Hello!
I’m trying to run replicator with the Cesium extension, and it creates the folder but the files never show up and many times it crashes. Can someone enlighten me as to how I can fix this so I can use Replicator and Cesium?
part of my log if it helps:
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] gpu_0: ‘NVIDIA GeForce RTX 3090’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] gpuVRAM_0: ‘25522339840’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] gpuDriver_0: ‘536.67’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] gpu_1: ‘NVIDIA GeForce RTX 3090’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] gpuVRAM_1: ‘25522339840’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] gpuDriver_1: ‘536.67’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] shaderdb_obfuscateCode: ‘1’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] shaderdb_debugSymbols: ‘0’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] shaderdb_dumpIntermediates: ‘0’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] shaderdb_dumpIncludeOverrides: ‘0’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] shaderdb_optimizationLevel: ‘1’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion: ‘536.67’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] lastCommands: ‘CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/SyncGate,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnWritePrimAttribute_06,node_type=omni.replicator.core.OgnWritePrimAttribute,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnCount_12,node_type=omni.replicator.core.OgnCount,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/SyncGate_01,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/RenderProduct_Replicator_BasicWriterWriter,node_type=omni.replicator.core.OgnWriter,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate,node_type=omni.graph.action.RationalTimeSyncGate,create_usd=True),CreateGraphAsNodeCommand(graph_path=/WriterOrchestrator,node_name=WriterOrchestrator,evaluator_name=execution,is_global_graph=True,backed_by_usd=True,fc_backing_type=?,pipeline_stage=?,evaluation_mode=?,graph=?),CreateNodeCommand(graph=?,node_path=/WriterOrchestrator/OgnOnFrame,node_type=omni.replicator.core.OgnOnFrame,create_usd=True),CreateNodeCommand(graph=?,node_path=/WriterOrchestrator/OgnScheduleWriter,node_type=omni.replicator.core.OgnScheduleWriter,create_usd=True),CreateNodeCommand(graph=?,node_path=/WriterOrchestrator/ReadFabricTime,node_type=omni.replicator.core.ReadFabricTime,create_usd=True)’
2024-04-02 00:48:20 [1,107,642ms] [Verbose] [carb.crashreporter-breakpad.plugin] lastCommand: ‘CreateNodeCommand(graph=?,node_path=/WriterOrchestrator/ReadFabricTime,node_type=omni.replicator.core.ReadFabricTime,create_usd=True)’
2024-04-02 00:48:20 [1,107,643ms] [Verbose] [carb.crashreporter-breakpad.plugin] carboniteSdkVersion: ‘158.3+release158.tc9506.b2fcff1c’
2024-04-02 00:48:20 [1,107,643ms] [Verbose] [carb.crashreporter-breakpad.plugin] carboniteFrameworkVersion: ‘158.3+release158.tc9506.b2fcff1c’
2024-04-02 00:48:20 [1,107,643ms] [Verbose] [carb.crashreporter-breakpad.plugin] gpuCrash: ‘1’
2024-04-02 00:48:20 [1,107,643ms] [Verbose] [carb] Client gpu.foundation.plugin acquiring interface carb::graphics::Graphics 2.20 from
2024-04-02 00:48:20 [1,107,643ms] [Verbose] [carb] Ensuring carb.graphics-direct3d.plugin unloads after gpu.foundation.plugin
2024-04-02 00:48:20 [1,107,643ms] [Verbose] [carb] carb.graphics-direct3d.plugin(154) already unloads after gpu.foundation.plugin(135)
2024-04-02 00:48:20 [1,107,643ms] [Verbose] [carb] Returning interface 0000023AFE0C80D0 as carb::graphics::Graphics 2.20 to client gpu.foundation.plugin
2024-04-02 00:48:20 [1,107,643ms] [Warning] [gpu.foundation.plugin] polling aftermath dump sta
