JetPack : 4.3
I’m using a custom CSI camera with LibArgus, i want to retreive EEPROM data from this latter, i’ve found the function getSensorEepromData but i didn’t find any example in argus sample to use it, **can you please suggest an implementation to use this function ?
I am wondering what’s the argument dst ? and how can i display this data ? I tried to this in my app, but i am getting a segmentation fault :
// Get the camera device
std::vector<Argus::CameraDevice*> cameraDevices;
iCameraProvider->getCameraDevices(&cameraDevices);
if (cameraDevices.size() == 0)
printf("No cameras available");
// Get EEPROM data
void* buffer = (void*) malloc(5 *sizeof(char));
Argus::Ext::ISensorEepromData *iSensorEepromData = Argus::interface_cast<Argus::Ext::ISensorEepromData>(cameraDevices[0]);
iSensorEepromData->getSensorEepromData(buffer, iSensorEepromData->getSensorEepromDataSize());
I think i’m having a segmentation fault because the EEPROM is not enabled in the device tree, so this error appear when i use iSensorEepromData->getSensorEepromDataSize() but i am wondering what i can do as parameter in the buffer (dst) ?
Make sure the your sensor driver have implement the EEPROM CID first.
Hi @ShaneCCC ,
Thank you for your answer, but i wanna know how this function will display the EEPROM data, what kind of output can i have with this latter ?
Should be able get the EEPROM data like below eeprom_data and opt_data.
nvidia@nvidia-desktop:~$ v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, ov5693 2-0036
Bus info : platform:15c10000.vi:2
Driver version: 4.9.253
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 2: no power)
Format Video Capture:
Width/Height : 2592/1944
Pixel Format : 'BG10'
Field : None
Bytes per Line : 5184
Size Image : 10077696
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
eeprom_data 0x009a2005 (str) : min=0 max=2048 step=2 value='01000700fe0ce803014d00ffffffffffff00ae053639392d38333332362d313030302d313030204d2e30ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff50333332364130315031343534ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff46464646ffff4646ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff73ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff' flags=read-only, has-payload
otp_data 0x009a2006 (str) : min=0 max=1024 step=2 value='9332eb330820d234000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000822a00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000057000000000000000000170000000000' flags=read-only, has-payload
system
closed
July 27, 2022, 3:32am
#7
