Hi everyone,
Today I successfully managed to install the CUDA 6.5 Toolkit on Debian Jessie. Unfortunately, the samples do not work, even though they compile without problems. I believe I have a correct driver version (I have 340.65 and I think the 6.5 toolkit requires a minimum driver version of 340.21):
kmdouglass@kmd-laptop1:~/NVIDIA_CUDA-6.5_Samples/bin/x86_64/linux/release$ optirun ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
I have not been able to find much help online so far because this appears to be a common error that may or may not be related to Optimus cards. Would anyone be able to help me with this problem?
I am using the version 340.65-2 driver from the Debian non-free repository, which is higher than the driver version provided with the CUDA 6.5.14 .run file:
kmdouglass@kmd-laptop1:~/src$ optirun sudo cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 340.65 Tue Dec 2 09:50:34 PST 2014
GCC version: gcc version 4.8.4 (Debian 4.8.4-1)
I actually compiled the samples with gcc 4.8.2 since anything higher is not supported by the 6.5 toolkit.
I use the optirun command because I am using bumblebee (http://bumblebee-project.org/) with my Optimus card.
kmdouglass@kmd-laptop1:~/src$ sudo aptitude versions bumblebee
Package bumblebee:
i A 3.2.1-7 stable 995
Package bumblebee-dbg:
p 3.2.1-7 stable 995
Package bumblebee-nvidia:
i 3.2.1-7 stable 995
GPU is a GeForce GT 555M:
kmdouglass@kmd-laptop1:~/src$ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 555M] (rev a1)
Linux and Debian version:
kmdouglass@kmd-laptop1:~/src$ uname -a
Linux kmd-laptop1 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt11-1+deb8u5 (2015-10-09) x86_64 GNU/Linux
kmdouglass@kmd-laptop1:~/src$ cat /etc/debian_version
stretch/sid
nvidia-smi output
kmdouglass@kmd-laptop1:~/src$ nvidia-smi
Sat Nov 7 22:49:58 2015
| NVIDIA-SMI 340.65 Driver Version: 340.65 |
| 0 GeForce GT 555M Off | 0000:01:00.0 N/A | N/A |
| N/A 50C P0 N/A / N/A | 6MiB / 1023MiB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 Not Supported |
Output from “optirun glxheads,” which successfully displays the rotating triangle:
kmdouglass@kmd-laptop1:~/src$ optirun glxheads
glxheads: exercise multiple GLX connections (any key = exit)
Usage:
glxheads xdisplayname ...
Example:
glxheads :0 mars:0 venus:1
Display: 0x1892060
Window: 0x3800002
Context: 0x198d860
GL_VERSION: 4.4.0 NVIDIA 340.65
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce GT 555M/PCIe/SSE2
PATH and LD_LIBRARY_PATH environment variables:
kmdouglass@kmd-laptop1:~/src$ echo $PATH
/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/usr/local/ImageJ/:/usr/local/cuda-6.5/bin:/usr/local/ImageJ/:/usr/local/cuda-6.5/bin
kmdouglass@kmd-laptop1:~/src$ echo $LD_LIBRARY_PATH
/usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server:/usr/lib/jvm/java-7-openjdk-amd64:/usr/lib/jvm/java-7-openjdk-amd64/include:/usr/local/cuda-6.5/lib64
Bumblebee configuration:
# Configuration file for Bumblebee. Values should **not** be put between quotes
## Server options. Any change made in this section will need a server restart
# to take effect.
[bumblebeed]
# The secondary Xorg server DISPLAY number
VirtualDisplay=:8
# Should the unused Xorg server be kept running? Set this to true if waiting
# for X to be ready is too long and don't need power management at all.
KeepUnusedXServer=false
# The name of the Bumbleblee server group name (GID name)
ServerGroup=bumblebee
# Card power state at exit. Set to false if the card shoud be ON when Bumblebee
# server exits.
TurnCardOffAtExit=false
# The default behavior of '-f' option on optirun. If set to "true", '-f' will
# be ignored.
NoEcoModeOverride=false
# The Driver used by Bumblebee server. If this value is not set (or empty),
# auto-detection is performed. The available drivers are nvidia and nouveau
# (See also the driver-specific sections below)
Driver=
# Directory with a dummy config file to pass as a -configdir to secondary X
XorgConfDir=/etc/bumblebee/xorg.conf.d
## Client options. Will take effect on the next optirun executed.
[optirun]
# Acceleration/ rendering bridge, possible values are auto, virtualgl and
# primus.
Bridge=auto
# The method used for VirtualGL to transport frames between X servers.
# Possible values are proxy, jpeg, rgb, xv and yuv.
VGLTransport=proxy
# List of paths which are searched for the primus libGL.so.1 when using
# the primus bridge
PrimusLibraryPath=/usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus:/usr/lib/primus:/usr/lib32/primus
# Should the program run under optirun even if Bumblebee server or nvidia card
# is not available?
AllowFallbackToIGC=false
# Driver-specific settings are grouped under [driver-NAME]. The sections are
# parsed if the Driver setting in [bumblebeed] is set to NAME (or if auto-
# detection resolves to NAME).
# PMMethod: method to use for saving power by disabling the nvidia card, valid
# values are: auto - automatically detect which PM method to use
# bbswitch - new in BB 3, recommended if available
# switcheroo - vga_switcheroo method, use at your own risk
# none - disable PM completely
# https://github.com/Bumblebee-Project/Bumblebee/wiki/Comparison-of-PM-methods
## Section with nvidia driver specific options, only parsed if Driver=nvidia
[driver-nvidia]
# Module name to load, defaults to Driver if empty or unset
KernelDriver=nvidia-current
PMMethod=auto
# colon-separated path to the nvidia libraries
LibraryPath=/usr/lib/x86_64-linux-gnu/nvidia:/usr/lib/i386-linux-gnu/nvidia:/usr/lib/nvidia
# comma-separated path of the directory containing nvidia_drv.so and the
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia,/usr/lib/xorg/modules
XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
## Section with nouveau driver specific options, only parsed if Driver=nouveau
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
XorgConfFile=/etc/bumblebee/xorg.conf.nouveau
bumblebee/xorg.conf.nvidia:
Section "ServerLayout"
Identifier "Layout0"
Option "AutoAddDevices" "false"
Option "AutoAddGPU" "false"
EndSection
Section "Device"
Identifier "DiscreteNvidia"
Driver "nvidia"
VendorName "NVIDIA Corporation"
# If the X server does not automatically detect your VGA device,
# you can manually set it here.
# To get the BusID prop, run `lspci | egrep 'VGA|3D'` and input the data
# as you see in the commented example.
# This Setting may be needed in some platforms with more than one
# nvidia card, which may confuse the proprietary driver (e.g.,
# trying to take ownership of the wrong device). Also needed on Ubuntu 13.04.
# BusID "PCI:01:00:0"
# Setting ProbeAllGpus to false prevents the new proprietary driver
# instance spawned to try to control the integrated graphics card,
# which is already being managed outside bumblebee.
# This option doesn't hurt and it is required on platforms running
# more than one nvidia graphics card with the proprietary driver.
# (E.g. Macbook Pro pre-2010 with nVidia 9400M + 9600M GT).
# If this option is not set, the new Xorg may blacken the screen and
# render it unusable (unless you have some way to run killall Xorg).
Option "ProbeAllGpus" "false"
Option "NoLogo" "true"
Option "UseEDID" "false"
Option "UseDisplayDevice" "none"
EndSection
I’d be happy to provide any other information if it’s needed.
Cheers,
Kyle
