I am not able to install the BatchTile Plugin using the open source Tensor RT github; are there any proper steps outlining how to do it properly. This is a pre req to run ssd correctly on the jetson nano.
What is the issue now?
Please follow steps in deepstream_tao_apps/TRT-OSS/Jetson at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
After successfully converting to an engine file, when I run the deepstream command I am faced with this error:
** INFO: <bus_callback:181>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:167>: Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
#assertion/home/nvidia/TensorRT/plugin/nmsPlugin/nmsPlugin.cpp,118
Aborted (core dumped)
Several question?
- Which device did you use, nano?
- Did you use Jetpack4.4 to install DS5, cuda10.2, cudnn8 and TRT7?
- Did you follow deepstream_tao_apps/TRT-OSS/Jetson at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub ? And also please care about GPU_ARCHS. For TX1 / NANO , it should be 53
I used the nano and followed those exact steps as mentioned in your 3 questions; I even re did the installation; while it successfully converts into an .engine - the same error comes up when i run SSD:
Please paste below. Thanks.
- $ ll -sh /usr/lib/aarch64-linux-gnu/libnvinfer_plugin*
- If you use tlt-converter to generate the trt engine. Please paste the full command here.
- Your full deepstream command and its full log
- The config file of deepstream.
Another important thing, please make sure your nano has enough disk space when generate trt engine.
Below is the requested information
1:
0 lrwxrwxrwx 1 root root 26 Apr 15 23:34 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so → libnvinfer_plugin.so.7.1.0*
4.5M -rw-r–r-- 1 ishan ishan 4.5M Jun 17 12:31 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7
0 lrwxrwxrwx 1 root root 26 Jun 18 00:03 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.0.0 → libnvinfer_plugin.so.7.1.0*
3.7M -rwxr-xr-x 1 root root 3.7M Jun 18 00:03 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.0*
7.7M -rw-r–r-- 1 root root 7.7M Apr 15 23:34 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin_static.a
2:
I used deepstream to automatically convert into an engine.
3:
Command:
deepstream-app -c deepstream_app_config_detect.txt
Log:
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
0:00:00.305466574 4182 0x3cfd1a10 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
0:01:06.018969732 4182 0x3cfd1a10 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1624> [UID = 1]: serialize cuda engine to file: /home/ishan/Documents/ssd/ssd_mobile_final.etlt_b1_gpu0_fp32.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT Input 3x320x576
1 OUTPUT kFLOAT NMS 1x200x7
2 OUTPUT kFLOAT NMS_1 1x1x1
0:01:07.031271753 4182 0x3cfd1a10 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/ishan/Documents/ssd/pgie_ssd_tlt_config.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
deepstream_app_config_detect.txt (3.0 KB) pgie_ssd_tlt_config.txt (2.5 KB)
So, I am afraid there is something wrong when you replace the libnvinfer_plugin.
Refer to my post Failling in building sample from TLT-DEEPSTREAM - #15 by Morganh
Thanks; got it working.
