Actually I have a legacy code which has video encoder and renderer enabled.
But my requirement is to run video encoder with disabled renderer.
I think, the presence of below mentioned lines in my code enables renderer.
EGLDisplayHolder g_display;
g_object_set(G_OBJECT(videoSource), "display", g_display.get(), NULL);
g_object_set(G_OBJECT(videoSource), "eglstream", eglStream, NULL);
Window &window = Window::getInstance();
PROPAGATE_ERROR(g_display.initialize(window.getEGLNativeDisplay()));
I also referred sample code “gstVideoEncode” given in argus examples.
But it has also renderer enabled.
Please look at the argus sample code “tegra_multimedia_api/argus/samples/gstVideoEncode/main.cpp”.
Is there a way to avoid using g_display and disable renderer ?
Thanks in advance.
