Thanks for the quick reply,
I tried batched-push-timeout=100000 and batched-push-timeout=-1 , but I still have same issue, when the first stream finish, the second stream detections results are messed up.
This is my config file :
Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
Permission is hereby granted, free of charge, to any person obtaining a
copy of this software and associated documentation files (the “Software”),
to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#kitti-track-output-dir=metadata
kitti-track-output-dir=metadata/counting/2cams_004
gie-kitti-output-dir=metadata/detection/2cams_004
[tiled-display]
enable=1
rows=1
columns=2
#width=1280
#height=720
#width=1300
#height=500
width=1920
height=1080
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=2
#uri=rtsp://192.168.1.122:8554/test
uri=file://./videos_for_manual_counting/2748_2017-07-28_1335_D_FFT_Trim_5min.mp4
#uri=file://./videos_for_manual_counting/2754_2017-08-10_0027_N_FFT_Trim_1.mp4
#uri=file://./videos_for_manual_counting/2779_2017-10-12_1023_D_FFT_Trim_2.mp4
#uri=file://./videos_for_manual_counting/2779_2017-08-10_0134_N_FFT_Trim_2.mp4
#uri=file://./videos_for_manual_counting/2785_2017-08-09_2230_N_FFT_Trim_7.mp4
#uri=file://./videos_for_manual_counting/2793_2017-09-30_1335_D_Split_Trim_2_FFT_9min.mp4
num-sources=1
camera-width=1920
camera-height=1080
gpu-id=0
#drop-frame-interval=2
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=2
num-sources=1
camera-width=1920
camera-height=1080
gpu-id=0
cudadec-memtype=0
[source2]
enable=0
type=2
num-sources=1
camera-width=1920
camera-height=1080
gpu-id=0
cudadec-memtype=0
[source3]
enable=0
type=2
num-sources=1
camera-width=1920
camera-height=1080
gpu-id=0
cudadec-memtype=0
[source4]
enable=0
type=2
num-sources=1
camera-width=1920
camera-height=1080
gpu-id=0
cudadec-memtype=0
[source5]
enable=0
type=2
num-sources=1
camera-width=1920
camera-height=1080
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
#iframeinterval=10
[sink1]
enable=0
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
#iframeinterval=10
[sink2]
enable=0
type=3
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
container=1
codec=1
output-file=metadata/augmented/2748_004.mp4
[sink3]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
qos=1
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
nvbuf-memory-type=0
#width=100
#height=100
#iframeinterval=30
[sink4]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=5
sync=1
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
[sink5]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
#msg-conv-config=config_brokers/cfg_msgconv.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_kafka_proto.so
#msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_azure_edge_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=192.168.1.118;9092;NanoTopic001
#msg-broker-conn-str=172.22.18.99;9092;NanoTopic001
#msg-broker-conn-str=10.50.7.187;9092;NanoTopic001
topic=NanoTopic001
#Optional:
#msg-broker-config=…/…/deepstream-test4/cfg_kafka.txt
#msg-broker-config=config_brokers/cfg_azure.txt
[osd]
enable=1
gpu-id=0
process-mode=2
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=2
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
#batched-push-timeout=40000
#batched-push-timeout=100000
Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
config-file property is mandatory for any gie section.
Other properties are optional and if set will override the properties set in
the infer config file.
[primary-gie]
enable=1
gpu-id=0
batch-size=2
interval=9
#Required by the app for OSD, not a plugin property, specify a color for each class
bbox-border-color0=0.5;0.5;0.5;1
bbox-border-color1=0;1;1;1
Fill the bbox with a background color, specify a color for each class
#bbox-bg-color0=0;1;0;1
#bbox-bg-color1=1;1;1;1
gie-unique-id=1
nvbuf-memory-type=0
#config-file=models/custom_yolov3_20191014/config_infer_primary_custom_yoloV3.txt
#config-file=models/custom_yolov3_20191029/config_infer_primary_custom_yoloV3.txt
#config-file=models/custom_yolov3_20191201/config_infer_primary_custom_yoloV3.txt
#config-file=models/custom_yolov3_tiny_Hend_3/config_infer_primary_custom_yoloV3_tiny.txt
#config-file=models/custom_yolov3_tiny_2754_N_FFT_Trim_2/config_infer_primary_custom_yoloV3_tiny.txt
#config-file=models/custom_yolov3_tiny_2748_D_FFT_trim/config_infer_primary_custom_yoloV3_tiny.txt
#config-file=models/custom_yolov3_tiny_20191020/config_infer_primary_custom_yoloV3_tiny.txt
config-file=models/custom_yolov3_tiny_20191209/config_infer_primary_custom_yoloV3_tiny.txt
[tracker]
enable=1
tracker-width=600
tracker-height=300
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#required ll-config-file for DCF/IOU only
#ll-config-file=./config_trackers/dcf_config.yml
#ll-config-file=./config_trackers/iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=0
[tests]
file-loop=0
##drop-frame-interval / skip-frames check nvv4l2decoder
