Sample 00_video_decode decode success but render failed
I build and run Sample 00_video_decode in Jetson_Multimedia_API_R35.6.0_aarch64 on Jetson AGX platform(Jetpack5.1.4).
The build is done well and I got video_decode, but it render failed when I run the video_decode.
My input arguments are “./video_decode H264 -o out.jpg output.h264”
The output.h264 is my input h264 local file stream.
I’ve checked the code follow, the nvdec worked well.
I play the YUV output file with yuvplayer, which show the correct video on the screen.
but when run the video_decode, the egl render got some error, and no video show in the screen.
The errors are:
nvbufsurface: Failed to create EGLImage.
[ERROR] (NvEglRenderer.cpp:386) Could not get EglImage from fd. Not rendering
Does anyone run the 00_video_decode sample well and get the render show in the screen?
Sorry, please ignore this, I rebuild 00_video_decode and run video_deocode then it work well and the video show in the screen.
The reason is I do not connet a real display.
Welcome to the NVIDIA developer forums.
Thanks for updating your issue!
