i have 2 questions
1.i m running visionworks samples in the folder VisionWorks-1.6-Samples/bin/aarch64/linux/release…
when i run samples,i m getting these error
VisionWorks library info:
VisionWorks version : 1.6.0
OpenVX Standard version : 1.1.0
Error: Can’t open source URI /home/dlinano/VisionWorks-1.6-Samples/bin/…/data/signs.avi
i have tried the command export DISPLAY=:1, and export DISPLAY=:0 also.
still i m getting the same error…
2.also i need to pass image instead of video…
im executing with below command
./nvx_demo_hough_transform --source=/home/dlinano/VisionWorks-1.6-Samples/data/baboon.jpg
but i m getting same error.
please help me in these context
Could you double check if this file is exist?
ok…
i m getting these error while running it.
dlinano@jetson-nano:~/V-samples/bin/aarch64/linux/release$ ./nvx_demo_feature_tracker -s “/home/dlinano/V-samples/data/pad.bmp”
[NVX LOG] nvxuHoughCircles: CUDA error: the launch timed out and was terminated
-1002[NVX LOG] vxQueryArray: CUDA error: the launch timed out and was terminated
Found 0 circles
[NVX LOG] CUDA stream destroy error: the launch timed out and was terminated
please help me in fixing it
Would you mind to check this command instead?
$ ./nvx_demo_feature_tracker --source=/home/dlinano/V-samples/data/pad.bmp
For more information, please find our document here:
https://developer.nvidia.com/embedded/dlc/visionworks-1-6-documentation-for-l4t-27-1
