I just tried to deploy my rust program on k3s on Jetson, got the following error:
error: failed to run custom build command for `libsqlite3-sys v0.18.0`
Caused by:
process didn't exit successfully: `/app/target/debug/build/libsqlite3-sys-4bfc4b965c533b72/build-script-build` (exit status: 1)
--- stdout
cargo:rerun-if-env-changed=SQLITE_MAX_VARIABLE_NUMBER
cargo:rerun-if-env-changed=SQLITE_MAX_EXPR_DEPTH
TARGET = Some("aarch64-unknown-linux-musl")
OPT_LEVEL = Some("0")
HOST = Some("aarch64-unknown-linux-musl")
CC_aarch64-unknown-linux-musl = None
CC_aarch64_unknown_linux_musl = None
HOST_CC = None
CC = None
CFLAGS_aarch64-unknown-linux-musl = None
CFLAGS_aarch64_unknown_linux_musl = None
HOST_CFLAGS = None
CFLAGS = None
CRATE_CC_NO_DEFAULTS = None
DEBUG = Some("true")
CARGO_CFG_TARGET_FEATURE = None
running: "cc" "-O0" "-ffunction-sections" "-fdata-sections" "-fPIC" "-g" "-fno-omit-frame-pointer" "-DSQLITE_CORE" "-DSQLITE_DEFAULT_FOREIGN_KEYS=1" "-DSQLITE_ENABLE_API_ARMOR" "-DSQLITE_ENABLE_COLUMN_METADATA" "-DSQLITE_ENABLE_DBSTAT_VTAB" "-DSQLITE_ENABLE_FTS3" "-DSQLITE_ENABLE_FTS3_PARENTHESIS" "-DSQLITE_ENABLE_FTS5" "-DSQLITE_ENABLE_JSON1" "-DSQLITE_ENABLE_LOAD_EXTENSION=1" "-DSQLITE_ENABLE_MEMORY_MANAGEMENT" "-DSQLITE_ENABLE_RTREE" "-DSQLITE_ENABLE_STAT2" "-DSQLITE_ENABLE_STAT4" "-DSQLITE_SOUNDEX" "-DSQLITE_THREADSAFE=1" "-DSQLITE_USE_URI" "-DHAVE_USLEEP=1" "-DSQLITE_HAVE_ISNAN" "-o" "/app/target/debug/build/libsqlite3-sys-c498aca38607cdd2/out/sqlite3/sqlite3.o" "-c" "sqlite3/sqlite3.c"
cargo:warning=sqlite3/sqlite3.c:14012:10: fatal error: stdio.h: No such file or directory
cargo:warning=14012 | #include <stdio.h>
cargo:warning= | ^~~~~~~~~
cargo:warning=compilation terminated.
exit status: 1
--- stderr
error occurred: Command "cc" "-O0" "-ffunction-sections" "-fdata-sections" "-fPIC" "-g" "-fno-omit-frame-pointer" "-DSQLITE_CORE" "-DSQLITE_DEFAULT_FOREIGN_KEYS=1" "-DSQLITE_ENABLE_API_ARMOR" "-DSQLITE_ENABLE_COLUMN_METADATA" "-DSQLITE_ENABLE_DBSTAT_VTAB" "-DSQLITE_ENABLE_FTS3" "-DSQLITE_ENABLE_FTS3_PARENTHESIS" "-DSQLITE_ENABLE_FTS5" "-DSQLITE_ENABLE_JSON1" "-DSQLITE_ENABLE_LOAD_EXTENSION=1" "-DSQLITE_ENABLE_MEMORY_MANAGEMENT" "-DSQLITE_ENABLE_RTREE" "-DSQLITE_ENABLE_STAT2" "-DSQLITE_ENABLE_STAT4" "-DSQLITE_SOUNDEX" "-DSQLITE_THREADSAFE=1" "-DSQLITE_USE_URI" "-DHAVE_USLEEP=1" "-DSQLITE_HAVE_ISNAN" "-o" "/app/target/debug/build/libsqlite3-sys-c498aca38607cdd2/out/sqlite3/sqlite3.o" "-c" "sqlite3/sqlite3.c" with args "cc" did not execute successfully (status code exit status: 1).
warning: build failed, waiting for other jobs to finish...
error: build failed
Any idea on this?
