Installed CUDA 10.1.243(update2) from local deb package and cuDNN (7.6.5) and facing the following issue when checking ./mnistCUDNN
cudnnGetVersion() : 7605 , CUDNN_VERSION from cudnn.h : 7605 (7.6.5)
Host compiler version : GCC 7.4.0
There are 1 CUDA capable devices on your machine :
device 0 : sms 36 Capabilities 7.5, SmClock 1710.0 Mhz, MemSize (Mb) 7949, MemClock 7001.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Cublas failure
Error code 1
mnistCUDNN.cpp:404
Aborting...
The same with CUDA 10.2 (and cuDNN 7.6.5.32), works just fine. Is it a known issue?
It might be due to cuDNN-CUDA compatibility issue.
Please refer below link for cuDNN and CUDA/Driver version compatibility:
https://docs.nvidia.com/deeplearning/sdk/cudnn-support-matrix/index.html#cudnn-cuda-hardware-versions
Nope, it’s due to the libcublas library error, there are some issues with symlinks in CUDA 10.1
Refer, https://devtalk.nvidia.com/default/topic/1047981/cuda-setup-and-installation/cublas-for-10-1-is-missing/
Basically, what I did was created a symlink to copy libcublas, and libcublasLt via
sudo ln -s /usr/lib/x86_64-linux-gnu/libcublasLt.so.10.2.1.243 /usr/local/cuda/lib64/libcublasLt.so
sudo ln -s /usr/lib/x86_64-linux-gnu/libcublas.so.10.2.1.243 /usr/local/cuda/lib64/libcublas.so
nauck.c
January 25, 2020, 10:45am
4
Experiencing the same issue with my 1080 Ti. Unfortunately, setting the symbolic links exactly like Cataluna did not solve the problem for me.
Output of ./mnistCUDNN
There are 3 CUDA capable devices on your machine :
device 0 : sms 28 Capabilities 6.1, SmClock 1582.0 Mhz, MemSize (Mb) 11178, MemClock 5505.0 Mhz, Ecc=0, boardGroupID=0
device 1 : sms 28 Capabilities 6.1, SmClock 1582.0 Mhz, MemSize (Mb) 11178, MemClock 5505.0 Mhz, Ecc=0, boardGroupID=1
device 2 : sms 28 Capabilities 6.1, SmClock 1582.0 Mhz, MemSize (Mb) 11176, MemClock 5505.0 Mhz, Ecc=0, boardGroupID=2
Using device 0
Cublas failure
Error code 1
mnistCUDNN.cpp:404
Aborting...
UPDATE: Solved the issue by downgrading the version to 10.2.1.243 like Cataluna proposed but additionally replacing the symlinks inside the /usr/lib/x86_64-linux-gnu/ folder:
sudo ln -s /usr/lib/x86_64-linux-gnu/libcublasLt.so.10.2.1.243 /usr/lib/x86_64-linux-gnu/libcublasLt.so.10
sudo ln -s /usr/lib/x86_64-linux-gnu/libcublas.so.10.2.1.243 /usr/lib/x86_64-linux-gnu/libcublas.so.10
