Hello!
The latest version of CuDNN runtime has undefined references to std::string. This makes it necessary to link with the system stdc++ library. There are cases when linking the system stdc++ is not desirable, such as having a tweaked STL. A previous version of CuDNN runtime did not depend on std::string, but was dependent on std::ios_base ctor/dtor, which was easy to stub. Dependence on std::string is troublesome.
Is it possible to fix this issue?
Dima
