Hello all,
On August 5, 2026, Proxmox announced the first officially supported Arm64 edition of Proxmox VE, with day-one support for NVIDIA Grace and NVIDIA Vera CPU architectures. It was developed in technical collaboration with NVIDIA and Supermicro and validated on NVIDIA Grace Hopper systems.
Proxmox VE itself is a Type 1 (bare-metal/native) hypervisor. However, you can run a fully functional Proxmox VE on an NVIDIA DGX Spark by running the Dockur Proxmox container with privileged: true, allowing it to access the host’s KVM acceleration. Because the DGX Spark is ARM64 based on the Grace + Blackwell GB10 platform, the resulting Proxmox environment runs ARM64 guests, not x86_64 guests.
Deploy Proxmox on the DGX Spark
docker-compose.yml
services:
proxmox:
hostname: pve
image: dockurr/proxmox
container_name: proxmox
environment:
PASSWORD: "your-root-password" # Proxmox web/root password
ports:
- 8006:8006
volumes:
- ./data:/var/lib/vz
- ./config:/var/lib/pve-cluster
restart: always
privileged: true
stop_grace_period: 2m
Up and running:
docker compose up -d
Then open the web UI: https://<DGX-Spark-IP>:8006 (ignore the self-signed cert).
The container keeps Proxmox state on your host disk via two bind mounts:
./data→/var/lib/vz(VM images, ISO templates, dumps)./config→/var/lib/pve-cluster(the Proxmox cluster config database)
Running an Ubuntu 24.04.4 Server image on the machine:
Instead of manually installing Ubuntu for every VM, It is possible to use cloud-init images on Proxmox. A cloud-init image is a prebuilt Linux virtual-machine disk image that is designed to be configured automatically when the VM first boots.
Running Proxmox VE on the NVIDIA DGX Spark is genuinely possible today, and it is no longer an exotic hack.
