• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• NVIDIA GPU Driver Version (valid for GPU only) 460+
• Issue Type( questions, new requirements, bugs) Deepstream Test app 5 has an error where if a camera goes offline, it attempts reconnect and then is stuck in a Kafka disconnect error as shown below logs. This is an issue at multiple sites and is a critical issue as DS stops.
** WARN: <watch_source_status:674>: No data from source 1 since last 20 sec. Trying reconnection",
"text": "%3|1632945618.289|FAIL|rdkafka#producer-1| [thrd:localhost:9094/bootstrap]: localhost:9094/bootstrap: Receive failed: Disconnected",
"text": "%3|1632945618.289|ERROR|rdkafka#producer-1| [thrd:localhost:9094/bootstrap]: localhost:9094/bootstrap: Receive failed: Disconnected",
"text": "%3|1632946518.006|FAIL|rdkafka#producer-1| [thrd:localhost:9094/bootstrap]: localhost:9094/bootstrap: Receive failed: Disconnected",
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) Use Deeptsream test app 5, broker to local kafka, rtsp reconnect as source and unplug camera, wait till reconnect event and then errors will show with kafka.
