./sample_camera in DriveWorks samples fails on different port
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hello, I’m experimenting with a camera setup. I noticed something interesting. If I have all 4 of my cameras connect to Group A and have the correct rig file accordingly, ./sample_camera would be able to show all 4 cameras. However, if I change to Group B (csi-ab 4-7) or Group C (csi-cd 0-3) with changes in the rig file accordingly (changes in link and interface in parameters). It shows a time out error:
[09-02-2024 04:55:01] CameraMaster: master init failed with status = 5
[09-02-2024 04:55:01] Driveworks exception thrown: DW_UNEXPECTED_EVENT: CameraMaster::bootstrap failed with sipl status 5
The rig file is exactly the same when I plugged the cameras into Group A (csi-ab 0-3 which was working perfectly) except for the interface and link in parameters. Can you guys help me with this? Thank you!
Which cameras listed in https://developer.nvidia.com/drive/ecosystem-orin#camera are being used? Does nvsipl_camera work with the cameras connected to Group B or C?
Hi Nick,
We have the Smartlead BF8S103G-100-00 120 FOV ones. The camera name that I used in my rig file is: V1SIM728S1RU3120NB20. Here is how I put in the sensor information in the rig file:
                "name": "camera:sample0",
                "nominalSensor2Rig_FLU": {
                    "roll-pitch-yaw": [
                        0.0,
                        0.0,
                        0.0
                    "t": [
                        1.8621,
                        -0.1939,
                        1.3165
                "parameter": "camera-name=V1SIM728S1RU3120NB20,interface=csi-cd,CPHY-mode=1,link=0,output-format=processed,async-record=1,file-buffer-size=16777216",
                "properties": {
                    "Model": "ftheta",
                    "bw-poly": "0.000000000000000 5.35356812179089e-4 4.99266072928606e-10 4.27370422037554e-12 -6.68245573791717e-16",
                    "cx": "1927.764404",
                    "cy": "1096.686646",
                    "height": "2168",
                    "width": "3848"
                "protocol": "camera.gmsl"
The only changes I’m making are in interface (csi-ab/csi-cd) and link (0-7). Thank you!
I was able to figure out Group C actually is csi-ef. Not csi-cd. Now I can get all my cameras to work. Thank you!
