Running Re-ID network in Triton
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version nvcr.io/nvidia/deepstream:7.1-gc-triton-devel
• TensorRT Version
• Issue Type( questions, new requirements, bugs) questions
Hi all,
I am currently investigating the nv-tracker and related features. I am wondering if there’s option to use the re identification network inside Triton instead of a single instance of trt engine. I am running multiple deepsteam application that will use the same re-id network, and it is much more efficient to run it with triton with cuda buffer sharing.
Many Thanks!
nvtracker don’t support Triton backend inference currently. Can you share your use case and the pipeline in your project? We can check if we can optimize the pipeline for your use case.
Basically I have multiple slightly different pipeline that all use the same Re-ID model provided by deepstream. Say I have 3 different pipeline, and current way only support create 3 Re-ID trt engine, which is super inefficient. I may create my own custom low-level-library to accommodate for this at the moment.
Here is the guide for implement custom low level tracker library: Gst-nvtracker — DeepStream documentation
