I’ve encountered issue when using Connect-X5.
OS is Ubuntu 18.04, kernel 5.4
Driver version 23.10-1.1.9 and FW - 16.35.3006 (MT_0000000425) and also happened on kernel one as well - 5.7-1.0.2 with FW - 16.34.1002 (MT_0000000425)
[Thu Dec 4 12:43:21 2025] mlx5_core 0000:af:00.0: RX timeout on channel: 26, ICOSQ: 0x3a8, RQ: 0x3ab, CQ: 0x487
[Thu Dec 4 12:43:21 2025] mlx5_core 0000:af:00.0: EQ 0x21: Cons = 0x393d736c, irqn = 0x24f
[Thu Dec 4 12:43:21 2025] mlx5_core 0000:af:00.0: Failed to get min RX wqes on Channel[30] RQN[0x3c3] wq cur_sz(0) min_rx_wqes(2)
[Thu Dec 4 12:43:21 2025] mlx5_core 0000:af:00.0: RX timeout on channel: 30, ICOSQ: 0x3c0, RQ: 0x3c3, CQ: 0x49b
[Thu Dec 4 12:43:21 2025] mlx5_core 0000:af:00.0: Failed to get min RX wqes on Channel[32] RQN[0x3cf] wq cur_sz(0) min_rx_wqes(2)
[Thu Dec 4 12:43:21 2025] mlx5_core 0000:af:00.0: RX timeout on channel: 32, ICOSQ: 0x3cc, RQ: 0x3cf, CQ: 0x4a5
[Thu Dec 4 12:43:22 2025] mlx5_core 0000:af:00.0: Failed to get min RX wqes on Channel[33] RQN[0x3d5] wq cur_sz(0) min_rx_wqes(2)
[Thu Dec 4 12:43:22 2025] mlx5_core 0000:af:00.0: RX timeout on channel: 33, ICOSQ: 0x3d2, RQ: 0x3d5, CQ: 0x4aa
[Thu Dec 4 12:43:22 2025] mlx5_core 0000:af:00.0: Failed to get min RX wqes on Channel[34] RQN[0x3db] wq cur_sz(0) min_rx_wqes(2)
[Thu Dec 4 12:43:22 2025] mlx5_core 0000:af:00.0: ICOSQ: 0x3d8, RQ: 0x3db, CQ: 0x4af
[Thu Dec 4 12:43:22 2025] mlx5_core 0000:af:00.0: Link down
This is the logs being seen in dmesg. During it server is experiencing troubles with network connectivity and availability. There is no full no connection at all, rather response time climbs too high, causing issues. It happens not very frequently and it seems not clear - how to reproduce this at the moment. Reboot helps in that case. Have you encountered something like this?
It seems, that functionality regarding such logs has been added here Making sure you're not a bot!
Thank you in advance
