if ((i == si) && (j == sj) && (k == sk)) {
p[sourcePos] = p[sourcePos] + sourceFn[n] + sourceFn[n-2];
// Insert Source
p[si][sj][sk] = p[si][sj][sk] + sourceFn[n] - sourceFn[n-2];
Look like it is not right.
// Insert Source
Why not?
[sourcePos] is the defined stride address for [si][sj][sk] (see the #defines above).
Or is it because of the ‘if’ condition? (On the CPU it doesn’t make any difference with or without it).
Please do elaborate…
Why not?
(drive-by posting without reading the thread)
is this just 80-bit precision on the host and 64-bit precision on the GPU due to x87? or are you not defining -arch sm_13?
+sourceFn and - sourceFn
What a fool I am… :">
How could I have missed that?
I have looked at this code over and over again, and never caught it!
Thank you Lev :). I’ll make the correction, and check again.
tmurray - I am defining sm13 architecture.
Do not forget about additional threads.
Also consider
instead
if ((i>0) && (i<iDim-1) && (j>0) && (j<jDim-1) && (k>0) && (k<kDim-1))
// We are inside the domain
p[ijk] = (pCoef*(pz[ip] + pz[im] + pz[jp] + pz[jm] + pz[kp] + pz[km])) - pzz[ijk];
if (k==0) { p[ijk] = (1.0+wR)*pz[kp] - wR*pzz[ijk]; } // Down Boundary
if (k==kDim-1) { p[ijk] = (1.0+wR)*pz[km] - wR*pzz[ijk]; } // Up Boundary
if (j==0) { p[ijk] = (1.0+wR)*pz[jp] - wR*pzz[ijk]; } // Front Boundary
if (j==jDim-1) { p[ijk] = (1.0+wR)*pz[jm] - wR*pzz[ijk]; } // Back Boundary
if (i==0) { p[ijk] = (1.0+wR)*pz[ip] - wR*pzz[ijk]; } // Left Boundary
if (i==iDim-1) { p[ijk] = (1.0+wR)*pz[im] - wR*pzz[ijk]; } // Right Boundary
somelthing like this
if ((i>0) & (i<iDim-1) & (j>0) & (j<jDim-1) & (k>0) & (k<kDim-1))
else
or
if (k==0) { p[ijk] = (1.0+wR)*pz[kp] - wR*pzz[ijk]; goto noinside; } // Down Boundary
etc
for better performance
though compiler may do it itself
also no need of syncthread at the end of the block
and you may combine all slices in one kernell, without cycle by k.
There are some easy optimization options arround.
Also consider
instead
else
or
etc
If you use x87 on CPU, not SSE2 scalar or vector, result has a bit more precision, cause internal registers of x87 is 80bit wide.
Thank you much for the help, Lev.
Greatly appreciated.
