Running replicator container on cloud Nvidia-L4
No output is generated when running the test.py script as in instructions
https://docs.omniverse.nvidia.com/extensions/latest/ext_replicator/container_setup.html
on a GCP VM. I tested also using relative and absolute path for test.py but neither works
log.txt (102.4 KB)
Hi @ilias.papastratis looking at the log, this pops out at me:
2024-02-13 12:50:29 [36,437ms] [Warning] [omni.replicator.core.scripts.backends.log] [tid 139960574741888][backends][disk.py] No root directory specified in carb setting `/omni/replicator/backends/disk/root_dir`. Writing data to /root/omni.replicator_out/output
It looks like it loaded the kitapp correctly (it shows [33.333s] RTX ready), runs some replicator stuff, and shuts down. See if it perhaps output the files to an unexpected directory.
