Running VideoMaMa on NVIDIA DGX Spark (ARM64 / GB10)
Platform: Lenovo ThinkStation PGX — NVIDIA GB10 Blackwell Superchip, 128GB unified memory, DGX OS, CUDA 13.0, Driver 580.142
This guide documents how to get VideoMaMa — a video matting model combining SAM2 mask tracking with Stable Video Diffusion — running on the DGX Spark. Several ARM64-specific issues needed to be resolved that don’t appear on x86 systems.
What is VideoMaMa?
VideoMaMa is a video matting pipeline that:
- Uses SAM2 to track an object through video frames based on user click prompts
- Uses a fine-tuned Stable Video Diffusion UNet to generate high-quality alpha mattes
- Provides a Gradio web UI for interactive use
Checkpoint Structure
Download the following checkpoints and place them as shown:
checkpoints/
├── VideoMaMa/ # HuggingFace: cvlab-kaist/VideoMaMa
│ ├── dino_projection_mlp.pth
│ └── unet/
│ ├── config.json
│ └── diffusion_pytorch_model.safetensors
├── sam2/ # Meta: facebook/sam2
│ └── sam2.1_hiera_large.pt
└── stable-video-diffusion-img2vid-xt/ # HuggingFace: stabilityai/stable-video-diffusion-img2vid-xt
├── model_index.json
├── feature_extractor/
├── image_encoder/
└── vae/
ARM64 Issues and Fixes
Fix 1 — Gradio version incompatibility
Gradio 4.x introduced a streaming WebSocket path in gradio-client that throws Method not implemented on ARM64, silently breaking all UI events including .select() clicks. No JS errors surface until you open DevTools:
stream.ts:185 Method not implemented.
api_info.ts:401 Too many arguments provided for the endpoint.
Fix: Pin to Gradio 3.50.2 + gradio-client 0.6.1 which uses a polling approach that works reliably on ARM64.
RUN uv pip install --no-cache "gradio==3.50.2" "gradio-client==0.6.1" --system
Fix 2 — Hardcoded localhost binding
The upstream app.py binds Gradio to 127.0.0.1, making the UI unreachable from outside the container even with port mapping. Patched to 0.0.0.0.
Fix 3 — gr.SelectData events silently fail on ARM64
Even with Gradio 3.50.2, gr.SelectData click events on gr.Image don’t reach Python on ARM64. Additionally, gr.HTML() strips <script> tags in Gradio 3.50.2 as a security measure, so the JS fix can’t be injected that way.
Fix: Replace .select() with a hidden textbox + hidden button wired to demo.load(_js=...):
- JS
onclickcaptures pixel coordinates from the image element - Coordinates are written to a hidden
gr.Textbox - A hidden
gr.Buttonis programmatically clicked to trigger the Python backend - The JS handler is injected via
demo.load(_js=...)which Gradio 3.x executes reliably
Fix 4 — OOM on long videos
VideoMaMa is built on Stable Video Diffusion which has a native 25-frame context window. Passing all frames at once (e.g. 121 frames) causes an out-of-memory crash that can take down the entire system — GB10 uses unified memory shared between CPU and GPU.
Fix: Chunked inference wrapper that processes 25-frame overlapping windows and frees memory between chunks with torch.cuda.empty_cache().
Memory budget on GB10 (128GB unified):
| Component | Memory |
| SAM2 + SVD UNet + DINO (idle) | ~20GB |
| Per 25-frame chunk @ 1024×576 fp16 | ~51GB |
| Available headroom | ~57GB ✅ |
Docker Setup
docker-compose.yml
services:
video-mama:
build:
context: .
dockerfile: Dockerfile
container_name: video-mama
volumes:
- ./checkpoints:/workspace/VideoMaMa/checkpoints
- pip-cache:/root/.cache
ports:
- "7860:7860"
environment:
- CUDA_VISIBLE_DEVICES=0
ipc: host
deploy:
resources:
reservations:
devices:
- driver: nvidia
count: all
capabilities: [gpu]
volumes:
pip-cache:
Dockerfile
# Use existing local SM121-capable torch — no download needed
FROM vllm-node-tf5:latest
ENV DEBIAN_FRONTEND=noninteractive
ENV PYTHONUNBUFFERED=1
RUN apt-get update && apt-get install -y --no-install-recommends \
ffmpeg cmake \
libavformat-dev libavcodec-dev libavdevice-dev libavutil-dev \
libswscale-dev libswresample-dev libavfilter-dev pkg-config \
libx11-dev \
&& rm -rf /var/lib/apt/lists/*
RUN pip install uv
WORKDIR /workspace
RUN git clone https://github.com/cvlab-kaist/VideoMaMa.git /workspace/VideoMaMa
WORKDIR /workspace/VideoMaMa
RUN uv pip install --no-cache git+https://github.com/facebookresearch/sam2.git --system
RUN uv pip install --no-cache --no-deps \
"git+https://github.com/EasternJournalist/utils3d.git#egg=utils3d" --system
RUN uv pip install --no-cache --no-deps -e . --system
RUN DS_BUILD_OPS=0 uv pip install --no-cache deepspeed==0.17.1 --system || \
echo "deepspeed skipped, continuing..."
RUN uv pip install --no-cache --system \
"accelerate>=1.9.0" \
"diffusers>=0.31.0" \
"opencv-python-headless>=4.9.0.80" \
"tokenizers>=0.20.3" \
"transformers==4.57.0" \
"numpy>=1.23.5,<2" \
psutil \
matplotlib \
scipy \
setuptools \
omegaconf \
tabulate \
pandas \
wandb \
datasets \
"peft>0.15" \
easydict \
"boto3>=1.37.22" \
ftfy \
scikit-image \
moviepy \
pyarrow \
imageio imageio-ffmpeg \
pycocotools \
einops safetensors \
timm
# Install gradio 3.50.2 + gradio-client 0.6.1 — matches the working WSL install.
# Gradio 4.x introduced a streaming WebSocket path in gradio-client that throws
# "Method not implemented" on ARM64, breaking all events including .select().
# Patch app.py:
# 1. Bind to 0.0.0.0 so the port is reachable from the host
# 2. Disable frpc share link (port is exposed directly via Docker)
# 3. Fix gr.State(None) → gr.State({}) to avoid JS schema serialization
# errors that silently prevent .select() click events on ARM64
# 4. Replace broken .select() with JS onclick → hidden textbox → gr.Button
# workaround (Gradio 4.44 .select() silently fails on ARM64 browsers)
RUN python3 - << 'EOF'
path = "/workspace/VideoMaMa/demo/app.py"
src = open(path).read()
src = src.replace('server_name="127.0.0.1"', 'server_name="0.0.0.0"')
# Fix image display size to match video player width
src = src.replace(
'button {border-radius: 8px !important;}',
'button {border-radius: 8px !important;}\n'
'#first_frame_display img { width: 100% !important; height: 100% !important; object-fit: contain !important; }\n'
'#first_frame_display { min-height: 440px !important; }'
src = src.replace('share=True', 'share=False')
# Hide the frames slider — we now process all frames always
src = src.replace(
'num_frames_slider = gr.Slider(',
'num_frames_slider = gr.Slider(visible=False,'
src = src.replace('video_state = gr.State(None)', 'video_state = gr.State({})')
src = src.replace('if video_state is None or', 'if not video_state or')
src = src.replace('if video_state is None:', 'if not video_state:')
# Patch videomama_wrapper.py to process frames in 25-frame chunks
# (VideoMaMa is based on SVD which has a fixed 25-frame context window;
# passing all frames at once OOMs the system)
wrapper_patch = '''
import torch
import numpy as np
from PIL import Image
_original_videomama = videomama
def videomama(pipeline, frames_np, mask_frames_np, chunk_size=25, overlap=4):
Chunked VideoMaMa inference — processes video in overlapping windows
to avoid OOM on long videos. chunk_size=25 matches SVD context window.
n = len(frames_np)
if n <= chunk_size:
return _original_videomama(pipeline, frames_np, mask_frames_np)
print(f"Processing {n} frames in chunks of {chunk_size} (overlap={overlap})...")
output_frames = []
start = 0
while start < n:
end = min(start + chunk_size, n)
chunk_frames = frames_np[start:end]
chunk_masks = mask_frames_np[start:end]
print(f" Chunk {start}-{end} ({len(chunk_frames)} frames)...")
chunk_out = _original_videomama(pipeline, chunk_frames, chunk_masks)
# Skip overlap frames from previous chunk to avoid seam artifacts
skip = overlap if start > 0 else 0
output_frames.extend(chunk_out[skip:])
# Advance by chunk_size minus overlap for smooth transitions
start += chunk_size - overlap
# Free memory between chunks
return output_frames[:n]
# Append the chunked wrapper to videomama_wrapper.py
vw_path = "/workspace/VideoMaMa/demo/videomama_wrapper.py"
vw_src = open(vw_path).read()
vw_src += "\n" + wrapper_patch
open(vw_path, "w").write(vw_src)
print("[DONE] Patched videomama_wrapper.py with chunked inference")
# Always process all frames at original FPS — no sampling, no FPS adjustment
old_extract = ''' # If video has more frames than max_frames, randomly sample
if len(all_frames) > max_frames:
print(f"Video has {len(all_frames)} frames, randomly sampling {max_frames} frames...")
# Sort indices to maintain temporal order
sampled_indices = sorted(np.random.choice(len(all_frames), max_frames, replace=False))
frames = [all_frames[i] for i in sampled_indices]
print(f"Sampled frame indices: {sampled_indices}")
# Adjust FPS to maintain normal playback speed
# If we sampled N frames from M total frames, adjust FPS proportionally
adjusted_fps = original_fps * (len(frames) / len(all_frames))
else:
frames = all_frames
print(f"Video has {len(frames)} frames (≤ {max_frames}), using all frames")
print(f"Using {len(frames)} frames from video (Original FPS: {original_fps:.2f}, Adjusted FPS: {adjusted_fps:.2f})")
return frames, adjusted_fps'''
new_extract = ''' frames = all_frames
print(f"Using all {len(frames)} frames at original FPS: {original_fps:.2f}")
return frames, original_fps'''
src = src.replace(old_extract, new_extract)
# Patch sam_refine to accept coords from hidden textbox instead of gr.SelectData
old_fn = '''def sam_refine(video_state, point_prompt, click_state, evt: gr.SelectData):
Add click and update mask on first frame
Args:
video_state: Dictionary with video data
point_prompt: "Positive" or "Negative"
click_state: [[points], [labels]]
evt: Gradio SelectData event with click coordinates
if not video_state or "frames" not in video_state:
return None, video_state, click_state
# Add new click
x, y = evt.index[0], evt.index[1]'''
new_fn = '''def sam_refine(video_state, point_prompt, click_state, click_coords):
Add click and update mask on first frame.
click_coords: JSON string "[x, y]" from hidden textbox via JS onclick.
if not click_coords:
import json as _json
try:
coords = _json.loads(click_coords)
x, y = int(coords[0]), int(coords[1])
except Exception:
return None, video_state, click_state'''
src = src.replace(old_fn, new_fn)
# Replace the gr.Image block and .select() wiring with JS onclick version
old_image = ''' first_frame_display = gr.Image(
label="First Frame",
type="pil",
interactive=True
new_image = ''' first_frame_display = gr.Image(
type="pil",
interactive=True,
elem_id="first_frame_display"
click_coords = gr.Textbox(value="", visible=False, elem_id="click_coords")
click_trigger = gr.Button("__click_trigger__", visible=False, elem_id="click_trigger")'''
src = src.replace(old_image, new_image)
# Replace .select() wiring with .click() on the hidden trigger button
old_select = ''' first_frame_display.select(
fn=sam_refine,
inputs=[video_state, point_prompt, click_state],
outputs=[first_frame_display, video_state, click_state]
new_select = ''' # Use _js to inject click handler via Gradio 3.x's built-in JS support.
# gr.HTML() strips <script> tags in Gradio 3.50.2, so we attach the handler
# via the load event's _js parameter which executes reliably.
click_trigger.click(
fn=sam_refine,
inputs=[video_state, point_prompt, click_state, click_coords],
# Inject JS via demo.load which runs after the page is ready
def noop():
return None
demo.load(
fn=noop,
inputs=[],
outputs=[],
_js="""
let attachedImg = null;
function attachClickHandler() {
const img = document.querySelector('#first_frame_display img');
const coordBox = document.querySelector('#click_coords textarea');
const btn = document.querySelector('#click_trigger');
if (!img || !coordBox || !btn) return;
if (img === attachedImg) return;
attachedImg = img;
img.style.cursor = 'crosshair';
img.addEventListener('click', function(e) {
const rect = img.getBoundingClientRect();
const scaleX = img.naturalWidth / rect.width;
const scaleY = img.naturalHeight / rect.height;
const x = Math.round((e.clientX - rect.left) * scaleX);
const y = Math.round((e.clientY - rect.top) * scaleY);
coordBox.value = JSON.stringify([x, y]);
coordBox.dispatchEvent(new Event('input', {bubbles: true}));
setTimeout(() => btn.click(), 50);
console.log('VideoMaMa: click handler attached');
setInterval(attachClickHandler, 300);
attachClickHandler();
src = src.replace(old_select, new_select)
open(path, "w").write(src)
print("[DONE] Patched app.py with JS onclick workaround")
EOF
ENV PYTHONPATH=/workspace/VideoMaMa
CMD ["python3", "/workspace/VideoMaMa/demo/app.py"]
Usage
# Build and start
cd VideoMaMa
docker compose build
docker compose up -d video-mama
# Access the UI
http://<your-dgx-ip>:7860
# Monitor inference
docker logs -f video-mama
Workflow:
- Upload a video
- Click Load Video
- Click on the object in the first frame (crosshair cursor)
- Add Positive/Negative clicks to refine the mask
- Click 🚀 Run Matting
Performance (DGX Spark, GB10)
| Stage | Details | Time |
| SAM2 tracking | 121 frames | ~40s |
| VideoMaMa inference | per 25-frame chunk | ~varies by video resolution |
| Total memory at inference | models + one chunk | ~71GB / 128GB |
Notes
- The base image
vllm-node-tf5is a community SM121-optimized image for the GB10 Blackwell. Any ARM64 CUDA 13 base with PyTorch should work as a substitute — just ensure SM121 support for the GB10. - Chunked inference with
overlap=4produces smooth transitions. Increase overlap if you see seam artifacts between chunks. - Output videos (matting result, mask track, greenscreen composite) are saved to
./outputs/inside the container and served via the Gradio UI. - The
frpcARM64 binary for Gradio’s share link feature is unavailable — expose the port directly via Docker instead.
