RuntimeError: normal expects all elements of std >= 0.0 when running custom articulation task
I have a custom manipulator that is using the same articulation task that the ShadowHand uses and I am finding that I get the following error:
File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/rl_games/torch_runner.py", line 121, in run
    self.run_train(args)
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/rl_games/torch_runner.py", line 102, in run_train
    agent.train()
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/rl_games/common/a2c_common.py", line 1226, in train
    step_time, play_time, update_time, sum_time, a_losses, c_losses, b_losses, entropies, kls, last_lr, lr_mul = self.train_epoch()
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/rl_games/common/a2c_common.py", line 1090, in train_epoch
    batch_dict = self.play_steps()
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/rl_games/common/a2c_common.py", line 664, in play_steps
    res_dict = self.get_action_values(self.obs)
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/rl_games/common/a2c_common.py", line 385, in get_action_values
    res_dict = self.model(input_dict)
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/extscache/omni.pip.torch-1_13_1-0.1.4+104.2.lx64/torch-1-13-1/torch/nn/modules/module.py", line 1194, in _call_impl
    return forward_call(*input, **kwargs)
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/python/lib/python3.7/site-packages/rl_games/algos_torch/models.py", line 263, in forward
    selected_action = distr.sample()
  File "/home/username/.local/share/ov/pkg/isaac_sim-2022.2.1/extscache/omni.pip.torch-1_13_1-0.1.4+104.2.lx64/torch-1-13-1/torch/distributions/normal.py", line 70, in sample
    return torch.normal(self.loc.expand(shape), self.scale.expand(shape))
Based on this error I’m guessing that the function is struggling to read all action values based on the get_action_values calls. For my manipulator, where do I need to look for how my actions are defined? Would this be a matter of a poorly defined task or are these parameters within the yaml file I need to adjust?
Hi there, this error generally means that the policy received a buffer that contained NaNs. In most cases, the NaNs come from the observation buffer. A good way to verify this is to double check the values in the observation buffer in the task before passing it to the RL policy. The source of the NaNs could be from unstable simulation, which can likely be tuned by modifying physics parameters in the assets or physics scene and making sure that the controller is applying valid actions.
Hey!
I’ve decided to plot what I am finding with my observation buffer and I am finding that the values I am getting are consistently on the second step it calls, otherwise it seems that the system initialises.
Here is my print function in my get_observation(self) to show all these values:
        print(self.obs_type)
        print(self.obs_buf.shape)
        print(type(self.obs_buf))
        print("unscale(self.hand_dof_pos, self.hand_dof_lower_limits, self.hand_dof_upper_limits)")
        print(self.obs_buf[:, 0:self.num_hand_dofs].shape)
        print(self.obs_buf[:, 0:self.num_hand_dofs])
        print(unscale(self.hand_dof_pos,
                self.hand_dof_lower_limits, self.hand_dof_upper_limits).shape)
                self.hand_dof_lower_limits, self.hand_dof_upper_limits))
        print("self.object_pos")
        print(self.obs_buf[:, 19:22])
        print(self.object_pos)
        print("self.object_rot")
        print(self.obs_buf[:, 22:26])
        print(self.object_rot)
        print("self.goal_pos")
        print(self.obs_buf[:, 26:29])
        print(self.goal_pos)
        print("self.goal_rot")
        print(self.obs_buf[:, 29:33])
        print(self.goal_rot)
        print("quat_mul(self.object_rot, quat_conjugate(self.goal_rot))")
        print(self.obs_buf[:, 33:37])
        print(quat_mul(self.object_rot, quat_conjugate(self.goal_rot)))
        print("self.fingertip_pos.reshape(self.num_envs, 3*self.num_fingertips)")
        print(self.obs_buf[:, 37:52].shape)
        print(self.obs_buf[:, 37:52])
        print(self.fingertip_pos.reshape(self.num_envs, 3*self.num_fingertips).shape)
        print(self.fingertip_pos.reshape(self.num_envs, 3*self.num_fingertips))
        print("self.actions")
        print(self.obs_buf[:, 52:70].shape)
        print(self.obs_buf[:, 52:70])
        print(self.actions.shape)
        print(self.actions)
And this is the output I find
[2023-10-26 10:57:12] Running RL reset
full
torch.Size([512, 157])
<class 'torch.Tensor'>
torch.Size([512, 19])
tensor([[-2.7106e+19, -4.6850e+18, -1.4326e+20,  ..., -5.3496e+18,
          6.5728e+19, -4.2172e+18],
        [-2.7284e+19, -7.4511e+18, -1.5910e+20,  ..., -1.3316e+19,
          7.2489e+19, -1.0030e+18],
        [-8.4951e+19, -1.9560e+19, -4.5132e+20,  ..., -1.8580e+19,
          2.2441e+20, -7.2675e+18],
        [-1.9062e+18, -3.4884e+17, -9.9040e+18,  ..., -2.9903e+17,
          4.5146e+18, -2.2122e+17],
        [ 7.0171e+18,  1.8247e+18,  2.8405e+19,  ...,  2.1454e+18,
         -1.2537e+19,  7.2946e+17],
        [ 2.3270e+18,  4.8319e+17,  9.9849e+18,  ...,  5.9163e+17,
         -4.7495e+18,  2.8657e+17]], device='cuda:0')
self.object_pos
tensor([[-8.4833e+21, -7.3835e+20, -2.2198e+22],
        [-7.9510e+21, -1.1100e+21, -2.3025e+22],
        [-2.6600e+22, -3.0766e+21, -7.0042e+22],
        [-5.9590e+20, -5.4812e+19, -1.5350e+21],
        [ 2.2780e+21,  2.9395e+20,  4.7164e+21],
        [ 7.5931e+20,  7.7700e+19,  1.6592e+21]], device='cuda:0')
tensor([[ 0.0023, -0.2398,  0.5959],
        [-0.0006, -0.2216,  0.6022],
        [-0.0063, -0.2329,  0.6030],
        [ 0.0044, -0.2347,  0.5892],
        [-0.0076, -0.2301,  0.5947],
        [ 0.0027, -0.2242,  0.5920]], device='cuda:0')
self.object_rot
tensor([[ 5.8964e+22,  1.5363e+22,  1.3487e+23, -2.1843e+23],
        [ 7.3229e+22, -4.3851e+22,  7.3476e+23, -4.9108e+23],
        [ 1.7563e+23,  6.9460e+22,  4.4650e+23, -7.0023e+23],
        [ 2.8840e+21,  2.1888e+21,  9.9195e+21, -1.3566e+22],
        [-1.0801e+22, -1.0295e+21, -3.4238e+22,  1.1092e+23],
        [-3.9277e+21, -3.1532e+21, -8.1248e+21,  3.3907e+22]], device='cuda:0')
tensor([[ 0.0595, -0.4677, -0.1114,  0.8748],
        [ 0.1791, -0.5222,  0.2705, -0.7887],
        [ 0.4778, -0.3883,  0.6115, -0.4970],
        [ 0.1742, -0.4895, -0.2864,  0.8050],
        [ 0.3821, -0.0880,  0.8965, -0.2064],
        [ 0.8855, -0.2252, -0.3938,  0.1002]], device='cuda:0')
self.goal_pos
tensor([[ 5.9488e+21, -2.6233e+22,  6.9139e+22],
        [ 5.6819e+21, -7.2834e+22,  3.7922e+23],
        [ 1.6076e+22, -7.4109e+22,  1.8002e+23],
        [ 5.3549e+20, -3.9982e+20,  5.3106e+21],
        [-6.2756e+20,  4.4690e+21, -2.0789e+22],
        [-2.6929e+20,  6.9501e+20, -6.8168e+20]], device='cuda:0')
tensor([[ 0.0000, -0.2300,  0.5600],
        [ 0.0000, -0.2300,  0.5600]], device='cuda:0')
self.goal_rot
tensor([[-1.7945e+23,  6.4769e+23, -7.4232e+21, -2.2230e+20],
        [-1.4681e+24,  1.2916e+24, -7.4893e+21, -4.9259e+20],
        [-6.1295e+23,  2.0695e+24, -2.4071e+22,  2.7901e+16],
        [-1.4459e+22,  4.0402e+22, -4.6500e+20, -2.1988e+19],
        [ 5.9020e+22, -2.6373e+23,  1.0983e+21,  3.0378e+21],
        [ 1.1347e+22, -8.1807e+22,  4.8356e+20, -2.7648e+17]], device='cuda:0')
tensor([[ 0.0152,  0.3937, -0.0355, -0.9184],
        [ 0.6872,  0.6637,  0.2125,  0.2053],
        [ 0.5651,  0.6532,  0.3297,  0.3811],
        [ 0.1421,  0.7993, -0.1022, -0.5749],
        [ 0.2919, -0.1083,  0.8909, -0.3306],
        [ 0.1964, -0.1767, -0.7170,  0.6451]], device='cuda:0')
tensor([[-7.8576e+19, -1.6329e+21, -8.5455e+20,  1.0128e+22],
        [ 1.3534e+23,  7.8607e+20, -2.0361e+21,  1.0344e+22],
        [-2.1815e+20, -3.4277e+20, -2.9518e+21,  3.4718e+22],
        [-6.6304e+19, -1.5157e+18, -4.7317e+19,  6.9647e+20],
        [ 2.5963e+19,  2.1001e+18,  3.3997e+20, -2.1074e+21],
        [ 4.1819e+18,  7.5831e+18,  9.4548e+19, -7.9512e+20]], device='cuda:0')
tensor([[-0.9827, -0.1639,  0.0855,  0.0076],
        [-0.3280, -0.7009,  0.5641, -0.2882],
        [ 0.0286, -0.9284,  0.3647,  0.0645],
        [-0.8000, -0.4557, -0.3849, -0.0645],
        [ 0.9880,  0.1282, -0.0719,  0.0473],
        [ 0.5607,  0.2945,  0.4300, -0.6434]], device='cuda:0')
torch.Size([512, 15])
tensor([[-6.7231e+20,  0.0000e+00,  0.0000e+00,  ..., -2.3980e-01,
          5.9592e-01,  5.9541e-02],
        [-1.2883e+20,  0.0000e+00,  0.0000e+00,  ..., -2.2159e-01,
          6.0221e-01,  1.7909e-01],
        [-1.1470e+21,  0.0000e+00,  0.0000e+00,  ..., -2.3290e-01,
          6.0295e-01,  4.7780e-01],
        [-3.5815e+19,  0.0000e+00,  0.0000e+00,  ..., -2.3466e-01,
          5.8924e-01,  1.7419e-01],
        [ 1.1671e+20,  0.0000e+00,  0.0000e+00,  ..., -2.3005e-01,
          5.9474e-01,  3.8206e-01],
        [ 4.6321e+19,  0.0000e+00,  0.0000e+00,  ..., -2.2423e-01,
          5.9203e-01,  8.8552e-01]], device='cuda:0')
tensor([[-0.0361, -0.2985,  0.5130,  ..., -0.0840, -0.2049,  0.5105],
        [-0.0361, -0.2985,  0.5130,  ..., -0.0840, -0.2049,  0.5105]],
       device='cuda:0')
self.actions
torch.Size([512, 18])
tensor([[-0.4677, -0.1114,  0.8748,  ..., -0.9184, -0.9827, -0.1639],
        [-0.5222,  0.2705, -0.7887,  ...,  0.2053, -0.3280, -0.7009],
        [-0.3883,  0.6115, -0.4970,  ...,  0.3811,  0.0286, -0.9284],
        [-0.4895, -0.2864,  0.8050,  ..., -0.5749, -0.8000, -0.4557],
        [-0.0880,  0.8965, -0.2064,  ..., -0.3306,  0.9880,  0.1282],
        [-0.2252, -0.3938,  0.1002,  ...,  0.6451,  0.5607,  0.2945]],
       device='cuda:0')
tensor([[0., 0., 0.,  ..., 0., 0., 0.],
        [0., 0., 0.,  ..., 0., 0., 0.]], device='cuda:0')
full
tensor([[nan, nan, nan,  ..., nan, nan, nan],
        [nan, nan, nan,  ..., nan, nan, nan]], device='cuda:0')
self.object_pos
tensor([[nan, nan, nan],
        [nan, nan, nan],
        [nan, nan, nan],
        [nan, nan, nan],
        [nan, nan, nan],
        [nan, nan, nan]], device='cuda:0')
tensor([[ 0.0023, -0.2398,  0.5912],
        [-0.0006, -0.2216,  0.5974],
        [-0.0063, -0.2329,  0.5982],
        [ 0.0044, -0.2347,  0.5845],
        [-0.0076, -0.2301,  0.5900],
        [ 0.0027, -0.2242,  0.5873]], device='cuda:0')
self.object_rot
tensor([[nan, nan, nan, nan],
        [nan, nan, nan, nan]], device='cuda:0')
self.goal_pos
        [nan, nan, nan],
        [nan, nan, nan],
        [nan, nan, nan],
        [nan, nan, nan],
self.goal_rot
tensor([[    nan,  0.0000,  0.0000,  ..., -0.2398,  0.5912,  0.0595],
        [    nan,  0.0000,  0.0000,  ..., -0.2216,  0.5974,  0.1791],
        [    nan,  0.0000,  0.0000,  ..., -0.2329,  0.5982,  0.4778],
        [    nan,  0.0000,  0.0000,  ..., -0.2347,  0.5845,  0.1742],
        [    nan,  0.0000,  0.0000,  ..., -0.2301,  0.5900,  0.3821],
        [    nan,  0.0000,  0.0000,  ..., -0.2242,  0.5873,  0.8855]],
       device='cuda:0')
self.actions
       device='cuda:0')
tensor([[-0.5776,  1.0000,  0.5270,  ...,  0.2500, -1.0000, -0.9111],
        [ 0.0017, -0.4264,  1.0000,  ...,  1.0000, -1.0000, -0.2598],
        [-0.4309,  0.3819,  0.1305,  ...,  0.4660,  0.4254, -1.0000],
        [ 0.4382,  1.0000, -0.7657,  ...,  1.0000, -0.4103, -0.3327],
        [ 0.0828,  0.1702,  0.4420,  ..., -0.0640,  0.1705,  0.7118],
        [-0.3522, -0.5169,  0.8220,  ...,  0.8664,  1.0000, -0.6398]],
       device='cuda:0')
Error executing job with overrides: ['task=RH8D', 'num_envs=512', 'headless=False']
Would this likely be a bad set-up of the physical parameters itself or is this likely an issue with setting up the custom classes incorrectly for the articulation and/or articulation view? My interpretation is that the hand_dof_pos and fingertip_pos are not being read properly.
I’ve done a bit more testing and I find that slightly increasing the time step (dt) valid can reduce the number of nan found in the observation buffer. I’m wondering if it’s something to do with the speed which the observation buffer can count, or if it’s just an unstable simulation.
Hi there, I suspect it may be due to the actions that are being applied after the first step, which lead the simulation into a bad state. Try verifying that the actions are within the limits of the joints and won’t cause instabilities in the simulation. You can also try running the simulation with just random actions or zero actions to see whether the issue still occurs.
