This guide describes how to deploy Qwen/Qwen3.8-Flash-Next-FP8 using vllm on a 4xH100 GPU Slurm compute node and access the OpenAI-compatible API remotely through the cluster’s login node.
Create a Python 3.12 virtual environment using uv and install vllm:
uv venv .vllm --python 3.12
source .vllm/bin/activate
uv pip install vllm --torch-backend=auto
Make sure the vllm environment is activated before starting the server. On the Slurm compute node with 4xH100 GPUs, start the model server:
vllm serve Qwen/Qwen3.8-Flash-Next-FP8 \
--max-num-seqs 256 \
--gpu-memory-utilization 0.90 \
--enable-prefix-caching \
--no-enable-flashinfer-autotune \
--tensor-parallel-size 4 \
--enable-auto-tool-choice \
--tool-call-parser qwen3_coder \
--reasoning-parser qwen3 \
--disable-custom-all-reduce
With this configuration, vllm reports:
GPU KV cache size: 2,853,864 tokens, Maximum concurrency for 262,144 tokens per request: 10.89x
This provides a substantial KV-cache capacity for long-context workloads.
Most clusters don’t expose compute nodes externally. SSH tunneling is fragile and blocked by many corporate networks. Use SSH port forwarding to create a tunnel from your laptop through the login node to the compute node running vLLM.
Open the tunnel on your local machine, run:
ssh -N -L 8000:<compute-node>:8000 <your-username>@<login-node>
In a separate terminal, use the local endpoint:
import requests
response = [requests.post](https://requests.post/)(
"http://localhost:8000/v1/completions",
json={
"model": "Qwen/Qwen3.8-Flash-Next-FP8",
"prompt": "Hello world"
print(response.json())
Output:
{'id': 'cmpl-a56333a907fbddb4', 'object': 'text_completion', 'created': 1789889586, 'model': 'Qwen/Qwen3.8-Flash-Next-FP8', 'choices': [{'index': 0, 'text': '!\n\n# What is the difference between a single phase and a three phase transformer', 'logprobs': None, 'finish_reason': 'length', 'stop_reason': None, 'token_ids': None, 'prompt_logprobs': None, 'prompt_token_ids': None, 'routed_experts': None}], 'service_tier': None, 'system_fingerprint': 'vllm-0.29.1rc1.dev350+gd5f0a6e82-tp4-7ec5d35a', 'usage': {'prompt_tokens': 2, 'total_tokens': 18, 'completion_tokens': 16, 'prompt_tokens_details': None, 'completion_tokens_details': None}, 'kv_transfer_params': None, 'ec_transfer_params': None, 'metrics': None}
The response confirms that the request successfully reached the vllm server running on the Slurm compute node.
The same vllm endpoint can be used as an OpenAI-compatible backend for Kimi CLI.
$env:KIMI_MODEL_NAME = "Qwen/Qwen3.8-Flash-Next-FP8"
$env:KIMI_MODEL_API_KEY = "your-actual-vllm-api-key"
$env:KIMI_MODEL_PROVIDER_TYPE = "openai"
$env:KIMI_MODEL_BASE_URL = "http://localhost:8000/v1"
$env:KIMI_MODEL_MAX_CONTEXT_SIZE = "262144"
Output:
Once the Kimi CLI is configured and the vLLM endpoint is working, you can start the Kimi web interface with:
kimi web --host
Output
