I have a 150W DC-DC Boost Converter with input as12V from a LiPo battery and the converter can output a 6A maximum current. Is this converter safe to power my Jetson AGX Orin device where its input is 7-20V with 5A current. The output voltage of the boost converter ranges from 12-35V.
The current draw by AGX Orin depends on its workload not by your power supply.
Ok,but is this converter safer to use with Jetson AGX Orin?
Should be. The power supply voltage level should be in the range of 7-20V for Orin.
