Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
When I use sample_camera, it gave me a pipeline error. I have no idea how to fix this issue.
WindowEGL: find EGL devices
WindowEGL: found 1 EGL devices
WindowEGL: init EGL with GLES3 context
WindowEGL: bind OpenGLES3 API
WindowEGL: offscreen mode → use EGL PBuffer surface 1280x800
WindowEGL: create EGL context
WindowEGL: assign EGL context to current thread
[13-01-2022 20:12:33] Platform: Detected Drive Xavier P3479
[13-01-2022 20:12:33] TimeSource: monotonic epoch time offset is 1642047784046298
[13-01-2022 20:12:33] TimeSource: Could not detect valid PTP time source at nvpps. Fallback to eth0
[13-01-2022 20:12:33] TimeSource Eth: Lost PTP time synchronizaton. Synchronized time will not be available from this timesource.
[13-01-2022 20:12:33] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[13-01-2022 20:12:33] Platform: number of GPU devices detected 1
[13-01-2022 20:12:33] Platform: currently selected GPU device integrated ID 0
[13-01-2022 20:12:33] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/home/nvidia/data/’: VirtualFileSystem: Failed to mount ‘/home/nvidia/data/[.pak]’
[13-01-2022 20:12:33] Context::findDataRootInPathWalk: Could not find ./data/DATA_ROOT in upto 7 parent directories from /usr/lib/libdw_base.so.4.0
[13-01-2022 20:12:33] SDK: No resources(.pak) mounted, some modules will not function properly
[13-01-2022 20:12:33] SDK: Create NvMediaDevice
[13-01-2022 20:12:33] SDK: Create NvMedia2D
[13-01-2022 20:12:33] SDK: use EGL display as provided
[13-01-2022 20:12:33] Initialize DriveWorks SDK v4.0.0
[13-01-2022 20:12:33] Release build with GNU 7.3.1 from no-gitversion-build against Drive PDK v5.2.6.0
[13-01-2022 20:12:33] Rig::fromFile: Loading rig file: /home/nvidia/data/samples/sensors/camera/camera/rig_truly.json
[13-01-2022 20:12:33] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[13-01-2022 20:12:33] No valid data file found for camera:front:center:120fov in parameter string: camera-name=TRULYP,interface=csi-ef,link=1,output-format=yuv (using configuration folder /home/nvidia/data/samples/sensors/camera/camera/)
onInitialize: creating camera.gmsl with params: camera-name=TRULYP,interface=csi-ef,link=1,output-format=yuv
[13-01-2022 20:12:33] SensorFactory::createSensor() → camera.gmsl, camera-name=TRULYP,interface=csi-ef,link=1,output-format=yuv
[13-01-2022 20:12:33] CameraBase: pool size set to 8
[13-01-2022 20:12:33] SensorFactory::createSensor() → camera.gmsl.master,
[13-01-2022 20:12:34] CameraMaster::parseDevBlock Getting device info list.
[13-01-2022 20:12:34] devBlock: 1 Slave = 0 Interface = csi-ef Camera_name = TRULYP Link = 1
[13-01-2022 20:12:34] Camera Match Name: TRULYP Description: TRULYP, MAX96717 linkIndex: 4294967295 serInfo.Name: MAX96717F
[13-01-2022 20:12:34] Client, Setting up information for camera ID 0
[13-01-2022 20:12:34] CameraClient, YUV camera detected, overriding all output types to produce processed only output
[13-01-2022 20:12:34] Client, successfully found info for camera ID 0 bound to id 0
[13-01-2022 20:12:34] CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/TRULYP.nito
[13-01-2022 20:12:34] CameraClient: no NITO found at /opt/nvidia/nvmedia/nit/trulyp.nito
[13-01-2022 20:12:34] CameraClient: using NITO found at /opt/nvidia/nvmedia/nit/template.nito
[13-01-2022 20:12:34] Initialize DriveWorks VisualizationSDK v4.0.0
[13-01-2022 20:12:34] Initialize DriveWorksGL SDK v4.0.0
onInitialize: Total cameras 1
onInitialize: getting image props 0
onInitialize: initilizing stream: 0
[13-01-2022 20:12:35] StreamConsumerGL: successfully initialized
[13-01-2022 20:12:35] StreamProducerCUDA: successfully initialized
[13-01-2022 20:12:35] CameraClient: camera params: format=h264,type=disk,file=abc.h264
[13-01-2022 20:12:35] CameraClient: serializer bitrate not specified. Using 8000000.
[13-01-2022 20:12:35] EncoderNvMedia: Setting encode on instance 0
Main: Starting master.
[13-01-2022 20:12:35] CameraGSMLMaster: starting…
[13-01-2022 20:12:35] SIPLMaster::SIPLMaster: Setting up master camera
[13-01-2022 20:12:35] Platform:
[13-01-2022 20:12:35] Platform Config:
[13-01-2022 20:12:35] Description:
[13-01-2022 20:12:35] Number of device blocks: 1
[13-01-2022 20:12:35] Device Block : 0
[13-01-2022 20:12:35] csiPort: 8
[13-01-2022 20:12:35] i2cDevice: 1
[13-01-2022 20:12:35] Deserializer Name: MAX96712
[13-01-2022 20:12:35] Deserializer Description: Maxim 96712 Aggregator
[13-01-2022 20:12:35] Deserializer i2cAddress: 41
[13-01-2022 20:12:35] Simulator Mode: 0
[13-01-2022 20:12:35] Slave Mode: 0
[13-01-2022 20:12:35] Phy Mode: 0
[13-01-2022 20:12:35] Number of camera modules: 1
[13-01-2022 20:12:35] CameraModule index: 1
[13-01-2022 20:12:35] Name :TRULYP
[13-01-2022 20:12:35] Description: TRULYP, MAX96717
[13-01-2022 20:12:35] Serializer name: MAX96717F
[13-01-2022 20:12:35] Serializer description: Maxim 96717F Serializer
[13-01-2022 20:12:35] Serializer i2cAdress: 64
[13-01-2022 20:12:35] Sensor ID: 0
[13-01-2022 20:12:35] Sensor name: TRULY
[13-01-2022 20:12:35] Sensor description: Truly Sensor
[13-01-2022 20:12:35] Sensor i2cAddress: 108
[13-01-2022 20:12:35] Sensor isTPGEnabled: 0
[13-01-2022 20:12:35] Sensor isTriggerMode: 0
[13-01-2022 20:12:35] cfa: 4
[13-01-2022 20:12:35] embeddedTopLines: 0
[13-01-2022 20:12:35] embeddedBottomLines: 0
[13-01-2022 20:12:35] inputFormat: 0
[13-01-2022 20:12:35] height: 1080
[13-01-2022 20:12:35] width: 1920
[13-01-2022 20:12:35] fps: 30.0000000
[13-01-2022 20:12:35] Embedded Data: 0
[13-01-2022 20:12:35] CameraMaster available outputs: 8
[13-01-2022 20:12:35] CameraClient: setting pipeline config for camera ID 0
sample_camera: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvMSensorPipeline.cpp: 462: VerifyPipelineCfg: At least one output needs to be enabled
sample_camera: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMCamera.cpp: 195: SetPipelineCfg: Invalid pipeline configuration
[13-01-2022 20:12:35] CameraClient: Failed to set Pipeline configuration for client with id 0, status 1
[13-01-2022 20:12:35] Driveworks exception thrown: DW_NVMEDIA_ERROR: CameraClient: Failed to set pipeline configuration!
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2022-01-13 20:12:35] DW Error DW_NVMEDIA_ERROR executing DW function:
dwSensor_start(m_camera[i])
at /usr/local/driveworks-4.0/samples/src/sensors/camera/camera/main.cpp:367
Aborted
