al configurar la cámara csi con el comando ./docker_dli_run.sh me marca “permiso denegado” no recurriría a esto pero llevo mucho tiempo intentando seguir el tutorial, gracias.
Hi emmanuelvidal128546,
Welcome to Jetson & Embedded Systems forum, please open issue with English manner then other developers can know your issue to share their experiences.
Translated in English:
when configuring the csi camera with the command ./docker_dli_run.sh marks me “permission denied” I would not resort to this but I have been trying to follow the tutorial for a long time, thanks.
May I know which tutorial you’re following?
What’s the camera you’re using?
Is this still an issue to support?
IMX219,I have the same problem.
I followed the tutorial,but the powershell also displayed permission denied.my camera is IMX-219
Hi new-max,
Please help to open a new topic with more details information of system setup, SW info, and tutorial …etc. Thanks
the prob has ben sovled…thx
I am still facing this problem “-bash: ./docker_dli_run.sh: Permission denied” could anyone please assist? I did not manage to find the solution from this forum.
Hi @Abuelgasim, can you try setting execution privilege on your script with the following command?
chmod +x docker_dli_run.sh
And then try running your script agian. Or you can try running it as sh ./docker_dli_run.sh
(which doesn’t require execution bit in the file’s privileges)
Thank you, setting the execution privilege worked.
