I am on the PCIE controller of the Jetson AGX Orin 32GB production module and hook up to 2 SSD devices via the SATA controller(88SE9215).
Jetson Linux 35.1
UPHY_TX2 UPHY_RX2 pins(K20 K21 B20 B21) connect to SATA controller 88SE_PCIe_RX 88SE_PCIe_RX
PEX_CLK0 pins(E14 E15) connect to 88SE_PCIe_CLK of the SATA controller
When an SSD device is connected to channel SATA0 of the SATAcontroller, the SATA controller can be detected and the SSD device can work properly. ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
When SSD device is connected to channel SATA1 of the SATAcontroller, the SATA controller can be detected, but the SSD device is not detected. ata2: SATA link down (SStatus 100 SControl 300)
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
pnp: PnP ACPI: disabled
la/ptsa driver initialized.
NET: Registered protocol family 2
IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
TCP: Hash tables configured (established 262144 bind 65536)
UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 8196K
hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
kvm [1]: IPA Size Limit: 48 bits
kvm [1]: VHE mode initialized successfully
Initialise system trusted keyrings
workingset: timestamp_bits=46 max_order=23 bucket_order=0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
ntfs: driver 2.1.32 [Flags: R/W].
NET: Registered protocol family 38
Key type asymmetric registered
Asymmetric key parser 'x509' registered
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
io scheduler mq-deadline registered
io scheduler kyber registered
tegra-pwm 3280000.pwm: PWM clk can sleep in ops
tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
tegra_dc_assign_hw_data: no matching compatible node
tegradccommon module_init failed
tegradc module_init failed
EINJ: ACPI disabled.
tegra-pmc c360000.pmc: scratch reg offset dts data not present
tegra-pmc: ### PMC reset source: SYS_RESET_N
tegra-pmc: ### PMC reset level: L0
tegra-pmc: ### PMC reset status reg: 0x0
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
random: fast init done
printk: console [ttyTCU0] enabled
arm-smmu 12000000.iommu: probing hardware configuration...
arm-smmu 12000000.iommu: SMMUv2 with:
arm-smmu 12000000.iommu: stage 1 translation
arm-smmu 12000000.iommu: stage 2 translation
arm-smmu 12000000.iommu: nested translation
arm-smmu 12000000.iommu: stream matching with 128 register groups
arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
arm-smmu 10000000.iommu: probing hardware configuration...
arm-smmu 10000000.iommu: SMMUv2 with:
arm-smmu 10000000.iommu: stage 1 translation
arm-smmu 10000000.iommu: stage 2 translation
arm-smmu 10000000.iommu: nested translation
arm-smmu 10000000.iommu: stream matching with 128 register groups
arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
arm-smmu 8000000.iommu: probing hardware configuration...
arm-smmu 8000000.iommu: SMMUv2 with:
arm-smmu 8000000.iommu: stage 1 translation
arm-smmu 8000000.iommu: stage 2 translation
arm-smmu 8000000.iommu: nested translation
arm-smmu 8000000.iommu: stream matching with 128 register groups
arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
tegra_profiler: version: 1.147, samples/io: 49/28
tegra_profiler: auth: init
nvsciipc: loaded module
tegra23x-qspi 3270000.spi: Adding to iommu group 0
tegra23x-qspi 3270000.spi: Node prod has invalid entries
tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
tegra23x-qspi 3270000.spi: Prod settings list not found
tegra23x-qspi 3270000.spi: Failed to get reset control: -517
tun: Universal TUN/TAP device driver, 1.6
hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
hns3: Copyright (c) 2017 Huawei Corporation.
e1000e: Intel(R) PRO/1000 Network Driver
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
igb: Intel(R) Gigabit Ethernet Network Driver
igb: Copyright (c) 2007-2014 Intel Corporation.
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver aqc111
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-pci: OHCI PCI platform driver
ohci-platform: OHCI generic platform driver
tegra-xusb 3610000.xhci: Adding to iommu group 1
usbcore: registered new interface driver uas
usbcore: registered new interface driver usb-storage
tegra-xudc 3550000.xudc: Adding to iommu group 2
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
tegra_rtc c2a0000.rtc: registered as rtc1
tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:33 UTC (33)
tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
i2c /dev entries driver
tegra-i2c 3160000.i2c: Adding to iommu group 3
tegra-i2c c240000.i2c: Adding to iommu group 3
tegra-i2c 3180000.i2c: Adding to iommu group 3
tegra-i2c 3190000.i2c: Adding to iommu group 3
tegra-i2c 31b0000.i2c: Adding to iommu group 3
tegra-i2c 31c0000.i2c: Adding to iommu group 3
tegra-i2c c250000.i2c: Adding to iommu group 3
tegra-i2c 31e0000.i2c: Adding to iommu group 3
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
Synopsys Designware Multimedia Card Interface Driver
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-tegra 3460000.sdhci: Adding to iommu group 4
SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
sdhci-tegra 3400000.sdhci: Adding to iommu group 5
tegra-bpmp bpmp: firmware: 888a114dda6bea50b6c6-eac380526d6
nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
hid: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
tegra-dce d800000.dce: Adding to iommu group 6
dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
tegra234-aon c000000.aon: Adding to iommu group 7
dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
c000000.aon:hsp: probed
dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [0]. Ignored...
tegra234-aon c000000.aon: init done
tegra23x-psc e860000.psc: Adding to iommu group 8
dce: dce_admin_send_cmd_ver:413 version : [0x2] err : [0x0]
tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
tegra23x-psc e860000.psc: init done
tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [1] ...
dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [1]. Ignored...
tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
dce: dce_admin_setup_clients_ipc:518 Get queue info failed for [2]
dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [3] ...
dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignored...
tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
dce: dce_start_boot_flow:100 DCE_BOOT_DONE
tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=7a10e4613e151d2bf1df37dd80d456800f5b94d0
t19x_cache tegra-cache: probed
scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
optee: probing for conduit method.
optee: revision 3.16 (65cc2218)
optee: dynamic shared memory is enabled
optee: initialized driver
nvpmodel: initialized successfully
tegra_hv: get_hvd: not initialized yet
user_ivc_mempool: hypervisor not present
usbcore: registered new interface driver snd-usb-audio
u32 classifier
input device check on
Actions configured
Initializing XFRM netlink socket
NET: Registered protocol family 10
Segment Routing with IPv6
NET: Registered protocol family 17
NET: Registered protocol family 15
bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
9pnet: Installing 9P2000 support
Key type dns_resolver registered
registered taskstats version 1
Loading compiled-in X.509 certificates
Loaded X.509 cert 'Build time autogenerated kernel key: 33c5ed3503b200c3079777cacd863df33960b65c'
tegra194-pcie 14100000.pcie: Adding to iommu group 10
tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
tegra194-pcie 14160000.pcie: Adding to iommu group 11
tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
tegra194-pcie 141a0000.pcie: Adding to iommu group 12
tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
tegra194-pcie 141e0000.pcie: Adding to iommu group 13
tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 14
host1x 13e40000.host1x: Adding to iommu group 15
t23x_init_gating_regs: Timed out waiting for syncpt ram init!
host1x 13e40000.host1x: initialized
iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 16
iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 17
iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 18
iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 19
iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 20
iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 21
iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 22
iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 23
iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 24
iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 25
iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 26
iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 27
iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 28
iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 29
iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 30
iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 31
iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
falcon 15340000.vic: Adding to iommu group 32
falcon 15340000.vic: initialized
falcon 15380000.nvjpg: Adding to iommu group 33
falcon 15380000.nvjpg: initialized
falcon 15540000.nvjpg1: Adding to iommu group 34
falcon 15540000.nvjpg1: initialized
falcon 154c0000.nvenc: Adding to iommu group 35
falcon 154c0000.nvenc: initialized
falcon 15a50000.ofa: Adding to iommu group 36
falcon 15a50000.ofa: initialized
nvdec 15480000.nvdec: Adding to iommu group 37
nvdec 15480000.nvdec: initialized
tsec 15500000.tsec: Adding to iommu group 38
tsec 15500000.tsec: initialized
gic 2a41000.agic-controller: GIC IRQ controller registered
tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
gpio-423 (gpio-hdmi2-en): hogged as output/high
gpio-425 (usb-hub-en): hogged as output/low
gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
tegra194-isp5 14800000.isp: Adding to iommu group 39
random: crng init done
t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 40
tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 41
scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 42
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 43
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 44
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 45
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 46
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 47
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 48
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 49
pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
pva 16000000.pva0: Adding to iommu group 50
pva 16000000.pva0: initialized
nvdla 15880000.nvdla0: Adding to iommu group 51
nvdla 15880000.nvdla0: initialized
nvdla 158c0000.nvdla1: Adding to iommu group 52
nvdla 158c0000.nvdla1: initialized
tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
tegra-fuse-burn efuse-burn: shutdown limit check disabled
tegra-fuse-burn efuse-burn: Fuse burn driver initialized
serial-tegra 3100000.serial: Adding to iommu group 3
3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
serial-tegra 3110000.serial: Adding to iommu group 3
3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 66, base_baud = 0) is a TEGRA_UART
serial-tegra 3130000.serial: Adding to iommu group 3
3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 67, base_baud = 0) is a TEGRA_UART
pca954x 2-0070: vcc-pullup regulator not found
pca954x 2-0070: device detect skipped.
i2c i2c-2: Added multiplexed i2c bus 9
i2c i2c-2: Added multiplexed i2c bus 10
irq: IRQ303: trimming hierarchy from :pmc@c360000
gpio-308 (EGPIO00_HDD_12V_CTR1): hogged as output/low
gpio-309 (EGPIO01_HDD_12V_CTR2): hogged as output/low
gpio-310 (EGPIO02_88SE_PWR_CRT): hogged as output/low
gpio-311 (EGPIO03_HDD_5V_CTR1): hogged as output/low
gpio-312 (EGPIO04_HDD_5V_CTR2): hogged as output/low
gpiochip2: registered GPIOs 308 to 315 on pcf8574
pcf857x 11-0020: probed
i2c i2c-2: Added multiplexed i2c bus 11
i2c i2c-2: Added multiplexed i2c bus 12
pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
pca954x 8-0070: vcc-pullup regulator not found
pca954x 8-0070: device detect skipped.
i2c i2c-8: Added multiplexed i2c bus 13
i2c i2c-8: Added multiplexed i2c bus 14
i2c i2c-8: Added multiplexed i2c bus 15
i2c i2c-8: Added multiplexed i2c bus 16
pca954x 8-0070: registered 4 multiplexed busses for I2C switch pca9546
cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2006000 KHz, changing to: 2035200 KHz
tegra194-cpufreq e000000.ccplex: probed with ICC
sdhci-tegra 3400000.sdhci: Got CD GPIO
tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
irq: IRQ304: trimming hierarchy from :pmc@c360000
mmc0: CQHCI version 5.10
tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 304
tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
mmc0: Command Queue Engine enabled
mmc0: periodic cache flush enabled
mmc0: new HS400 Enhanced strobe MMC card at address 0001
mmcblk0: mmc0:0001 G1M15M 59.3 GiB
mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
tegra194-pcie 14100000.pcie: Phy link never came up
tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
pci_bus 0001:00: root bus resource [bus 00-ff]
pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
pci 0001:00:00.0: PME# supported from D0 D3hot
pci 0001:00:00.0: PCI bridge to [bus 01-ff]
pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
pcieport 0001:00:00.0: Adding to iommu group 10
pcieport 0001:00:00.0: PME: Signaling with IRQ 51
pcieport 0001:00:00.0: AER: enabled with IRQ 51
pci_bus 0001:01: busn_res: [bus 01-ff] is released
pci 0001:00:00.0: Removing from iommu group 10
pci_bus 0001:00: busn_res: [bus 00-ff] is released
tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
tegra194-pcie 14160000.pcie: Phy link never came up
tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
pci_bus 0004:00: root bus resource [bus 00-ff]
pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
pci 0004:00:00.0: PME# supported from D0 D3hot
pci 0004:00:00.0: PCI bridge to [bus 01-ff]
pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
pcieport 0004:00:00.0: Adding to iommu group 11
pcieport 0004:00:00.0: PME: Signaling with IRQ 53
pcieport 0004:00:00.0: AER: enabled with IRQ 53
pci_bus 0004:01: busn_res: [bus 01-ff] is released
pci 0004:00:00.0: Removing from iommu group 11
pci_bus 0004:00: busn_res: [bus 00-ff] is released
CPU:0, Error:cbb-fabric@0x13a00000, irq=21
tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
tegra194-pcie 141e0000.pcie: Link up
tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
pci_bus 0007:00: root bus resource [bus 00-ff]
pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
pci 0007:00:00.0: PME# supported from D0 D3hot
pci 0007:01:00.0: [1b4b:9215] type 00 class 0x010601
pci 0007:01:00.0: reg 0x10: [io 0x8000-0x8007]
pci 0007:01:00.0: reg 0x14: [io 0x8040-0x8043]
pci 0007:01:00.0: reg 0x18: [io 0x8100-0x8107]
pci 0007:01:00.0: reg 0x1c: [io 0x8140-0x8143]
pci 0007:01:00.0: reg 0x20: [io 0x800000-0x80001f]
pci 0007:01:00.0: reg 0x24: [mem 0x00900000-0x009007ff]
pci 0007:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
pci 0007:01:00.0: Enabling fixed DMA alias to 00.1
pci 0007:01:00.0: PME# supported from D3hot
pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
pci 0007:00:00.0: BAR 13: assigned [io 0x200000-0x200fff]
pci 0007:01:00.0: BAR 6: assigned [mem 0x3228000000-0x322800ffff pref]
pci 0007:01:00.0: BAR 5: assigned [mem 0x3228010000-0x32280107ff]
pci 0007:01:00.0: BAR 4: assigned [io 0x200000-0x20001f]
pci 0007:01:00.0: BAR 0: assigned [io 0x200020-0x200027]
pci 0007:01:00.0: BAR 2: assigned [io 0x200028-0x20002f]
pci 0007:01:00.0: BAR 1: assigned [io 0x200030-0x200033]
pci 0007:01:00.0: BAR 3: assigned [io 0x200034-0x200037]
pci 0007:00:00.0: PCI bridge to [bus 01-ff]
pci 0007:00:00.0: bridge window [io 0x200000-0x200fff]
pci 0007:00:00.0: bridge window [mem 0x3228000000-0x32280fffff]
pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
pci 0007:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
pcieport 0007:00:00.0: Adding to iommu group 13
pcieport 0007:00:00.0: PME: Signaling with IRQ 57
pcieport 0007:00:00.0: AER: enabled with IRQ 57
vdd-3v3-pcie: supplied by vdd-3v3-sys
avdd-cam-2v8: supplied by vdd-3v3-sys
vdd-dp: supplied by vdd-3v3-sys
vdd-3v3-sd: supplied by vdd-3v3-sys
dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
irq: IRQ306: trimming hierarchy from :pmc@c360000
usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
tegra194-isp5 14800000.isp: initialized
tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
(NULL device *): fops function table already registered
tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
tegra-xusb 3610000.xhci: xHCI Host Controller
tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: xHCI Host Controller
usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
usb usb1: SerialNumber: 3610000.xhci
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: xHCI Host Controller
usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
usb usb2: SerialNumber: 3610000.xhci
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 4 ports detected
tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
usb 1-4: new high-speed USB device number 2 using tegra-xusb
tegra194-pcie 141a0000.pcie: Link up
tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
pci_bus 0005:00: root bus resource [bus 00-ff]
pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
pci 0005:00:00.0: PME# supported from D0 D3hot
pci 0005:01:00.0: [12d8:2608] type 01 class 0x060400
pci 0005:01:00.0: supports D1 D2
pci 0005:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0005:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0005:02:01.0: [12d8:2608] type 01 class 0x060400
usb 1-4: New USB device found, idVendor=04b4, idProduct=6506, bcdDevice=50.00
pci 0005:02:01.0: supports D1 D2
usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
pci 0005:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0005:02:02.0: [12d8:2608] type 01 class 0x060400
hub 1-4:1.0: USB hub found
pci 0005:02:02.0: supports D1 D2
hub 1-4:1.0: 4 ports detected
pci 0005:02:02.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0005:02:03.0: [12d8:2608] type 01 class 0x060400
pci 0005:02:03.0: supports D1 D2
pci 0005:02:03.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0005:02:04.0: [12d8:2608] type 01 class 0x060400
pci 0005:02:04.0: supports D1 D2
pci 0005:02:04.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0005:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0005:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0005:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0005:02:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
pci 0005:03:00.0: [10ec:8168] type 00 class 0x020000
pci 0005:03:00.0: reg 0x10: [io 0x0000-0x00ff]
pci 0005:03:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
pci 0005:03:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
usb 2-3: New USB device found, idVendor=04b4, idProduct=6504, bcdDevice=50.00
pci 0005:03:00.0: supports D1 D2
usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
pci 0005:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci_bus 0005:03: busn_res: [bus 03-ff] end is updated to 03
hub 2-3:1.0: USB hub found
pci 0005:04:00.0: [10ec:8168] type 00 class 0x020000
hub 2-3:1.0: 4 ports detected
pci 0005:04:00.0: reg 0x10: [io 0x0000-0x00ff]
pci 0005:04:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
pci 0005:04:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0005:04:00.0: supports D1 D2
pci 0005:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci_bus 0005:04: busn_res: [bus 04-ff] end is updated to 04
pci 0005:05:00.0: [10ec:8168] type 00 class 0x020000
pci 0005:05:00.0: reg 0x10: [io 0x0000-0x00ff]
pci 0005:05:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
pci 0005:05:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0005:05:00.0: supports D1 D2
pci 0005:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci_bus 0005:05: busn_res: [bus 05-ff] end is updated to 05
pci 0005:06:00.0: [10ec:8168] type 00 class 0x020000
pci 0005:06:00.0: reg 0x10: [io 0x0000-0x00ff]
pci 0005:06:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
pci 0005:06:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
pci 0005:06:00.0: supports D1 D2
pci 0005:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci_bus 0005:06: busn_res: [bus 06-ff] end is updated to 06
pci_bus 0005:02: busn_res: [bus 02-ff] end is updated to 06
pci 0005:00:00.0: BAR 14: assigned [mem 0x2b28000000-0x2b287fffff]
pci 0005:00:00.0: BAR 15: assigned [mem 0x2740000000-0x27407fffff 64bit pref]
pci 0005:00:00.0: BAR 13: assigned [io 0x300000-0x303fff]
pci 0005:01:00.0: BAR 14: assigned [mem 0x2b28000000-0x2b287fffff]
pci 0005:01:00.0: BAR 15: assigned [mem 0x2740000000-0x27407fffff 64bit pref]
pci 0005:01:00.0: BAR 13: assigned [io 0x300000-0x303fff]
pci 0005:02:01.0: BAR 14: assigned [mem 0x2b28000000-0x2b281fffff]
pci 0005:02:01.0: BAR 15: assigned [mem 0x2740000000-0x27401fffff 64bit pref]
pci 0005:02:02.0: BAR 14: assigned [mem 0x2b28200000-0x2b283fffff]
pci 0005:02:02.0: BAR 15: assigned [mem 0x2740200000-0x27403fffff 64bit pref]
pci 0005:02:03.0: BAR 14: assigned [mem 0x2b28400000-0x2b285fffff]
pci 0005:02:03.0: BAR 15: assigned [mem 0x2740400000-0x27405fffff 64bit pref]
pci 0005:02:04.0: BAR 14: assigned [mem 0x2b28600000-0x2b287fffff]
pci 0005:02:04.0: BAR 15: assigned [mem 0x2740600000-0x27407fffff 64bit pref]
pci 0005:02:01.0: BAR 13: assigned [io 0x300000-0x300fff]
pci 0005:02:02.0: BAR 13: assigned [io 0x301000-0x301fff]
pci 0005:02:03.0: BAR 13: assigned [io 0x302000-0x302fff]
pci 0005:02:04.0: BAR 13: assigned [io 0x303000-0x303fff]
pci 0005:03:00.0: BAR 4: assigned [mem 0x2740000000-0x2740003fff 64bit pref]
pci 0005:03:00.0: BAR 2: assigned [mem 0x2b28000000-0x2b28000fff 64bit]
pci 0005:03:00.0: BAR 0: assigned [io 0x300000-0x3000ff]
pci 0005:02:01.0: PCI bridge to [bus 03]
pci 0005:02:01.0: bridge window [io 0x300000-0x300fff]
pci 0005:02:01.0: bridge window [mem 0x2b28000000-0x2b281fffff]
pci 0005:02:01.0: bridge window [mem 0x2740000000-0x27401fffff 64bit pref]
pci 0005:04:00.0: BAR 4: assigned [mem 0x2740200000-0x2740203fff 64bit pref]
pci 0005:04:00.0: BAR 2: assigned [mem 0x2b28200000-0x2b28200fff 64bit]
pci 0005:04:00.0: BAR 0: assigned [io 0x301000-0x3010ff]
pci 0005:02:02.0: PCI bridge to [bus 04]
pci 0005:02:02.0: bridge window [io 0x301000-0x301fff]
pci 0005:02:02.0: bridge window [mem 0x2b28200000-0x2b283fffff]
pci 0005:02:02.0: bridge window [mem 0x2740200000-0x27403fffff 64bit pref]
pci 0005:05:00.0: BAR 4: assigned [mem 0x2740400000-0x2740403fff 64bit pref]
pci 0005:05:00.0: BAR 2: assigned [mem 0x2b28400000-0x2b28400fff 64bit]
pci 0005:05:00.0: BAR 0: assigned [io 0x302000-0x3020ff]
pci 0005:02:03.0: PCI bridge to [bus 05]
pci 0005:02:03.0: bridge window [io 0x302000-0x302fff]
pci 0005:02:03.0: bridge window [mem 0x2b28400000-0x2b285fffff]
pci 0005:02:03.0: bridge window [mem 0x2740400000-0x27405fffff 64bit pref]
pci 0005:06:00.0: BAR 4: assigned [mem 0x2740600000-0x2740603fff 64bit pref]
pci 0005:06:00.0: BAR 2: assigned [mem 0x2b28600000-0x2b28600fff 64bit]
pci 0005:06:00.0: BAR 0: assigned [io 0x303000-0x3030ff]
pci 0005:02:04.0: PCI bridge to [bus 06]
pci 0005:02:04.0: bridge window [io 0x303000-0x303fff]
pci 0005:02:04.0: bridge window [mem 0x2b28600000-0x2b287fffff]
pci 0005:02:04.0: bridge window [mem 0x2740600000-0x27407fffff 64bit pref]
pci 0005:01:00.0: PCI bridge to [bus 02-06]
pci 0005:01:00.0: bridge window [io 0x300000-0x303fff]
pci 0005:01:00.0: bridge window [mem 0x2b28000000-0x2b287fffff]
pci 0005:01:00.0: bridge window [mem 0x2740000000-0x27407fffff 64bit pref]
mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
pci 0005:00:00.0: PCI bridge to [bus 01-ff]
pci 0005:00:00.0: bridge window [io 0x300000-0x303fff]
pci 0005:00:00.0: bridge window [mem 0x2b28000000-0x2b287fffff]
pci 0005:00:00.0: bridge window [mem 0x2740000000-0x27407fffff 64bit pref]
pci 0005:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
pci 0005:01:00.0: Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128
pci 0005:02:01.0: Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128
pci 0005:03:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
pci 0005:02:02.0: Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128
pci 0005:04:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
pci 0005:02:03.0: Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128
pci 0005:05:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
pci 0005:02:04.0: Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128
pci 0005:06:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
pcieport 0005:00:00.0: Adding to iommu group 12
pcieport 0005:00:00.0: PME: Signaling with IRQ 55
pcieport 0005:00:00.0: AER: enabled with IRQ 55
pcieport 0005:01:00.0: Adding to iommu group 12
pcieport 0005:01:00.0: enabling device (0000 -> 0003)
pcieport 0005:02:01.0: Adding to iommu group 12
pcieport 0005:02:01.0: enabling device (0000 -> 0003)
pcieport 0005:02:02.0: Adding to iommu group 12
pcieport 0005:02:02.0: enabling device (0000 -> 0003)
pcieport 0005:02:03.0: Adding to iommu group 12
pcieport 0005:02:03.0: enabling device (0000 -> 0003)
pcieport 0005:02:04.0: Adding to iommu group 12
pcieport 0005:02:04.0: enabling device (0000 -> 0003)
nvethernet 2310000.ethernet: Adding to iommu group 53
nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
nvethernet 2310000.ethernet: failed to read MDIO address
nvethernet 2310000.ethernet: Failed to read nvida,pause_frames, so setting to default support as disable
nvethernet 2310000.ethernet: setting to default DMA bit mask
nvethernet 2310000.ethernet: max-platform-mtu DT entry missing, setting default 1500
nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:93:ec:bf
-->macsec_probe()
-->macsec_get_platform_res()
<--macsec_get_platform_res()
-->macsec_enable_car()
<--macsec_enable_car()
<--macsec_probe()
nvethernet 2310000.ethernet: Macsec not enabled
nvethernet 2310000.ethernet: Macsec: Reduced MTU: 1466 Max: 1500
nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
irq: IRQ312: trimming hierarchy from :pmc@c360000
irq: IRQ313: trimming hierarchy from :interrupt-controller@f400000-1
irq: IRQ314: trimming hierarchy from :pmc@c360000
input: gpio-keys as /devices/platform/gpio-keys/input/input0
tegra-se-nvhost 15810000.se: Adding to iommu group 54
tegra-se-nvhost 15810000.se: initialized
tegra-se-nvhost 15810000.se: tegra_se_probe: complete
tegra-se-nvhost 15820000.se: Adding to iommu group 55
tegra-se-nvhost 15820000.se: initialized
tegra-se-nvhost 15820000.se: tegra_se_probe: complete
tegra-se-nvhost 15840000.se: Adding to iommu group 56
tegra-se-nvhost 15840000.se: initialized
tegra-se-nvhost 15840000.se: tegra_se_probe: complete
tegra_actmon d230000.actmon: in actmon_register()...
tegra_actmon d230000.actmon: bwmgr_disable = 1
tegra_actmon d230000.actmon: initialization Completed for the device mc_all
hvc_sysfs: hypervisor is not present
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 3968K
Run /init as init process
with arguments:
/init
with environment:
HOME=/
TERM=linux
mminit_loglevel=4
Root device found: mmcblk0p1
Found dev node: /dev/mmcblk0p1
EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Rootfs mounted over mmcblk0p1
Switching from initrd to actual rootfs
tegra-xusb 3610000.xhci: entering ELPG done
systemd[1]: System time before build time, advancing clock.
x_tables: module verification failed: signature and/or required key missing - tainting kernel
systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
systemd[1]: Detected architecture arm64.
systemd[1]: Set hostname to <nvidia-desktop>.
systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
systemd[1]: Created slice system-modprobe.slice.
systemd[1]: Created slice system-serial\x2dgetty.slice.
systemd[1]: Created slice User and Session Slice.
systemd[1]: Started Forward Password Requests to Wall Directory Watch.
systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
systemd[1]: Reached target User and Group Name Lookups.
systemd[1]: Reached target Slices.
systemd[1]: Reached target Swap.
systemd[1]: Listening on RPCbind Server Activation Socket.
systemd[1]: Listening on Syslog Socket.
systemd[1]: Listening on fsck to fsckd communication Socket.
systemd[1]: Listening on initctl Compatibility Named Pipe.
systemd[1]: Listening on Journal Audit Socket.
systemd[1]: Listening on Journal Socket (/dev/log).
systemd[1]: Listening on Journal Socket.
systemd[1]: Listening on udev Control Socket.
systemd[1]: Listening on udev Kernel Socket.
systemd[1]: Mounting Huge Pages File System...
systemd[1]: Mounting POSIX Message Queue File System...
systemd[1]: Mounting RPC Pipe File System...
systemd[1]: Mounting Kernel Debug File System...
systemd[1]: Mounting Kernel Trace File System...
systemd[1]: Starting Journal Service...
systemd[1]: Starting Set the console keyboard layout...
systemd[1]: Starting Create list of static device nodes for the current kernel...
systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
systemd[1]: Starting NVIDIA specific first-boot udev script...
systemd[1]: Started Nameserver information manager.
systemd[1]: Reached target Network (Pre).
systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
systemd[1]: Starting Load Kernel Modules...
systemd[1]: Starting Remount Root and Kernel File Systems...
EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
nvmap_heap_init: nvmap_heap_init: created heap block cache
systemd[1]: Starting udev Coldplug all Devices...
tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x000000082f000000,16777216
tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
nvmap_page_pool_init: Total RAM pages: 7817411
nvmap_page_pool_init: nvmap page pool size: 977176 pages (3817 MB)
nvmap_background_zero_thread: PP zeroing thread starting.
misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
systemd[1]: Started Journal Service.
misc nvmap: created heap fsi base 0x000000082f000000 size (16384KiB)
systemd-journald[294]: Received client request to flush runtime journal.
nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
nvidia: loading out-of-tree module taints kernel.
nv_platform 13800000.display: Adding to iommu group 57
platform 13800000.display:nvdisplay-niso: Adding to iommu group 58
NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.1.0 Release Build (buildbrain@mobile-u64-5273-d7000) Wed Aug 10 20:32:39 PDT 2022
spi-tegra114 3210000.spi: Adding to iommu group 3
spi-tegra114 3230000.spi: Adding to iommu group 3
using random self ethernet address
using random host ethernet address
cpu-throttle-alert cooling device registered.
gpu-throttle-alert cooling device registered.
cv0-throttle-alert cooling device registered.
cv1-throttle-alert cooling device registered.
cv2-throttle-alert cooling device registered.
soc0-throttle-alert cooling device registered.
soc1-throttle-alert cooling device registered.
soc2-throttle-alert cooling device registered.
tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
irq: IRQ315: trimming hierarchy from :pmc@c360000
nct1008_nct72 4-004c: starting parse dt
nct1008_nct72 4-004c: !!!Found deprecated property!!!
nct1008_nct72 4-004c: success parsing dt
nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
libata version 3.00 loaded.
hot-surface-alert cooling device registered.
nct1008_nct72 4-004c: LOC shutdown limit 107
nct1008_nct72 4-004c: EXT shutdown limit 107
nvadsp 2993000.adsp: Adding to iommu group 59
nvadsp 2993000.adsp: in probe()...
nvadsp 2993000.adsp: nvadsp_app_module_probe
nct1008_nct72 4-004c: initial LOC temp: 46000
nct1008_nct72 4-004c: initial EXT temp: 52500
nct1008_nct72 4-004c: hi_b:-4, lo_b:0
nct1008_nct72 4-004c: nct1008_probe: initialized
1 fixed-partitions partitions found on MTD device spi6.0
Creating 1 MTD partitions on "spi6.0":
0x000000000000-0x000004000000 : "Whole_flash0"
tegra-hda 3510000.hda: Adding to iommu group 60
tegra-asoc: sound: Adding to iommu group 59
ahci 0007:01:00.0: Adding to iommu group 13
ahci 0007:01:00.0: version 3.0
irq: IRQ318: trimming hierarchy from :interrupt-controller@f400000-1
ucsi_ccg 1-0008: i2c_transfer failed -121
ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
ahci 0007:01:00.0: AHCI 0001.0000 32 slots 4 ports 6 Gbps 0xf impl SATA mode
ahci 0007:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
r8169 0005:03:00.0: Adding to iommu group 12
ucsi_ccg: probe of 1-0008 failed with error -121
r8169 0005:03:00.0: enabling device (0000 -> 0003)
scsi host0: ahci
scsi host1: ahci
input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
scsi host2: ahci
scsi host3: ahci
ata1: SATA max UDMA/133 abar m2048@0x3228010000 port 0x3228010100 irq 317
ata2: SATA max UDMA/133 abar m2048@0x3228010000 port 0x3228010180 irq 317
ata3: SATA max UDMA/133 abar m2048@0x3228010000 port 0x3228010200 irq 317
ata4: SATA max UDMA/133 abar m2048@0x3228010000 port 0x3228010280 irq 317
r8169 0005:03:00.0 enp2s0: RTL8168f/8111f, 00:e0:4c:68:00:06, XID 481, IRQ 319
r8169 0005:03:00.0 enp2s0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 59
tegra210_adsp_audio_probe: platform probe started
r8169 0005:04:00.0: Adding to iommu group 12
r8169 0005:04:00.0: enabling device (0000 -> 0003)
tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
tegra210-adsp tegra210-adsp: using adma channel page 0
nvadsp 2993000.adsp: ADSP OS firmware already loaded
r8169 0005:04:00.0 (unnamed net_device) (uninitialized): failed to name netdev enp2s0, err = -23
r8169 0005:04:00.0 eth1: RTL8168f/8111f, 00:e0:4c:68:00:08, XID 481, IRQ 320
r8169 0005:04:00.0 eth1: jumbo features [frames: 9194 bytes, tx checksumming: ko]
r8169 0005:05:00.0: Adding to iommu group 12
r8169 0005:05:00.0: enabling device (0000 -> 0003)
r8169 0005:05:00.0 (unnamed net_device) (uninitialized): failed to name netdev enp2s0, err = -23
r8169 0005:05:00.0 eth2: RTL8168f/8111f, 00:e0:4c:68:00:09, XID 481, IRQ 321
r8169 0005:05:00.0 eth2: jumbo features [frames: 9194 bytes, tx checksumming: ko]
r8169 0005:06:00.0: Adding to iommu group 12
r8169 0005:06:00.0: enabling device (0000 -> 0003)
r8169 0005:06:00.0 (unnamed net_device) (uninitialized): failed to name netdev enp2s0, err = -23
r8169 0005:06:00.0 eth3: RTL8168f/8111f, 00:e0:4c:68:00:07, XID 481, IRQ 322
r8169 0005:06:00.0 eth3: jumbo features [frames: 9194 bytes, tx checksumming: ko]
loop: module loaded
tegra210-adsp tegra210-adsp: Loaded app wire
tegra210-adsp tegra210-adsp: Loaded app apm
tegra210-adsp tegra210-adsp: Loaded app adma
tegra210-adsp tegra210-adsp: Loaded app adma_tx
nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000e6b1fc55
ata1: SATA link down (SStatus 0 SControl 300)
ata4: SATA link down (SStatus 0 SControl 300)
tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
ata3: SATA link down (SStatus 0 SControl 300)
cryptd: max_cpu_qlen set to 1000
Mass Storage Function, version: 2009/09/11
LUN: removable file: (no medium)
rndis0: HOST MAC 36:db:8b:e7:d3:d0
rndis0: MAC 36:db:8b:e7:d3:d1
usb0: HOST MAC 36:db:8b:e7:d3:d2
usb0: MAC 36:db:8b:e7:d3:d3
tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
l4tbr0: port 1(rndis0) entered blocking state
l4tbr0: port 1(rndis0) entered disabled state
device rndis0 entered promiscuous mode
l4tbr0: port 2(usb0) entered blocking state
l4tbr0: port 2(usb0) entered disabled state
device usb0 entered promiscuous mode
irq: IRQ323: trimming hierarchy from :interrupt-controller@f400000-1
RTL8211E Gigabit Ethernet r8169-5-500:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-5-500:00, irq=IGNORE)
r8169 0005:05:00.0 eth2: Link is Down
RTL8211E Gigabit Ethernet r8169-5-400:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-5-400:00, irq=IGNORE)
r8169 0005:04:00.0 eth1: Link is Down
RTL8211E Gigabit Ethernet r8169-5-600:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-5-600:00, irq=IGNORE)
pstore: Using crash dump compression: deflate
printk: console [ramoops-1] enabled
pstore: Registered ramoops as persistent store backend
ramoops: using 0x200000@0x82c200000, ecc: 0
r8169 0005:06:00.0 eth3: Link is Down
RTL8211E Gigabit Ethernet r8169-5-300:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-5-300:00, irq=IGNORE)
r8169 0005:03:00.0 enp2s0: Link is Down
nvgpu: 17000000.ga10b tpc_pg_mask_store:1067 [INFO] no value change, same mask already set
zram: Added device: zram0
zram: Added device: zram1
zram: Added device: zram2
zram: Added device: zram3
zram: Added device: zram4
zram: Added device: zram5
zram: Added device: zram6
zram: Added device: zram7
zram0: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram0. Priority:5 extents:1 across:1954348k SS
zram1: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram1. Priority:5 extents:1 across:1954348k SS
zram2: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram2. Priority:5 extents:1 across:1954348k SS
zram3: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram3. Priority:5 extents:1 across:1954348k SS
zram4: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram4. Priority:5 extents:1 across:1954348k SS
zram5: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram5. Priority:5 extents:1 across:1954348k SS
zram6: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram6. Priority:5 extents:1 across:1954348k SS
zram7: detected capacity change from 0 to 2001256448
Adding 1954348k swap on /dev/zram7. Priority:5 extents:1 across:1954348k SS
r8169 0005:06:00.0 eth3: Link is Up - 1Gbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth3: link becomes ready
pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
fuse: init (API version 7.32)
nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.1.0 Release Build (buildbrain@mobile-u64-5273-d7000) Wed Aug 10 20:32:41 PDT 2022
NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
CPU: 4 PID: 1555 Comm: modprobe Tainted: G W OE 5.10.104-tegra #3
Hardware name: /, BIOS 1.0-d7fb19b 08/10/2022
Call trace:
dump_backtrace+0x0/0x1d0
show_stack+0x2c/0x40
dump_stack+0xd8/0x138
os_dump_stack+0x18/0x20 [nvidia]
tlsEntryGet+0x130/0x138 [nvidia]
gpumgrGetSomeGpu+0x7c/0x90 [nvidia]
threadPriorityStateFree+0xa8/0x2a8 [nvidia]
rmclientConstruct_IMPL+0x170/0x240 [nvidia]
__nvoc_ctor_RmClient+0x5c/0x88 [nvidia]
__nvoc_objCreate_RmClient+0x78/0x110 [nvidia]
resservClientFactory+0x28/0x90 [nvidia]
serverAllocClient+0x19c/0x318 [nvidia]
serverAllocResource+0x140/0x2e0 [nvidia]
rmapiAllocWithSecInfo+0x180/0x2e0 [nvidia]
rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
rmapiControlWithSecInfoTls+0x4a8/0x520 [nvidia]
nvkms_call_rm+0x60/0x98 [nvidia_modeset]
nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
do_one_initcall+0x4c/0x2d0
do_init_module+0x4c/0x200
load_module+0x1ff8/0x22f0
__do_sys_finit_module+0xb4/0xf0
__arm64_sys_finit_module+0x28/0x40
el0_svc_common.constprop.0+0x7c/0x1c0
do_el0_svc+0x34/0xa0
el0_svc+0x1c/0x30
el0_sync_handler+0xa8/0xb0
el0_sync+0x16c/0x180
NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
nvidia@nvidia-desktop:~$ lspci -vvv
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 55
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 00000000-00003fff [size=16K]
Memory behind bridge: 40000000-407fffff [size=8M]
Prefetchable memory behind bridge: 0000002740000000-00000027407fffff [size=8M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: <access denied>
Kernel driver in use: pcieport
0005:01:00.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Bus: primary=01, secondary=02, subordinate=06, sec-latency=0
I/O behind bridge: 3a100000-3a103fff [size=16K]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
0005:02:01.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 307
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 3a100000-3a100fff [size=4K]
Memory behind bridge: 40000000-401fffff [size=2M]
Prefetchable memory behind bridge: 0000002740000000-00000027401fffff [size=2M]
0005:02:02.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 308
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 3a101000-3a101fff [size=4K]
Memory behind bridge: 40200000-403fffff [size=2M]
Prefetchable memory behind bridge: 0000002740200000-00000027403fffff [size=2M]
0005:02:03.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 309
Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 3a102000-3a102fff [size=4K]
Memory behind bridge: 40400000-405fffff [size=2M]
Prefetchable memory behind bridge: 0000002740400000-00000027405fffff [size=2M]
0005:02:04.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 310
Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: 3a103000-3a103fff [size=4K]
Memory behind bridge: 40600000-407fffff [size=2M]
Prefetchable memory behind bridge: 0000002740600000-00000027407fffff [size=2M]
0005:03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 19)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Latency: 0, Cache Line Size: 64 bytes
Region 0: I/O ports at 300000 [size=256]
Region 2: Memory at 2b28000000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 2740000000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169, r8168
0005:04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 19)
Region 0: I/O ports at 301000 [size=256]
Region 2: Memory at 2b28200000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 2740200000 (64-bit, prefetchable) [size=16K]
0005:05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 19)
Region 0: I/O ports at 302000 [size=256]
Region 2: Memory at 2b28400000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 2740400000 (64-bit, prefetchable) [size=16K]
0005:06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 19)
Region 0: I/O ports at 303000 [size=256]
Region 2: Memory at 2b28600000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 2740600000 (64-bit, prefetchable) [size=16K]
0007:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 57
I/O behind bridge: 00000000-00000fff [size=4K]
Memory behind bridge: 40000000-400fffff [size=1M]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
0007:01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11) (prog-if 01 [AHCI 1.0])
Subsystem: Marvell Technology Group Ltd. Device 9215
Latency: 0
Interrupt: pin A routed to IRQ 318
Region 0: I/O ports at 200020 [size=8]
Region 1: I/O ports at 200030 [size=4]
Region 2: I/O ports at 200028 [size=8]
Region 3: I/O ports at 200034 [size=4]
Region 4: I/O ports at 200000 [size=32]
Region 5: Memory at 3228010000 (32-bit, non-prefetchable) [size=2K]
Expansion ROM at 3228000000 [disabled] [size=64K]
Kernel driver in use: ahci
Kernel modules: ahci
