Required Info | |
Camera Model | { D400 } |
Firmware Version | v2.50.13 |
Operating System & Version | Ubuntu 20.04 |
Kernel Version (Linux Only) | 5.10.104-tegra |
Platform | NVIDIA Jetson& Docker |
SDK Version | { 2.50.13 } |
Language | python } |
Segment | {Other } |
Issue Description
I have a FRAMOS D455e stereo camera connected to Nvidia Jetson ORIN with Jetpack 5.1 via ethernet port (not PoE).
I successfully created a Docker image to run my Computer Vision application using the camera following the instructions unpacked from FRAMOS_D400e_Software_Package_Linux64_ARM_latest and extracted with the debian package under ~/librealsense2/scripts/Docker_FRAMOS/Dockerfile
I can successfully run rs-enumerate-devices
, rs-color
and rs-depth
inside the docker container.
The python example scripts I managed to run and get the expected output from:
python3 librealsense2/wrappers/python/examples/python-tutorial-1-depth.py # changed import pyrealsense2 as rs ---> import pyrealsense2.pyrealsense2 as rs
BUT when I apply the same technique to read color frames, as exhibited in the script `opencv_viewer_example.py’ I get this error:
RuntimeError: Frame didn't arrive within 5000
How can I proceed? Thank you
