Software Version
DRIVE OS 6.0.10.0
[1]DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1]Linux
QNX
other
Hardware Platform
[1]DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[1]other
Host Machine Version
other
Issue Description
Hi team, On host, I could see some python samples under /usr/src/tensorrt/samples/python.
I want to execute the network_api_pytorch_mnist sample. I tried installing the dependencies from requirements.txt file. But I got the below errors. What could be the reasons?
Or Do I need to copy all the samples from host to target and build it on target itself?
ignore the requirements.txt, or manually edit it. best is to run the sample it will prompt for missing pip packages. always use a virtual environment as well better pip-package isolation.
Dear @akshay.tupkar ,
Could you please use text message instead of images for logs for all your future topics.
Yes. I dont se any issue when running pythoin sample ditrectly on target.
nvidia@tegra-ubuntu:/usr/src/tensorrt/samples/python/network_api_pytorch_mnist$ python3 sample.py
Downloading http://yann.lecun.com/exdb/mnist/train-images-idx3-ubyte.gz
Failed to download (trying next):
HTTP Error 404: Not Found
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/train-images-idx3-ubyte.gz
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/train-images-idx3-ubyte.gz to /tmp/mnist/data/MNIST/raw/train-images-idx3-ubyte.gz
100%|███████████████████████████████████████████████████████████████████████| 9912422/9912422 [00:04<00:00, 2362436.19it/s]
Extracting /tmp/mnist/data/MNIST/raw/train-images-idx3-ubyte.gz to /tmp/mnist/data/MNIST/raw
Downloading http://yann.lecun.com/exdb/mnist/train-labels-idx1-ubyte.gz
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/train-labels-idx1-ubyte.gz
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/train-labels-idx1-ubyte.gz to /tmp/mnist/data/MNIST/raw/train-labels-idx1-ubyte.gz
100%|████████████████████████████████████████████████████████████████████████████| 28881/28881 [00:00<00:00, 117873.54it/s]
Extracting /tmp/mnist/data/MNIST/raw/train-labels-idx1-ubyte.gz to /tmp/mnist/data/MNIST/raw
Downloading http://yann.lecun.com/exdb/mnist/t10k-images-idx3-ubyte.gz
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/t10k-images-idx3-ubyte.gz
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/t10k-images-idx3-ubyte.gz to /tmp/mnist/data/MNIST/raw/t10k-images-idx3-ubyte.gz
100%|████████████████████████████████████████████████████████████████████████| 1648877/1648877 [00:01<00:00, 943887.41it/s]
Extracting /tmp/mnist/data/MNIST/raw/t10k-images-idx3-ubyte.gz to /tmp/mnist/data/MNIST/raw
Downloading http://yann.lecun.com/exdb/mnist/t10k-labels-idx1-ubyte.gz
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/t10k-labels-idx1-ubyte.gz
Downloading https://ossci-datasets.s3.amazonaws.com/mnist/t10k-labels-idx1-ubyte.gz to /tmp/mnist/data/MNIST/raw/t10k-labels-idx1-ubyte.gz
100%|████████████████████████████████████████████████████████████████████████████| 4542/4542 [00:00<00:00, 16994227.27it/s]
Extracting /tmp/mnist/data/MNIST/raw/t10k-labels-idx1-ubyte.gz to /tmp/mnist/data/MNIST/raw
Train Epoch: 1 [0/60000 (0%)] Loss: 2.313610
Train Epoch: 1 [6400/60000 (11%)] Loss: 0.601012
Train Epoch: 1 [12800/60000 (21%)] Loss: 0.286917
Train Epoch: 1 [19200/60000 (32%)] Loss: 0.277789
Train Epoch: 1 [25600/60000 (43%)] Loss: 0.146727
Train Epoch: 1 [32000/60000 (53%)] Loss: 0.140967
Train Epoch: 1 [38400/60000 (64%)] Loss: 0.136560
Train Epoch: 1 [44800/60000 (75%)] Loss: 0.052772
Train Epoch: 1 [51200/60000 (85%)] Loss: 0.041543
Train Epoch: 1 [57600/60000 (96%)] Loss: 0.157574
Test set: Average loss: 0.0884, Accuracy: 9749/10000 (97%)
Train Epoch: 2 [0/60000 (0%)] Loss: 0.070697
Train Epoch: 2 [6400/60000 (11%)] Loss: 0.054531
Train Epoch: 2 [12800/60000 (21%)] Loss: 0.075649
Train Epoch: 2 [19200/60000 (32%)] Loss: 0.054936
Train Epoch: 2 [25600/60000 (43%)] Loss: 0.022699
Train Epoch: 2 [32000/60000 (53%)] Loss: 0.014617
Train Epoch: 2 [38400/60000 (64%)] Loss: 0.061728
Train Epoch: 2 [44800/60000 (75%)] Loss: 0.014672
Train Epoch: 2 [51200/60000 (85%)] Loss: 0.064870
Train Epoch: 2 [57600/60000 (96%)] Loss: 0.111935
Test set: Average loss: 0.0592, Accuracy: 9817/10000 (98%)
sample.py:112: DeprecationWarning: Use set_memory_pool_limit instead.
config.max_workspace_size = common.GiB(1)
sample.py:75: DeprecationWarning: Use add_convolution_nd instead.
conv1 = network.add_convolution(
sample.py:78: DeprecationWarning: Use stride_nd instead.
conv1.stride = (1, 1)
sample.py:80: DeprecationWarning: Use add_pooling_nd instead.
pool1 = network.add_pooling(input=conv1.get_output(0), type=trt.PoolingType.MAX, window_size=(2, 2))
sample.py:81: DeprecationWarning: Use stride_nd instead.
pool1.stride = (2, 2)
sample.py:85: DeprecationWarning: Use add_convolution_nd instead.
conv2 = network.add_convolution(pool1.get_output(0), 50, (5, 5), conv2_w, conv2_b)
sample.py:86: DeprecationWarning: Use stride_nd instead.
conv2.stride = (1, 1)
sample.py:88: DeprecationWarning: Use add_pooling_nd instead.
pool2 = network.add_pooling(conv2.get_output(0), trt.PoolingType.MAX, (2, 2))
sample.py:89: DeprecationWarning: Use stride_nd instead.
pool2.stride = (2, 2)
Test Case: 7
Prediction: 7
system
Closed
October 17, 2025, 5:12am
9
