Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I’m writing an application that runs multiple gmsl cameras, my code fails here:
NvMediaStatus nvStatus = NvMediaIJPEFeedFrame(camera.NvMediaIjpe, image_nvmedia->img, 70);
NvMediaIJPEFeedFrame() failed: 1
This only happens when I try to run 2 or more cameras, and the error appears with the second camera. I understand that for DriveWorks 3.5 each camera requires a different sensor handle (4 Camera setup with dwSensorHandle_t only finds 1)
I initialize the ContextHandle and then the Sal_Handle, I use the same Sal_Handle to create all the sensor: result = dwSAL_createSensor(&sensor_handle, sensor_params, sal);
I wonder if this is the problem or could be causing the NVMediaIJPEFeedFrame to fail?
I have a separate dwSensorHandle_t for each camera, my code is consistant with the sample_camera at the moment. I just don’t know yet what’s the meaning of the error “1” in NvMediaIJPEFeedFrame().
It passes, dwSensorCamera_readFrame, dwSensorCamera_getImage, dwImage_create, dwImage_copyConvert, dwSensorCamera_returnFrame, dwImage_getTimestamp, dwImage_getNvMedia, but when it reach to NvMediaIJPEFeedFrame the code fails.
Dear @jber4282,
What is the format conversion you are looking? Are you using NvMediaIJPEFeedFrame explicitly in your code or it is from DW APIs internally? Is it possible to share code some snippet?
