I’m trying to port Leopard AR0233 RAW GMSL2 camera to Jetpack5 with L4T 35.1. Then I came across a tool nvargus_nvraw
to check driver is workable or not. However, when I dump all camera’s info by the following command:
$> nvargus_nvraw --lps
nvargus_nvraw version 1.13.1
Number of supported sensor entries 8
Entry Source Mode Uniquename Resolution FR BitDepth Mode
Index Index Index CSI Dyn Type
0 0 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
1 1 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
2 2 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
3 3 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
4 4 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
5 5 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
6 6 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
7 7 0 ar0233_rear_liar0233 2048x1280 29 12 12 Bayer
All 8 cameras shows the same uniquename. (ar0233_rear_liar0233
I guess this slot is acquired by the device tree (tegra-camera-platform
node):
tegra-camera-platform {
modules {
module0 {
badge = "ar0233_rear_liar0233";
module1 {
badge = "ar0233_front_liar0233";
However, I double check my dts settings are set correctly.
$> cat /proc/device-tree/tegra-camera-platform/modules/module*/badge
ar0233_topright_liar0233
ar0233_bottomright_liar0233
ar0233_topleft_liar0233
ar0233_centerright_liar0233
ar0233_centerleft_liar0233
ar0233_bottomleft_liar0233
Is this problem is caused by nvargus_nvraw
it self ?
