Running TAO in Microsoft Azure
Hello, I am hoping to get some assistance and clarification about setting up an Azure VM to run the TAO Toolkit. I have been reading the guide provided by NVIDIA found here: Running TAO on an Azure VM
However, I think this may be a little out of date… On the guide it shows setting up using NVIDIA GPU-Optimized Image for AI and HPC
But I think the names have changed since this was posted. Is the correct image to select the NVIDIA GPU-Optimized VMI?
If so, I was looking at the plans, and noticed that it used Ubuntu 22.04
But I see that TAO requires Ubuntu 20.04 based on what I see here: https://docs.nvidia.com/tao/tao-toolkit-archive/5.2.0/text/tao_toolkit_quick_start_guide.html
For latest 5.5.0 version(NVIDIA TAO - NVIDIA DocsGetting Started - NVIDIA Docs), this page mentions that it uses Ubuntu22.04 now.
Can you also confirm the image NVIDIA GPU-Optimized VMI is the correct image if I am trying to follow the step to run TAO on an Azure VM? The image shown by the setup guide appears to have been changed/renamed.
Thanks,
Andrew
Yes, it is " NVIDIA GPU-Optimized VMI" . The link is: GPU optimized image.
