First, I wrote the tensorRT-SSD code in gtx1080, and it runs successfully.
Then,Inputed a same picture twice, it got two different result.
for example, SSD output the result contains 4 position values
the first one, 0.4523 0.1240 0.8511 0.4512
the second, 0.4531 0.1237. 0.8531 0.4512
The results of the two outputs will be slightly different.
Although it does not affect the final detection accuracy, I want to know what causes this.
And,I copyed this code to TX2,it also ran successfully.
But, the result of TX2 output is different with gtx1080 output.
For example, inputing a picture contains several objects,gtx1080-tensorRT could detect all objects, but tx2-tensorRT got only one or two.
can you update to TensorRT 5 and Jetpack 4.1 (trt5) or Jetpack 3.3 (trt4). Many improvements and fixes have been submitted since TRT3.0.
can you share a small repro package containing the code used to generate the plan files, 2 plan files for both GPUs, set of images that demonstrate what you seeing, and any scripts that you are using to run inference. You can DM if you don’t want to post publically.
Any one help me ?
There are 4 pictures, results of detection
The first ,GTX1080_mobileNetSSD_Caffe External Media
The second,GTX1080_mobileNetSSD_TensorRT3.0.4 External Media
The third,TX2_mobileNetSSD_Caffe External Media
The last,TX2_mobileNetSSD_TensorRT3.0.4 External Media
The premise of getting the above results is that the same code, the same caffemodel, the same input image
As can be seen from the four pictures,
1、The results on the caffe are the same.
2、Same hardware platform,the result of tensorRT is different with Caffe’s.
3、The accuracy on gtx1080 is higher than on tx2. So,Why??
the results are defferent between two detectons about image-71.
And there is big difference between the 1080ti and jetson tx2,
the confidence about image-71 is much lower, I don’t know why?
I tried your code in the github,seems you have solved this problem? I run many times at 1080ti and they have the same coordinates value, and the result at jetson tx2 has slightly differenence, the results are close to each other.
Could you give me some advices? I would be very grateful.
