I use a V4L2 camera, my camera use MJPEG so I convert MJPEG to RGB with Gstreamer in the pipeline, my camera is stereo so I crop the image to get only one view with cuda crop, I implemented a RGB to Gray function that you don’t need, then I just send the image to the skeleton algo, after that I use a cpp codelet to get the output bones.
This is my JSON file :
"name": "openpose_inference",
"modules": [
"//packages/skeleton_pose_estimation/apps/openpose:PoseRX",
"//packages/skeleton_pose_estimation/apps/openpose:rgb2grey",
"//packages/ml:ml",
"//packages/ml:tensorrt",
"//packages/skeleton_pose_estimation",
"//packages/perception",
"sensors:v4l2_camera",
"deepstream",
"message_generators",
"viewers",
"deepstream",
"sight"
"graph": {
"nodes": [
"name": "poseRX",
"components": [
"name": "message_ledger",
"type": "isaac::alice::MessageLedger"
"name": "poseRX",
"type": "isaac::PoseRX"
"name": "feeder",
"components": [
"name": "image_feeder",
"type": "isaac::message_generators::ImageLoader"
"name": "pipeline",
"type": "isaac::deepstream::Pipeline"
"name": "compute",
"components": [
"name": "crop1",
"type": "isaac::perception::CropAndDownsampleCuda"
"name": "crop2",
"name": "RGB2GRAY",
"type": "isaac::opencv::RGB2GREY"
"name": "tensor_encoder",
"components": [
"name": "isaac.ml.ColorCameraEncoderCuda",
"type": "isaac::ml::ColorCameraEncoderCuda"
"name": "tensor_r_t_inference",
"components": [
"name": "isaac.ml.TensorRTInference",
"type": "isaac::ml::TensorRTInference"
"name": "open_pose_decoder",
"components": [
"name": "isaac.skeleton_pose_estimation.OpenPoseDecoder",
"type": "isaac::skeleton_pose_estimation::OpenPoseDecoder"
"name": "skeleton_viewer",
"components": [
"name": "isaac.alice.MessageLedger",
"name": "isaac.viewers.SkeletonViewer",
"type": "isaac::viewers::SkeletonViewer"
"name": "isaac.viewers.ColorCameraViewer",
"type": "isaac::viewers::ColorCameraViewer"
"name": "publishing",
"components": [
"name": "viewer1",
"name": "viewer2",
"name": "viewer3",
"name": "viewer4",
"name": "viewer1_widget",
"type": "isaac::sight::SightWidget"
"name": "viewer2_widget",
"name": "viewer3_widget",
"name": "viewer4_widget",
"edges": [
"source": "open_pose_decoder/isaac.skeleton_pose_estimation.OpenPoseDecoder/skeletons",
"target": "poseRX/poseRX/skeletons"
"source": "feeder/pipeline/acquired_image",
"target": "compute/crop1/input_image"
"target": "compute/crop2/input_image"
"target": "compute/RGB2GRAY/input_image"
"source": "compute/crop1/output_image",
"target": "tensor_encoder/isaac.ml.ColorCameraEncoderCuda/rgb_image"
"source": "tensor_encoder/isaac.ml.ColorCameraEncoderCuda/tensor",
"target": "tensor_r_t_inference/isaac.ml.TensorRTInference/input"
"source": "tensor_r_t_inference/isaac.ml.TensorRTInference/part_affinity_fields",
"target": "open_pose_decoder/isaac.skeleton_pose_estimation.OpenPoseDecoder/part_affinity_fields"
"source": "tensor_r_t_inference/isaac.ml.TensorRTInference/gaussian_heatmap",
"target": "open_pose_decoder/isaac.skeleton_pose_estimation.OpenPoseDecoder/gaussian_heatmap"
"source": "tensor_r_t_inference/isaac.ml.TensorRTInference/maxpool_heatmap",
"target": "open_pose_decoder/isaac.skeleton_pose_estimation.OpenPoseDecoder/maxpool_heatmap"
"target": "skeleton_viewer/isaac.viewers.SkeletonViewer/skeletons"
"target": "skeleton_viewer/isaac.viewers.ColorCameraViewer/color_listener"
"target": "publishing/viewer1/color_listener"
"source": "compute/crop2/output_image",
"target": "publishing/viewer2/color_listener"
"target": "publishing/viewer3/color_listener"
"source": "compute/RGB2GRAY/output_image",
"target": "publishing/viewer4/color_listener"
"config": {
"poseRX" : {
"poseRX" : {
"LogLvl" : "1"
"compute": {
"crop1": {
"crop_start": [0, 0],
"crop_size": [480, 640]
"crop2": {
"crop_start": [0, 640],
"publishing": {
"viewer1_widget": {
"title": "Viewer: Video Left",
"type": "2d",
"channels": [
"name": "publishing/viewer1/Color"
"viewer2_widget": {
"title": "Viewer: Video Right",
"type": "2d",
"channels": [
"name": "publishing/viewer2/Color"
"viewer3_widget": {
"title": "Viewer: Acquis ",
"type": "2d",
"channels": [
"name": "publishing/viewer3/Color"
"viewer4_widget": {
"title": "Viewer: GRAY",
"type": "2d",
"channels": [
"name": "publishing/viewer4/Color"
"tensor_encoder": {
"isaac.ml.ColorCameraEncoderCuda": {
"rows": 320,
"cols": 320,
"pixel_normalization_mode": "HalfAndHalf",
"tensor_index_order": "201",
"keep_aspect_ratio": false
"feeder": {
"pipeline": {
"pipeline": "gst-launch-1.0 -v v4l2src device=/dev/video0 ! avdec_mjpeg ! videoconvert ! video/x-raw,format=RGB,height=480,wight=1280,framerate=60/1 ! appsink name = acquired_image "
"image_feeder": {
"color_filename": "packages/skeleton_pose_estimation/apps/openpose/validation_dataset/images/01.png",
"tick_period": "1Hz",
"focal_length": [
100,
100
"optical_center": [
500,
500
"distortion_coefficients": [
0.01,
0.01,
0.01,
0.01,
0.01
"tensor_r_t_inference": {
"isaac.ml.TensorRTInference": {
"model_file_path": "external/openpose_model/ix-networks-openpose.uff",
"engine_file_path": "external/openpose_model/ix-networks-openpose.plan",
"input_tensor_info": [
"channel": "input",
"operation_name": "input_1",
"dims": [3, 320, 320],
"uff_input_order": "channels_first"
"output_tensor_info": [
"channel": "part_affinity_fields",
"operation_name": "lambda_2/conv2d_transpose",
"dims": [160, 160, 38]
"channel": "gaussian_heatmap",
"operation_name": "lambda_3/tensBlur_depthwise_conv2d",
"dims": [160, 160, 19]
"channel": "maxpool_heatmap",
"operation_name": "tensBlur/MaxPool",
"channel": "heatmap",
"operation_name": "lambda_1/conv2d_transpose",
"open_pose_decoder": {
"isaac.skeleton_pose_estimation.OpenPoseDecoder": {
"label": "Human",
"labels": ["Nose", "Neck", "Rsho", "Relb", "Rwri", "Lsho", "Lelb", "Lwri", "Rhip", "Rkne",
"Rank", "Lhip", "Lkne", "Lank", "Leye", "Reye", "Lear", "Rear"],
"edges": [[1, 2], [1, 5], [2, 3], [3, 4], [5, 6], [6, 7], [1, 8], [8, 9], [9, 10], [1, 11],
[11, 12], [12, 13], [1, 0], [0, 14], [14, 16], [0, 15], [15, 17], [2, 16], [5, 17]],
"edges_paf": [[12, 13], [20, 21], [14, 15], [16, 17], [22, 23], [24, 25], [0, 1], [2, 3],
[4, 5], [6, 7], [8, 9], [10, 11], [28, 29], [30, 31], [34, 35], [32, 33],
[36, 37], [18, 19], [26, 27]],
"threshold_heatmap" : 0.05,
"threshold_edge_size" : 0.1,
"threshold_edge_score" : 0.05,
"threshold_edge_sampling_counter" : 8,
"threshold_part_counter" : 4,
"threshold_object_score" : 0.4,
"threshold_split_score" : 2,
"edge_sampling_steps" : 10,
"refine_parts_coordinates" : true,
"output_scale" : [480, 640]
"skeleton_viewer": {
"isaac.viewers.SkeletonViewer": {
"edges_render": [[1, 2], [1, 5], [2, 3], [3, 4], [5, 6], [6, 7], [1, 8], [8, 9], [9, 10],
[1, 11], [11, 12], [12, 13], [1, 0], [0, 14], [14, 16], [0, 15], [15, 17]]
"isaac.viewers.ColorCameraViewer": {
"camera_name": "color_camera_viewer",
"target_fps": 30,
"reduce_scale": 1
This is to get the skeleton output :
#include "poseRX.hpp"
#include <string>
namespace isaac {
void PoseRX::start() {
// By using tickOnMessage instead of tickPeriodically we instruct the codelet to only tick when
// a new message is received on the incoming data channel `trigger`.
tickOnMessage(rx_skeletons());
void PoseRX::tick() {
// This function will now only be executed whenever we receive a new message. This is guaranteed
// by the Isaac Robot Engine.
// Parse the message we received
// create cap'n Proto List of Skeleton2Proto
auto skeleton_list = rx_skeletons().getProto().getSkeletons();
for(size_t i = 0; i < skeleton_list.size(); i++) {
// for each Skeleton2Proto, create cap'n Proto List of Joint2Proto
auto joint_list = skeleton_list[i].getJoints();
for(size_t ii = 0; ii < joint_list.size(); ii++) {
// retrieve joint prediction confidence, this is a float
float joint_conf = joint_list[ii].getLabel().getConfidence();
std::printf("conf : %f | ",joint_conf);
// retrieve X position in image of joint (be warned, this is a float too)
float joint_x = joint_list[ii].getPosition().getX();
std::printf("x : %f | ",joint_x);
// retrieve Y position in image of joint (be warned, this is a float too)
float joint_y = joint_list[ii].getPosition().getY();
std::printf("y : %f \n",joint_y);
// Print to the console
//std::printf("%s:", message.c_str());
//std::printf(" DOPE! \n");
} // namespace isaac
Hope that can guide you, tell me if you need more details
