Hi, I am trying to bring up a Xavier AGX recently purchased from NVidia.
I have a problem with trying to import tensorflow in python3
2021-06-23 11:17:57.405430: W tensorflow/stream_executor/platform/default/dso_loader.cc:60] Could not load dynamic library 'libcudart.so.10.2'; dlerror: libcudart.so.10.2: cannot open shared object file: No such file or directory
2021-06-23 11:17:57.405665: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
My main issue is the incapability of the python environment to identify the position of the libcudart.so.10.2 driver. what might be the problem with the installation process?
When I run the sdkmanager I am facing the following issue when I try to flash the Xavier, it get stucked at 99%. Any suggestions?
JetPack 4.1.1 uses an older CUDA library version.
To reflash Xavier and install components from the latest JP4.5 can set up a compatible environment for TensorFlow.
In general, the flash should finish within an hour.
Do you get it to finish in the end?
