexec to a .engine file but there I only had empty boundinboxes and no detections.
Can you support me in this topic? You can also tell me if there is a better option to do this project.
Could you checkout the x86 branch and try it again?
so as explained I am using my own container. I build it with the base image from Dusty for amd64. (with dustynv/jetson-inference:22.06)
I need this because I need to install some company related stuff. When I understand it correctly it should download peoplenet by itself when I call it, or do I miss understand something? I also don’t understand why I should clone the git site.
Sorry for the late awnser I was on vaccation.
Hi
Models are downloaded by CMakePreBuild.sh script.
If it doesn’t download automatically, would you mind running it manually?
