Running wrf 3dvar
Hi Mat,
I have problem in running 3dvar.When i run the script
./DA_Run_3DVAR.csh.
i get the message see below:
[root@drizzle run]# ./DA_Run_3DVAR.csh
unlimit: descriptors: Can’t remove limit
So i tried the following :
  1. I removed the “unlimit” in the script,i got this message
see below:
Running script DA_Run_3DVAR
setenv: Too many arguments.
  1. I use the “ulimit” in the script , i get
/usr/bin/perl/ulimit: Not a directory.
[root@drizzle run]#
Also i check the ulimit in the command line i got the msg
[root@drizzle run]# ulimit
unlimited:
So i wonder what is wrong,
Peter
Hi Peter,
Two different issues are happening. The ‘setenv’ error your getting occurs when you use spaces when setting a environment variable. (ex setenv PATH my path). My guess is that you have not edited the ‘DA_Run_3DVAR.csh’ and added the actual paths for WRF_DIR, DAT_DIR, and RUN_DIR (lines 68-70). I was unable to find anything in the documentation about needing to do this. I guess they assume you’d just know!
The problem with ‘unlimit’ is most likely caused by your administrator not letting users adjust the number of file descriptors available. What you really need to do is set the available stack size to a really large number, else your executable will seg fault. Try doing the following:
csh
limit
limit stacksize 1000m
limit
You should see the stack size be set to 1024000 kbytes. Once you have your stack size set large enough and have edited your run script, try running again (your edited version without the ‘unlimit’). If you get a seg fault, set the stack size to an even larger value.
  • Mat
Hi Mat,
I still get this message:
I have set three environment variables DAT_DIR,RUN_DIR,WRF_DIR in the script w’thout spaces,but with the tab n still get msg above.
see below:
setenv WRF_DIR /home/3dvar/dat_dir/wrf3dvar ‘Enter full path of wrf3dvar code directory here’
setenv DAT_DIR /home/3dvar/dat_dir ‘Enter full path of directory containing input files here’
setenv RUN_DIR /home/3dvar/run_dir ‘Enter full path of directory you want output to go here’
But i’m using Bash shell,can it be the cause of the problem?
thanks,
petero
I should have said ‘replace’ the paths instead of ‘add’.
  • Mat
Mat,
Thanks ,i have solved the problem.
The shell was still treating those comment in single quotes as arguments,so i removed the single quotes and use pound sign and the shell treated them as comments, so i run succesfully.
petero.
