whaler@whaler-laptop:/usr/local/cuda-9.2/samples$ make
make[1]: Entering directory ‘/usr/local/cuda-9.2/samples/0_Simple/cppOverload’
/usr/local/cuda-9.2/bin/nvcc -ccbin g++ -I…/…/common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cppOverload.o -c cppOverload.cu
Assembler messages:
Fatal error: can’t create cppOverload.o: Permission denied
Makefile:288: recipe for target ‘cppOverload.o’ failed
make[1]: *** [cppOverload.o] Error 1
make[1]: Leaving directory ‘/usr/local/cuda-9.2/samples/0_Simple/cppOverload’
Makefile:52: recipe for target ‘0_Simple/cppOverload/Makefile.ph_build’ failed
make: *** [0_Simple/cppOverload/Makefile.ph_build] Error 2
Ubuntu 16.04
1080Ti 396.37
Cuda9.2 patch
you don’t have write access to the directory you are trying to build in
try
sudo make
