I try to feed 16 input sources using deepstream-app and test3 with the same config,same sources and same model engine file. My system configuration: ubuntu18.04 deepstream5.0 ,GTX1070. YOLOv3 Input image size is 320.
Deepstream-app as the following:
Comp name = nvv4l2decoder12 in_system_timestamp = 1589076866411.476074 out_system_timestamp = 1589076866513.801025 component latency= 102.324951
Comp name = src_bin_muxer source_id = 3 pad_index = 3 frame_num = 470 in_system_timestamp = 1589076866669.389893 out_system_timestamp = 1589076866677.427979 component_latency = 8.038086
Comp name = nvv4l2decoder3 in_system_timestamp = 1589076866406.945068 out_system_timestamp = 1589076866513.219971 component latency= 106.274902
Comp name = src_bin_muxer source_id = 5 pad_index = 5 frame_num = 470 in_system_timestamp = 1589076866664.779053 out_system_timestamp = 1589076866677.427979 component_latency = 12.648926
Comp name = primary_gie in_system_timestamp = 1589076866677.454102 out_system_timestamp = 1589076866734.322998 component latency= 56.868896
Comp name = tracking_tracker in_system_timestamp = 1589076866734.341064 out_system_timestamp = 1589076866750.394043 component latency= 16.052979
Comp name = tiled_display_tiler in_system_timestamp = 1589076866756.521973 out_system_timestamp = 1589076866769.393066 component latency= 12.871094
Comp name = nvosd0 in_system_timestamp = 1589076866770.602051 out_system_timestamp = 1589076866772.271973 component latency= 1.669922
Test3 as the following:
Comp name = nvv4l2decoder12 in_system_timestamp = 1589076914243.735107 out_system_timestamp = 1589076914513.468018 component latency= 269.732910
Comp name = stream-muxer in_system_timestamp = 1589076914513.476074 out_system_timestamp = 1589076914594.230957 component latency= 80.754883
Comp name = nvv4l2decoder13 in_system_timestamp = 1589076914161.397949 out_system_timestamp = 1589076914505.507080 component latency= 344.109131
Comp name = stream-muxer in_system_timestamp = 1589076914505.520020 out_system_timestamp = 1589076914594.230957 component latency= 88.710938
Comp name = nvv4l2decoder1 in_system_timestamp = 1589076914306.117920 out_system_timestamp = 1589076914513.448975 component latency= 207.331055
Comp name = stream-muxer in_system_timestamp = 1589076914513.465088 out_system_timestamp = 1589076914594.230957 component latency= 80.765869
Comp name = nvv4l2decoder3 in_system_timestamp = 1589076914233.283936 out_system_timestamp = 1589076914517.877930 component latency= 284.593994
Comp name = stream-muxer in_system_timestamp = 1589076914517.884033 out_system_timestamp = 1589076914594.230957 component latency= 76.346924
Comp name = primary-nvinference-engine in_system_timestamp = 1589076914594.248047 out_system_timestamp = 1589076914819.144043 component latency= 224.895996
Comp name = tracker in_system_timestamp = 1589076914819.154053 out_system_timestamp = 1589076914835.211914 component latency= 16.057861
Comp name = nvtiler in_system_timestamp = 1589076914840.446045 out_system_timestamp = 1589076914850.270996 component latency= 9.824951
Comp name = nv-onscreendisplay in_system_timestamp = 1589076914850.374023 out_system_timestamp = 1589076914888.256104 component latency= 37.882080
I found the different performance of YOLOV3 as primary-nvinference-engine when using deepstream-app and test3, deepsteam-app is about 50-60ms ,but test3 is above 200ms.To the point , the same cfg file, the same model engine file and the same sources.
Can you help me to investigate it. Thanks a lot.
