Running ROS2 Galactic and Cupy on a Docker on the Jetson Xavier NX
I’m trying to run ROS2 Galactic and Cupy on the Jetson Xavier NX. As it is not possible to install ROS2 Galactic natively I am using a docker.
Until now I have only used ROS2 Galactic and it worked perfectly. I create a Dockerfile pulling ros:galactic and used docker buildx to build for the target platform linux/arm64.
Now I want to add cupy. I understand that to install cupy it is necesarry to have cuda installed. So is it possible to install cuda into my existing Docker Image or do I have to use an Docker Image from NVIDIA providing CUDA and then try to install ROS2 Galactic in there?
Im happy for any comments.
Hi @Benutzer636, in order to use GPU, you should use a container based off of l4t-base, like the ROS containers that we have here:
I don’t believe my ROS containers have cupy, but the l4t-ml container does, so you can add the cupy part to my ROS Galactic dockerfile:
https://github.com/dusty-nv/jetson-containers/blob/56bdf7e31037b308b6ef3039175c80a64e5e9d81/Dockerfile.ml#L101
